Weller WLC100
Weller WLC100
Have any of you guys ever used this iron? I need something for soldering 13GA wire.
http://www.amazon.com/Weller-WLC100-.../dp/B000AS28UC
Get the hakko...
Yeah, but the Hakko is like $80.
I have one i like it just fine but no it is not as good as a Hakko. and you will need to get a wider tip . for the price it is a descent iron.
If you want cheep go with this
http://www.homedepot.com/webapp/wcs/...ctId=100391613
It will solder 12 gauge wire no problem and fits in the pit box.
You don't need a temp controlled or variable iron for soldering wires together... at least in my opinion, I'm sure others will disagree.
Just bought the cheap Weller iron, and it worked like a charm. I just had to use the biggest tip to get enough heat. Thanks for the advice guys.
Yep, for wires, those thick high wattage irons actually do pretty well. I have that WLC100, while its not nearly as good as the hakko, it does just about everything great. I have several tips though, I use a thicker flat one for RC, but the sharp pointed one works great for PCB work.
Tech Legend
Trader Rating: 51 (100%+)
IF you want a really nice iron from Weller then you want the WES51. Been using mine for many years now and works great and would be similiar to the Hakko 936 which is another good soldering station.
I had many of cheap ones in the past but they all sucked so I broke down and spent a little more money for the WES51 and never looked back.
