Like Tree22Likes
Old 12-10-2013, 12:06 PM
  #14686
murky123's Avatar
so the tunability of a 2way slipper depends on how big your variety of slipperpads is? pads with less holes or more holes? bigger holes, smaller holes?
that is getting a bit of expensive
murky123 is offline
Old 12-10-2013, 12:53 PM
  #14687
Cameron Kellogg's Avatar
Trader Rating: 45 (100%+)
Yes the testing process could be. I have an idea for a slipper pad but I am not sure if they can be made yet. We will see what Marcus at RCShox has to say about it and let you know.
Cameron Kellogg is offline
Old 12-10-2013, 02:26 PM
  #14688
ekt
ekt's Avatar
I now how a 2way slipper works. front and rear can work independent from eachother. but I I dont understand how to adjust it? lets say I want to loosen up the front. how do you do that without effecting the rear?
Here's a bit of info on tuning the 2-way http://www.oople.com/forums/showpost...8&postcount=35
ekt is offline
Old 12-10-2013, 02:51 PM
  #14689
Trader Rating: 50 (100%+)
Anybody have a spare DEX410 bevel gear, part # 310005? I had a set of two and upon looking at them one of them is missing a tooth. They are out of stock everywhere.
jamesbernatchez is offline
  #14690
murky123's Avatar
so tuning a 2way slipper means messing with different pads. what a pain.
murky123 is offline
Old 12-10-2013, 03:31 PM
  #14691
R/C Tech Elite Member
Trader Rating: 520 (100%+)
IDK, no more than using different diff oils, shock springs, shock limiters, different weight shock oils, tires, closed or open cell foams, droop screws, added weights, etc..IMO its will be a nice tuning fork to more define the car to your liking..or you can lock it down and it will be like the std center gear..
flame56mx is offline
Old 12-10-2013, 03:55 PM
  #14692
It is a quick drop in and out too so trying different pads or just testing the straight v3 slipper would be easy to do.
Old 12-10-2013, 05:04 PM
  #14693
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
I have some New spares. If you need some for the time being, I can help you out. Plus I'm in Ct. as well....PM if interested!
Bman's 3XNT is offline
Old 12-10-2013, 06:51 PM
  #14694
I agree, cant see it taking very long to find the set-up I will like..I think a tire punch might make a good slipper pad hole making device...
Old 12-10-2013, 07:39 PM
  #14695
aray's Avatar
Default Hexes
Was there a final answer for a "proven" 12mm locking hex conversion, and which front wheels to use with it?
I searched and found a lot of discussion but couldn't tell what worked. Are the Avids the winner?
I picked up a used dex410r with the upgraded durango aluminum hexes but the pins fly out if you breathe on them wrong. Did the previous owner use the wrong size pins or is this normal?
Thanks!
aray is offline
Old 12-10-2013, 07:57 PM
  #14696
Thanks!
Um, no, the pins are more than likely correct. The Td alumi hexes don't have much for pin capturing built into them. I use a drop of CA to hold the pins on mine..I cant speak for the 12mm conversion, but someone will chime in shortly..
Old 12-11-2013, 02:45 PM
  #14697
fifi's Avatar
Thanks!
I use tresrey
http://www.tresrey-usa.com/tresrey-a...eel-hub-clamp/
fifi is offline
Old 12-11-2013, 04:51 PM
  #14698
Tried the prototype on another track tonight. I only ran one pack but the car felt good. I need alittle more rear drive so I am bumping the center up. Still very stable! I will report back......
Old 12-11-2013, 05:26 PM
  #14699
I got to check that center diff out one day. Seems interesting.
Old 12-11-2013, 10:45 PM
  #14700
Originally Posted by BlackedOutREVO
I have to admit. That is the coolest looking wheeler out! But electronics placement is nothing, doesnt look like a FASST RX would even fit.
You can fit a FASST in there, its super tight but it still fits some how haha. I put mine on its side on the outside where they put the transponder
lee111m is offline
