Dirt Hardening Additives >
Old 01-29-2002, 06:33 PM
Default Dirt Hardening Additives
I was wondering what all the big tracks in the down there in the states use to harden the dirt so the track will last longer and not crumble. Currently I am thinking calcium chloride, but what do you guys use?
bmxxxry is offline
Old 01-29-2002, 08:20 PM
well the track i go to isnt one of the big tracks around but i know they do use calcium chloride to keep it fresh. i am in NW indiana
adam is offline
Old 01-29-2002, 09:16 PM
does it last good? Like do the jumps last a far bit, right now we are stuck with the track rutting up and the jumps getting torn down to the point where the quad is now a single section instead of a double double. How is traction?
bmxxxry is offline
Old 01-29-2002, 09:20 PM
from week to week it dosent really change. they re do the track every 4 to 6 weeks, but the jumps dont really change between that time at all. the tabletop jump has been there for at least 3 months and looks the same as it did then. traction is good i think. gets kinda dusty by the 3rd qualifier but still has good traction.
adam is offline
Old 01-29-2002, 09:47 PM
cool man...thanks for da info
bmxxxry is offline
Old 01-31-2002, 12:27 PM
Jared Kirkwood's Avatar
bmxxxry - Try the calcium chloride and saw dust. We had an outdoor track that we added that too and it seemed to help. I can't really say how much we added but it did hold water better and stayed together better. Just play around with a section of the track until you feel like you've found a good formula.
I do know they added to much saw dust to one section that part would flake up. So don't add to much. I think the saw dust was to help hold the water and the calcium chloride helped hold the dirt together. But the part that was right stayed really spongy.
They used calcium cloride at the '97 worlds in cal to help that track hold up best I can remember.
Good Luck.
Jared Kirkwood is offline
Old 02-02-2002, 07:58 AM
Default tracks
the track should be constructed from a mixture of 70% clay 30% sand. smoothed and rolled it should last a long time. the top inch can be loosened up and watered for the ultimate in traction.
Dr.Dirt is offline
Old 02-02-2002, 05:46 PM
cool...thanks guys. I think I will go with the Calcium Chloride and try some saw dust to hold the water.
When we do get a load of dirt for this year, i will order that mix of 70% clay 30% sand. Thanks again for the tips guys.
bmxxxry is offline
Old 02-02-2002, 08:13 PM
007yoshi's Avatar
Our track uses 70% topsoil and 30% clay and our track stays really hard packed, only a little dirt stays looseon top. Holds water really well. BUT this is an indoor track.
007yoshi is offline
Old 02-09-2002, 05:06 PM
How would a mixture of black dirt and sand hold up outside? It's hard to find clay is some parts of the US.
Team Green
GreenRC is offline
Old 06-30-2010, 08:33 PM
Ridley's Avatar
soiltac will hold the track together better than calcium chloride, and it won't corrode your cars either. There's a whole slew of soil additives along the same lines as soiltac. Use google
Calcium does best at just bringing and holding moisture in the surface of the track, it's not really a soil binder.
Ridley is offline
Old 06-30-2010, 08:46 PM
bboard's Avatar
My local track uses lime. Water, roll, drench with water, roll once, add lime with a spreader, and roll until its dry. Makes the track super super hard packed.
bboard is offline
Old 06-30-2010, 09:53 PM
How's this for traction?
http://s190.photobucket.com/albums/z...7.flv&newest=1
We use soil stabilizer diluted with water and it looks just like elmers glue. On a fresh track there is more traction than concrete.
8ight-racer is offline
Old 06-30-2010, 11:24 PM
mdowney's Avatar
Trader Rating: 21 (100%+)
We have a local "home grown" track down the street on a vacant lot. It doesn't have access to water (though it's in Seattle so it gets plenty of rain). The locals have put a lot of time into carving out a pretty decent track, considering. However, without water we end up with a LOT of dust and big traction problems.
Any tips on things we can do to get more traction, other then sweeping the heck out of it every time we use it? I think plenty of us would throw in some money for chemicals or whatever...
mdowney is offline
Old 07-01-2010, 12:17 AM
ScottKelly911's Avatar
My friends and I have a local track that we made, where's a good place to get clay for the track?
ScottKelly911 is offline
