Like Tree22Likes
Old 08-31-2010, 10:12 AM
  #1456
Dlewis4's Avatar
Trader Rating: 148 (100%+)
Yes Grapejuice, it is a wrap.
Was able to put my order thru at Amain for my aluminum front hingepin holder. Came back in stock. Also ordered the pivot balls and the Carbon rear brace.
Now i just need the rest of the aluminum hinge pin holders to come back in stock!
Dlewis4 is offline
Old 08-31-2010, 02:48 PM
  #1457
Thumbs up Team Durango DEX410 Ceramic Bearing Kit
Yes we just released the Team Durango DEX410 Ceramic Bearing Kit. It will also fit the DEX410R. Only $89.99 with FREE worldwide shipping. Have you seen how this buggy jumps? Pretty amazing.
acerracing is offline
Old 08-31-2010, 03:25 PM
  #1458
Carlos69's Avatar
What grade Si3N4 ?, greased or oiled ? steel seals ?... will you put out a Ti screw kit as well ?
Carlos69 is offline
Old 08-31-2010, 08:01 PM
  #1459
dangerwr's Avatar
Since this is the closest thing to shameless advertising I have seen in a forum, I must ask is ACER truly based in L.A.? Is that why they have such easy access to out-of-work pornstars to pose for their ads? I like me a pornstar just like the next guy but geez.
Although, $90 is not bad for ceramic. I have never ran ceramic, you guys? What about the ACER products??
dangerwr is offline
Old 08-31-2010, 08:05 PM
  #1460
Dlewis4's Avatar
I ran ceramics in my Odonnell buggy, and there was adifference, especially in the hubs. I didnt run them for the diff's.
I paid $300 for a set of Boca Orange Seal (the best you can buy) and they were well worth it. I wouldnt mind trying the Acer's... just havent heard much about them.
Dlewis4 is offline
Old 08-31-2010, 08:10 PM
  #1461
Company Representative
JoeNolasco's Avatar
Ceramics are best used for engines and motors. On chassis the benefits are super minimal, except in touring car/pan car applications and even then you would need to remove the seals, blow the grease/oil out and then re-oil them with a super light oil every run....to notice any difference on track.
That being said, you certainly won't harm your car by using good ceramic bearings like the acer ones.
Acer is top notch, I use their diff balls in my onroad stuff all the time!
JoeNolasco is offline
Old 08-31-2010, 08:49 PM
  #1462
dangerwr's Avatar
Yeah, that is what I gathered from 8th scale off-road--mainly used in engines and the like. Thanks!
dangerwr is offline
Old 09-01-2010, 11:40 AM
  #1463
mdowney's Avatar
Trader Rating: 21 (100%+)
Originally Posted by t8rtot
...And that was on a revised part issue, there is already an upgraded part to fix the issue, hence no reason for them to replace them
What? That makes no sense. Durango builds a faulty part that effects a huge number of their customers (every review I've read broke the front outer brace the first day it was run on the track) and they don't need to replace it because they sell an aluminum part that actually works? How does that make sense to you.
I'm sure Durango will replace that part if you just ask them and explain what happened. It's overwhelmingly clear that this is their fault.
mdowney is offline
Old 09-01-2010, 12:23 PM
  #1464
rfleck's Avatar
Trader Rating: 58 (100%+)
I'm sure Durango will replace that part if you just ask them and explain what happened. It's overwhelmingly clear that this is their fault.[/QUOTE]
For score and 50 replacements later?
rfleck is offline
Old 09-01-2010, 12:27 PM
  #1465
Dlewis4's Avatar
If you placed a backorder at AMain... the aluminum front hinge pin braces are in.... get em while you can!
I will be running the car for the first time Friday... cannot wait!
Dlewis4 is offline
Old 09-01-2010, 01:05 PM
  #1466
mdowney's Avatar
I back-ordered the front outer and front inner but they only show the outer as being available. Did you get the inner as well? No big deal for me because the outer is the most important of the two, IMO.
mdowney is offline
Old 09-01-2010, 01:25 PM
  #1467
Dlewis4's Avatar
The inner is still on backorder
Going to get that, and the rear inner as soon as it also comes in. I want both!!!
Dlewis4 is offline
Old 09-01-2010, 01:34 PM
  #1468
bigBoyBigToy's Avatar
Trader Rating: 23 (100%+)
just banking on the outer to hold up imo wont work cuz every hit to the front messes with both...i would not just try to run the outer without the inner jmo
bigBoyBigToy is offline
Old 09-01-2010, 01:40 PM
  #1469
Dlewis4's Avatar
Well, everyone i have talked to said the outer is the MAIN upgrade. THe inner will be upgraded as soon as someone gets one in.
I also ordered a carbon rear brace. Stiffen it up just a little bit, and it looks dang good.
I am wondering... how/where is everyone running their steering servo leads...? Cant figure out a good place to run it through the steering rack.
Also, anyone running any fans for a motor or speedo?
Dlewis4 is offline
Old 09-01-2010, 02:29 PM
  #1470
grapejuice's Avatar
Trader Rating: 152 (100%+)
I think the inner will be okay because it only gets damaged when the out is broken....finally broke mine , but I clipped a small hole on the straight away wall at speed just right and it just ripped the whole right front off the car...lol (pieces of wood stuck on the wheel too).
The inner mount on mine just got a little wallowed out when the front broke and that whole side came off...just my 2 cents but I will still get the inner when they are available, I am hoping since amain got some outers that mine thats on back order with HRP will be showing up next order!!
Look at the picks of my car, not sure if you can see it but I went around the back of the servo to the left side (non servo saver side), then along the front of the servo to the reciever.
As for fans, you can really only fit one on the speedo, no room for one on the motor I think. I'm not running one right now because I blew my LRP fan up at the shootout and have not got another one yet, no over heating issues but the speedo does get warmer then usual.
grapejuice is offline
