B44 motor/esc choice for short track? >
Old 02-10-2009, 11:24 AM
  #16
JEFFRO503's Avatar
Damn it....i'm probably going to have to buy two B44's now , and put a Tekin system in one and a LRP system in the other.
JEFFRO503 is offline
Old 02-10-2009, 11:33 AM
  #17
JEFFRO503's Avatar
Is this the tekin package i should be looking at? >>> http://www.amainhobbies.com/product_...ducts_id/32312
and is this the LRP package i should be looking at? >>>> Motor > http://www.amainhobbies.com/product_...ducts_id/34261
and ESC >>> http://www.amainhobbies.com/product_...ducts_id/14048
In the LRP stuff , i get confused on the exact ESC i'm supposed to be looking at.
Both the tekin and LRP stuff look so good....it's a hard choice.
Old 02-10-2009, 12:30 PM
  #18
B4wires2's Avatar
Jeffro503 you have a P.M..
B4wires2 is offline
Old 02-10-2009, 02:23 PM
  #19
Im running a 5700 MM. I have all the power i nee and find it perfect for most tracks. Im not running lipos tho, so maybe a 4600 would work for you. Although i do know of a hot bodies driver who uses the 7500 in his ride!
AE BT is offline
Old 02-10-2009, 02:47 PM
  #20
C Reedy's Avatar
I run with the novak gtb and 6.5r with lipos and it is plenty of motor
C Reedy is offline
Old 02-10-2009, 07:02 PM
  #21
JEFFRO503's Avatar
well guys....thanks for all the advice on the motor/esc stuff. As of right now i've decided to go with the Tekin RS pro 6.5 or 7.5 setup >>>> http://www.amainhobbies.com/product_...ducts_id/32307
seems like it'll be a great setup. And who knows....i may get into this hard enough again to try out the LRP set up as well. maybe try out some of the novak motors as well with these esc's.
thanks again!
Old 02-10-2009, 08:19 PM
  #22
Trader Rating: 19 (100%+)
Hi jeffro503
With the Tekin RS Pro and B44. You could put in either 5.5 or 6.5 too.
The RS Pro can handle the hotter brushless motors.
Something to think about.
Tekin has real good tech support from staff and team drivers. If you have questions on your Tekin, you can go to www.teamtekin.com. They have thier own forum.
Everyone is be more then happy to help you with your questions.
If you have any.
b4wires is offline
Old 02-10-2009, 08:40 PM
  #23
JEFFRO503's Avatar
Thanks man. I am sure i'll be hitting up the tekin forums once i get things under way. I was shooting for something pretty powerfull , thinking something like a 6.5 or 7.5 because i didn't want to over power the car. The track i'll be running it on isn't all that big , but it'll have some sections where i'll need all the grunt out of the motor i can get. I will definetly do some more reading before i finally decided to buy tekin system. I could just swap out motors to i guess? Have a 7.5 for here at home and maybe a 5.5 when i go to a bigger track...that might work.
Old 02-10-2009, 08:46 PM
  #24
Happy to help you out. I like my Tekins. They work good for me.
b4wires is offline
