Like Tree22Likes
Old 12-24-2013, 07:35 PM
  #14851
Trader Rating: 38 (100%+)
Originally Posted by jmackani
Tires seem right. What are your ride heights? Go to 19 both front and rear and remove your sway bars. Use dual rate on your radio to calm down the steering.
what should I run for droop? Full extension, or wind it down? Hopefully I can get to the track thursday and play around before friday racing.
vw addict is offline
Old 12-24-2013, 09:15 PM
  #14852
jmackani's Avatar
Trader Rating: 14 (100%+)
22mm in the front, 33 mm in the rear. Measure from base of shock cap on the bottom of the shock body to the top of the bottom shock mount where the threads stop. It's shown this way as length on the setup sheets.
jmackani is offline
Old 12-24-2013, 11:30 PM
  #14853
Originally Posted by HotBodiesVe8Boy
Hey everyone, running 2 team durango dex410 v3's for next season. Running them both with speed passion reventon pro's, savox 1256 tg's and 7.5t novak vulcan and a trinity d3.5 17.5t. I was just wondering would I need different oils in the diffs for stock vs mod? I am running stock pistons and stock springs. What would be a good starting place for oils for shocks and diffs? Running on a high grip outdoor 1/10th track with a few jumps. Any input is greatly appreciated. Cheers Jay
any input? rebuilding both as of now
HotBodiesVe8Boy is offline
Old 12-25-2013, 12:05 AM
  #14854
Mopar's Avatar
Originally Posted by knowitall156
Do you happen to know the axle u-joint part numbers off hand?
Thanks,
13120VRY
Attached Thumbnails Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-td310426t.jpg
Mopar is offline
Old 12-25-2013, 07:54 AM
  #14855
jmackani's Avatar
Run it as is and see how it feels. Then probably post what you need out of the car for you and we can probably help.
jmackani is offline
Old 12-25-2013, 09:07 AM
  #14856
Got my V4 yesterday. Going to start building today.
knowitall156 is offline
Old 12-25-2013, 09:15 AM
  #14857
R/C Tech Elite Member
Trader Rating: 520 (100%+)
Coo-ull...
flame56mx is offline
Old 12-25-2013, 09:59 AM
  #14858
Trader Rating: 47 (100%+)
Looking at getting into 4wd. Am I better off trying to find a good used v3 or just get a new v4. I'm leaning towards the v4. I just don't a whole lot about this buggy. Still doing some reading. Lol
Any tips tricks ideas would be great.
Thanks,
DC
smitty2802 is offline
Old 12-25-2013, 11:30 AM
  #14859
jmackani's Avatar
Thanks,
DC
Since you are new, I recommend buying new. Then you learn it as you build and not worry about any problems from a previous owner.
jmackani is offline
Old 12-25-2013, 11:57 AM
  #14860
That's what I'm leaning towards. Just didn't know what hopups. And they seem pricey. From what I've read seems like the hoops and rear brass weight
Thanks,
DC
Old 12-25-2013, 03:10 PM
  #14861
platgof's Avatar
I bought used because of the deal I was offered. I will use the money saved for batteries and other stuff. I still need some bearings and will get the Avids. I am going low key on mine as I don't need stupid power. I run on a small indoor track, so I put a Tekin RS and Gen2 13.5 in it, and will use Gens Ace 4600 25c batteries. I do not plan on going that fast and hate replacing parts. I just want something that is very controllable.
platgof is offline
Old 12-25-2013, 03:14 PM
  #14862
jmackani's Avatar
Thanks,
DC
Rear brass weight yes. Hoops are not necessary. Between myself and sons, we have three and they had the stock hoops over two years with no issues. Mine was aluminum from day one.
jmackani is offline
Old 12-25-2013, 03:42 PM
  #14863
platgof's Avatar
Are you using all three brass weights?
platgof is offline
Old 12-25-2013, 03:47 PM
  #14864
jmackani's Avatar
Just the rear. The other two can make the car hard to correct off some jumps. The additional weight with them causes too much momentum to counteract in my opinion.
jmackani is offline
Old 12-25-2013, 03:56 PM
  #14865
huzzler's Avatar
I totally agree with you here. I ran all three weights on my car when I first got it. Then one day I was talking to one of the faster guys at my track and he suggested I try it without the side weights and it was a noticeable difference. Never put them back on since.
huzzler is offline
