Like Tree22Likes
Old 12-30-2013, 04:51 PM
  #14911
Typical Durango the late Dec release for the V4 is now listed late Jan, just yesterday Tower still had it as a late Dec release.
Sleepytime is offline
Old 12-30-2013, 05:03 PM
  #14912
R/C Tech Elite Member
Trader Rating: 520 (100%+)
It'll be worth it, one cant control the ships @ sea..
flame56mx is offline
Old 12-30-2013, 11:29 PM
  #14913
Anyone know the part number for for the TD +2 RF hanger?
TLRrunner is offline
Old 12-31-2013, 01:09 AM
  #14914
disregard my previous post. I figured out the RF hanger can be flipped and it becomes the +2 that I was looking for!
Old 12-31-2013, 05:42 AM
  #14915
doubled up..VVV
Old 12-31-2013, 05:43 AM
  #14916
I been there before..did the same thing..
Old 12-31-2013, 07:30 AM
  #14917
Just finnished my winter car ( and most of our rainy summers car )
A waterproof DEX410. Im using the Hobbywing Ezrun SC 120a esc and the Ezrun 3656, 4700kv motor. Also mounted a waterproof receiver boc on the right side, above the lipo, just behind the spur. If I use the 15mm hex from the DESC410 up front and 12mm hex for the B44.2 at the rear I can use DE racing wheels and 2.2 truck tires.
Pics are coming.
ridgeracer is offline
Old 12-31-2013, 10:15 AM
  #14918
13Maschine's Avatar
I also hate Cab forward stuff! haha
Gainabull was the best body I've seen so far.
13Maschine is offline
Old 12-31-2013, 10:34 AM
  #14919
13Maschine's Avatar
Happy New Year Everyone!
I've had my V3 for a couple months now and I've had a couple of days of track time at SCVRC here in Cali and also one day at the ever famous OCRC. Let me say the DEX410 is the best 4 wheel I've ever driven and I haven't done much to set it up. Couple of questions for everyone here...
At first I ran the plastic shock towers from the R version because I broke one of the carbon towers in a bad crash with a SC truck. That's what I get for running on saturdays with all the crazies. I broke several of the plastic shock towers learning the track and car and have now switched back to carbon. The carbon actually seems more durable. I had a few tumbles at OCRC my most recent track day and I didn't break anything. Only a ball cup popped off. (My DEX210 was another story however…can't wait for Type B parts!) Are most of you running the Carbon towers? Or Aluminum? Do you find the Carbon breaks easily?
Lastly, are most of you running the rear sway bar? I've tried it with and without but need to do more testing to really understand what it does.
Thanks!
  #14920
13Maschine's Avatar
Thanks!
Old 12-31-2013, 10:42 AM
  #14921
tobamiester's Avatar
Trader Rating: 360 (100%+)
Thanks!
Some will say they've never broke a Carbon tower. Personally broken at least 3 Fronts (One aftermarket, 2 TD) in 2+ years driving the car. I run the old Alum front tower, and Carbon Rear.
And Rear Sway bar only - tames the rear of the car down, and rotates more consistently.
tobamiester is offline
Old 12-31-2013, 10:44 AM
  #14922
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Thanks!
I do run the rear sway as I feel it helps smooth the car out. I was getting a quick jerk/ over rotation in certain corners. The sway helped tame that down and made it almost slide through the corner rather than the snap/spin. To sum it up I think it made the car more consistent. Good Luck!
Bman's 3XNT is offline
  #14923
13Maschine's Avatar
sorry I can't seem to delete my double post….
Rear sway bar only? I swear some guys run the front only? Do you mind elaborating?
Old 12-31-2013, 10:45 AM
  #14924
13Maschine's Avatar
Old 12-31-2013, 11:05 AM
  #14925
It wont let you delete a complete post, but you can edit/change the info posted. A sway bar on either front or rear but not both will generally give the opposite end more traction. They are normally ran on both ends to help smooth the car (especially in higher speed corners). If the track is really rough, they (IMO) do more bad than good..
