Like Tree22Likes
Old 08-29-2010, 07:30 AM
  #1426
R/C Tech Elite Member
DavidR's Avatar
Trader Rating: 97 (100%+)
Originally Posted by Dlewis4
Not going to lie. This is one tough build. The plastic is harder to thread than the old Losi stifezel plastic
But wow. The fit and finish is second to none for an off road car. I am building with ti screws and the rubber boots for the shocks and axles.
So far my order list will be the aluminum hinge pin mounts, the carbon towers and the carbon rear brace. Then I think k will just drive this bad boy!!!
I will post pics tonight when the build is done!!!
Where did you find a Ti screw kit for the Durango?
I'd like to do the same when I build mine, but have yet to locate a kit.
Did you have to peice a kit together?
-David
DavidR is offline
Old 08-29-2010, 09:16 AM
  #1427
Dlewis4's Avatar
Trader Rating: 148 (100%+)
I have a whole box of Lunsford screws. No kit available to my knowledge
Dlewis4 is offline
Old 08-29-2010, 05:23 PM
  #1428
nta01's Avatar
Trader Rating: 19 (100%+)
What ESC/Motor combo are you guys running? I just built and raced with the R and can't make it beyond 8 minutes without it thermo-ing out. I am running a Novak GTB with a Novak Velocity 6.5. I also read on the review in XRC running a Tekin with a 7.5 average run time was 8 minutes. It's hard to finish a main when they are 10 minutes long. And yes, I reamed some holes and vents to get some air moving in there.
Thanks,
nta01 is offline
Old 08-29-2010, 05:45 PM
  #1429
mdowney's Avatar
Trader Rating: 21 (100%+)
Thanks,
LRP TC spec with X12 6.5T motor. Awesome combo. This car runs very hot when properly geared so the heatsink on the TC spec really helps. It is all a very tight fit though. Order the LRP 70mm sensor cable for your ESC.
And the front suspension braces break like they're made of butter. Buy the aluminum ones direct from Durango because you can't get them from the resellers. If not, order three or four plastic spares because you will be replacing them regularly.
mdowney is offline
Old 08-29-2010, 05:47 PM
  #1430
mdowney's Avatar
Originally Posted by Shirk
I think it was broken before I drove it....
Just for that little comment you owe me a replacement part!
mdowney is offline
Old 08-29-2010, 06:49 PM
  #1431
bigBoyBigToy's Avatar
Trader Rating: 23 (100%+)
Well all i can say is order the aluminum front braces or stock about 10 of the plastic ones with a full tree of shock caps yikes its like its made to break so easily lol what a joke i also lost 4 teeth in my rear ring and pinion lol grrr but the key to not doing that is make sure u shim or set the small pinion real good... Anyways i will work the demons out eventually
bigBoyBigToy is offline
Old 08-29-2010, 09:57 PM
  #1432
I hope you are joking...
Shirk is offline
Old 08-30-2010, 02:14 PM
  #1433
this is for everyone when doing the diff pinion with the 2 small bearing make sure you have no play foward and backwards if you look in the maual it has a X&OBY what your supposed to do if u just lay the bearings in the slot of the diff case then you will have problems stripping the ring gear trust me i know now and questioned it on the build but thought it was fine just laying the bearings in the slots but anyways just wanted to pass that on for new builders i flunked build 101.....
you will know when you hear real loud click click click click click lol
Old 08-30-2010, 02:57 PM
  #1434
rfleck's Avatar
Trader Rating: 58 (100%+)
You broke the shock caps too?
rfleck is offline
Old 08-30-2010, 04:02 PM
  #1435
grapejuice's Avatar
Trader Rating: 154 (100%+)
My DEX410R
Attached Thumbnails Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-durango-001.jpg   Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-durango-004.jpg   Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-durango-005.jpg   Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-durango-006.jpg
grapejuice is offline
Old 08-30-2010, 04:20 PM
  #1436
Dlewis4's Avatar
Will post pictures tonight. Had some steering servo issues and lost a servo, so had to get a new BLS451 today. Will mount up my Tekin and my motor tonight, and shoot some pics
Current setup is 35 losi oil ft, 30 in back, stock springs, stock positions, going to try it and play with it. I picked up a full spring kit front and rear, so i can play with them.
Also ran 15k in front, 5k in rear. Running J Concepts barcodes in blue frt and rear.
Dlewis4 is offline
Old 08-30-2010, 04:24 PM
  #1437
Dlewis4's Avatar
IS anyone running a fan on their motor? Wondering if there is room enough for one or if i should just place it next to the ESC and let it blow across the posts...
Dlewis4 is offline
Old 08-30-2010, 06:00 PM
  #1438
When u break the front toe brace it sometimes pulls the shock cap right off stripping the threads
Old 08-30-2010, 06:06 PM
  #1439
mdowney's Avatar
Default A Main fulfilled my aluminum front outer brace order
I've had the front aluminum braces on back order at A Main Hobbies for a few months and the front outer (the most important one) just got fulfilled. Still shows back order on their site but they may just be holding back until they fulfill all the back orders.
You may want to place your own on back order because they reserve it for you but don't force you to buy it and don't charge any money for the back order.
mdowney is offline
  #1440
savageboy69's Avatar
Trader Rating: 93 (100%+)
does anyone happen to have the aluminum suspension mounts, both pieces? tired of breaking plastic ones and pissed at the $30 shipping durango has. just thought id check to see maybe if someone had extras lol that they may not mind parting with
savageboy69 is offline
