Like Tree22Likes
Old 10-26-2013, 08:58 AM
  #14131
Konich's Avatar
I would find Lutz's setup from the worlds and start there. His car looked pretty dialed
Konich is offline
Old 10-26-2013, 09:00 AM
  #14132
Konich's Avatar
Originally Posted by tobamiester
+1 with that. Jorn just killed it at EOS with his v3 with small bores.
Small bores and back to the current chassis from what I can tell.
Konich is offline
Old 10-26-2013, 09:03 AM
  #14133
the incubus's Avatar
Trader Rating: 17 (100%+)
I ran Small bores for a while and the car took a bit of a pounding. the BB really calmed it down and made it smoother overall. With the small bores it felt jittery in certain areas.
the incubus is offline
Old 10-26-2013, 09:05 AM
  #14134
Konich's Avatar
^^What surface where you running on? I have a set of small bores but would only run them on carpet or high bite clay with small jumps.
Konich is offline
Old 10-26-2013, 09:08 AM
  #14135
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Originally Posted by Konich
Why in the world would you want to replicate the "Worlds" chassis when it bombed?
Lutz didn't seem to have much trouble with the V3 he was running? The car in its current configuration has done well for the past 3+ years
To be different and try something new. I am working on something right now. Taking a little longer than I expected though....... Dude Lutz is a sick driver, he loves his cars on edge. I and many others may like a little more planted feel. Don't get me wrong I love this car, but I am looking to make it even better.....
I would some this up to the level of grip at the EOS tracks.
Bman's 3XNT is offline
Old 10-26-2013, 09:14 AM
  #14136
Konich's Avatar
^^Give it a shot and let us know how it works. I'm too lazy to try stuff
Hell I've had my same setup for 3 years! lol
Konich is offline
Old 10-26-2013, 02:20 PM
  #14137
jmackani's Avatar
Trader Rating: 14 (100%+)
Originally Posted by rcjunky1
I saw some of those parts on the durango site and they showed in stock, now tower shows late december Doesn't look like much is new and Dino has pointed out, under $50 plus the new drive shafts and arms, still far from the $200 difference there will be between the v3 and v4, so hopefully no one was waiting the new kit out
The durango website stock levels are representing overseas distributors. They are not U.S. levels and tower's website is probably accurate until they come via a cargo ship. I recall they switched to mode of transportation some time ago.
jmackani is offline
Old 10-26-2013, 09:48 PM
  #14138
I'm mrunning on a large 1/10 outdoor red Florida "clay" track. A bit clay mixed with abrasive sand. We have considerable jumps in a few spots and plenty of elevation changes.
Small bores were decent for that environment but the BB really settled the car down nicely. SB are going on my 25 year old Andy's kit for our new dirt oval! Lol
Old 10-27-2013, 11:34 AM
  #14139
Trader Rating: 54 (100%+)
Is there some secret to threading the spring adjustment nut on to the shock bodies?
Does anybody make a better shock than the junk that comes with an otherwise perfect kit?
Let me guess, Kyosho shocks.
w_dupree is offline
Old 10-27-2013, 12:03 PM
  #14140
Or maybe its just you..
The Durango SB and BB shocks with Tamiya blye x-rings are the smoothest dampers I have ever tried. Had to go up 5-7.5wt after the rebuild because of the Tamiya rings
ridgeracer is offline
Old 10-27-2013, 12:09 PM
  #14141
Trader Rating: 38 (100%+)
Just got my 4wd Durango. any good setup hints for indoor carpet? I'm going to run Schumy mini pins.
vw addict is offline
Old 10-27-2013, 01:17 PM
  #14142
Ridge,
Can you offer a link to which Tamiya xrings? I have seen 50 and 70 durometer ones. I also read something about having to use mineral based shock oil(?) I use Losi. Do you know if it will work OK with the Tamiya rings?
Thanks.
Mark
mlinder is offline
Old 10-27-2013, 02:19 PM
  #14143
Originally Posted by mlinder
Ridge,
Thanks.
Mark
Hi Mark,
Item number 42214, 50-durometer are the ones you want. The 70-durometer is for mineral oil only. I use Losi oil also and no problems after 2 months.
Owe
Old 10-27-2013, 03:05 PM
  #14144
R/C Tech Elite Member
thecman26's Avatar
Trader Rating: 112 (100%+)
I had a PITA time getting mine on, I ended up running a razor knife over the threads on the nut, nothing else helped. I tried black grease, diff lube and nothing helped. The threads are awful. I want to get some alumionum collars soon as I jacked the plastic collars up pretty bad. IMHO the shocks otherwise are pretty smooth... I mean not as nice as Kyosho velvets but those are amazing shocks! TLR and AE big bores are pretty good also!
thecman26 is offline
Old 10-27-2013, 04:05 PM
  #14145
Hi Mark,
Owe
Thanks Ridge!
Mark
mlinder is offline
