Like Tree22Likes
Old 01-01-2014, 09:15 AM
  #14941
Originally Posted by flame56mx
After 1.5 years I finally broke my first front tower, my son has taken a ball stud mount off of a pair. Found this while browsing..interesting idea, judging by the thickness maybe more than just added strength going on??
Attachment 1149633
They look to be like a they're machined aluminum. Weight wouldn't be too high, but if they are weighted why would you want the weight up so high?
TLRrunner is offline
Old 01-01-2014, 09:21 AM
  #14942
8ight-e's Avatar
Trader Rating: 58 (100%+)
Originally Posted by jmackani
Take a brass wheel to the slipper clip and take off the black coating. It will come out smoother. Although charging in the car is easier, I do not recommend it. There are plenty of pictures on here of entire vehicles ruined when the lipo charging goes wrong.
You have to bypass most chargers safety features to even charge at the wrong voltage at this point.... lipo's don't ever have issues charging if you charge at the correct voltage setting. Understand the battery = no issues. About the only other thing that could possibly go wrong is a short and you can do that in or out of the vehicle charging or not charging if you are careless.. don't be careless; give respect where it is due and you will NEVER have an issue
8ight-e is offline
Old 01-01-2014, 09:32 AM
  #14943
thephunnel's Avatar
Hey guys. I'm just getting my Dex410 ready to hit the track for the first time. What would be a good size pinion to start with? Med size carpet track, 7.5 motor , and will be using the 87t spur.
thephunnel is offline
Old 01-01-2014, 09:37 AM
  #14944
tksnobords's Avatar
Trader Rating: 36 (100%+)
Originally Posted by platgof
Batteries don't get warm after the race? I guess the puffing at high altitude explains why airlines don't like them.
My buggy batteries get a little warm after the race. So I let them cool, then charge them up. Only takes like 30 min to charge them.
tksnobords is offline
Old 01-01-2014, 10:26 AM
  #14945
R/C Tech Elite Member
Trader Rating: 520 (100%+)
Warm yes, Hot is not normal though. If yours are hot then there is an issue that should be addressed, or it will eventually address itself with bad results. I have rec'd a set of 2s packs via priority mail a while back. One with a 3.90 charge and one had 4.15 on it. I put a storage on both, and stored them. The mostly charged one puffed a few days later..The other worked fine for months..
flame56mx is offline
Old 01-01-2014, 11:00 AM
  #14946
the incubus's Avatar
Trader Rating: 17 (100%+)
Geez, sounds like you can use a better charger. Lol
My Reedy 5200 packs take just over 15 minutes to charge, but I have the Elan RX2 which is the best charger I've ever used.
the incubus is offline
Old 01-01-2014, 11:07 AM
  #14947
You mean like removing the wires first. Again, do you use two sets of batteries?
I'm referring to the slipper and battery retaining pins. I figured removing the wires was a given. As for easier slipper pin removal, the easiest way is with your index finger as you pull down on it ever so slightly as you pull towards you. Then the battery pin and follow as I described. Practice it a few times and it'll become a breeze.
Old 01-01-2014, 11:11 AM
  #14948
tksnobords's Avatar
i would hope so for $350 lol. pretty nice looking charger though. i would like to get a 20A Charger
they don't even have any distributors listed on their website. is WWW.EXPRESSRCHOBBIES.COM the only place to get it or something
Old 01-01-2014, 12:15 PM
  #14949
racingdan's Avatar
You can buy here at smc-racing.net
racingdan is offline
Old 01-01-2014, 12:20 PM
  #14950
huzzler's Avatar
Damn you must charge them at a high amperage. I bet your packs dont last very long? I always charge my packs at 1c some even lower. I never have problems with my packs puffing and I have some that are over three years old.
huzzler is offline
Old 01-01-2014, 12:45 PM
  #14951
Smc recommends charging at 2c
Barge is offline
Old 01-01-2014, 12:52 PM
  #14952
huzzler's Avatar
My wallet recommends me to charge at 1c.
huzzler is offline
Old 01-01-2014, 01:10 PM
  #14953
Hard to say, maybe trying to balance..? Get the car to roll more.. or maybe it is what we think it is, and just a tower stiffener..lol
Old 01-01-2014, 01:19 PM
  #14954
huzzler's Avatar
I would start with an 18 and go from there.
huzzler is offline
Old 01-01-2014, 01:28 PM
  #14955
Depends on what type of 7.5t motor you have. With the Trackstar 7.5t I use 24t or 25t pinion on an outdoor track with 30m long straight
ridgeracer is offline
