B4...lipo or not? (setup questions) >
Old 02-09-2009, 03:24 PM
  #31
speedsterblade's Avatar
Originally Posted by CaptainHowdyt13 View Post
Scratch that, I got my answer. I just hope this 25/81 gearing with a 10.5 motor will work well.
I think I was running 26/81 but it may have been a 84spur... what you ordered should work fine but I'd say you can go up 1 or 2 before any temp issues. Gearing suggestions are tough cause tires vary in height, tracks vary and there are other varibables...best advise is checking your temps and laptimes for proper gearing. I run GTB w/ no fan, never gotten this motor 'hot' ever..maybe 150degrees after a 10 min run, on a hot day. I could gear higher but it's a tight track and would hurt my infield times.
speedsterblade is offline
Old 02-09-2009, 04:10 PM
  #32
porkey's Avatar
No got with 78 30 on the b4. I seen it done and it was fast and temps at 150.
porkey is offline
Old 02-09-2009, 05:17 PM
  #33
Trader Rating: 520 (100%+)
Yeah, im runnin 78-30 also w/13.5 low temp and plenty of usable power..
flame56mx is offline
Old 02-09-2009, 10:26 PM
  #34
bigbadyoda's Avatar
I run a xxxt with a 5700kv system on 5000 20c, 3800 30c, 5000 20c lipos.. There's a BIG difference in run time and performance between nihms and lipos.. I's strongly recommend the lipos..
My motor rocks on the tracks I run.. Kinda open a little and more long straights where the bigger motor buys can pull away..
bigbadyoda is offline
