Like Tree22Likes
Old 10-14-2013, 03:05 PM
  #14026
Trader Rating: 165 (100%+)
Originally Posted by flame56mx
Hey Chris, the gold 3mm locknuts I found once from ofna.
Thanks!
What about those gold spacers on the steering link?
Chris Gierse is offline
Old 10-14-2013, 03:06 PM
  #14027
the incubus's Avatar
Trader Rating: 17 (100%+)
Originally Posted by Jamison R
Lunsford ballcups, tie rods and ball studs. Car is tough as nails then. I run the xb4 now but kinda wish I had my 410 back. Not that I don't like the xb4 its that I do like the 410. If that makes sense.
I knows what you mean! LOL
I've had my eye on an XB4 and the new HB413 but I don't want to sell my 410 without running one of those other 2 for a bit. Would hate to lose so much on my 410 and then have to go back out of pocket for one of the others to then lose more to buy another 410 if I find I don't like those others as much as my 410.
Dilemmas, dilemmas. LOL
the incubus is offline
Old 10-14-2013, 03:27 PM
  #14028
ekt
ekt's Avatar
Originally Posted by Chris Gierse
Can anyone give me the part number for the spacers used on the servo link in this picture? Also, does anyone have a part number for the gold lock nuts on this car?
Hi Chris, that is my car. The nuts I used http://www.amainhobbies.com/product_...k-Nuts-Gold-10 and the spacers http://www.amainhobbies.com/product_...Shim-Orange-10
ekt is offline
Old 10-14-2013, 04:28 PM
  #14029
Originally Posted by ekt
Thanks! The car looks great.
Old 10-14-2013, 06:55 PM
  #14030
13Maschine's Avatar
Love the XB4!! Seriously considered it before I picked up the DEX410v3. The 199 price tag is really what sealed the deal for me....also the fact that already have a DEX210 that I love.
Hot Bodies looks awesome too.
I haven't finished my build and I haven't driven mine yet so I'll hold back on my comments for now!
13Maschine is offline
Old 10-15-2013, 07:48 AM
  #14031
I see on a lot of the setup sheets guys are using 2, 3 and 4 hole pistons. Are these Avid pistons? What seems to be the best piston to use in the front and rear shocks?
Old 10-15-2013, 10:11 AM
  #14032
Tdiddy's Avatar
[QUOTE=the incubus;12630994]pferris,
I run the ones from the R version and they don't pop off at all and I've taken some nasty tumbles and even snapped an arm and the cups held strong. If you can't locate those I'd strongly recommend you go with the TLR ones as they are among the most precise fitting cups I've ever used. So much so I replaced all the stock ones and RPM ones on my 4.2 to TLR cups and balls all around and it removed all the annoying slop and no more popping off.[/QUOTE
TLR ball cups and ball studs are really nice. Another good option from TLR is the titanium ball studs. They aren't that expensive.
Tdiddy is offline
Old 10-15-2013, 10:37 AM
  #14033
Originally Posted by Tdiddy
pferris,
umm... $60 for 12 ball studs that's maybe 5-10g lighter, and not any stronger? regular ones are good enough.
Personally I don't like TLR ball cups, they are good when they are new, last about 1-2months, then all kinds of sloop. Good price, works, but quality/durability-wise there's better.
nicholasxuu is offline
Old 10-15-2013, 03:13 PM
  #14034
R/C Tech Elite Member
Trader Rating: 520 (100%+)
There are a few different options, Durango sells a "spec b" shock piston set, and the also have some tapered pistons that are a little more $. I use 2 hole 1.6 up front, and 2 hole 1.7 in the rear, 35w losi oil for both.
flame56mx is offline
Old 10-15-2013, 03:26 PM
  #14035
Cameron Kellogg's Avatar
Trader Rating: 45 (100%+)
I really have been liking Lutz recent setup using 2x1.6 in the front and 3x1.5 in the rear. A little thicker front shock oil but but drives and jumps the big and little stuff great.
Cameron Kellogg is offline
Old 10-15-2013, 03:30 PM
  #14036
ekt
ekt's Avatar
The 2, 3 or 4 hole setups are just regular pistons with some holes sealed or drilled blanks. TD have release a type b piston set that has some of the more popular piston sizes, if you don't want to got to the effort of drilling/sealing http://www3.towerhobbies.com/cgi-bin...?&I=LXDNVK&P=7. For a list of other piston options available, check out my site http://durangofansite.com/main.php?v...shocks-pistons
ekt is offline
Old 10-15-2013, 03:34 PM
  #14037
I'd recommend you to get to this page:
http://www.petitrc.com/setup/durango...oDEX410v3.html
then find the surface close to your local track,
then try to find videos of that particular race, check the surface condition and jump sizes/types (i.e. big jump with flat landing, big jump with smooth downhill landing, small jumps, etc...).
find the closest one and try as a base setup.
if there are several choices, choose the latest one.
merge in some of your own understanding (i.e. personal favor of general diff setup), and you'd probably end up with some adjustments as well (i.e. my local track has a sweeper with some bumps, thinner rear shock oil helps the rear to hold better).
personally I ended up with 1.6x2 losi 45wt front & 1.6x3 losi 30wt rear. drilled my own piston with a drill bit.
Old 10-15-2013, 05:51 PM
  #14038
8ight-e's Avatar
Trader Rating: 58 (100%+)
1/16(edit) bits are what 1.5 if you drill your own? At any rate from the kits and things I've bought in my box I have 1.2, 1.3, 1.4 6hole and from there I use some small zip ties and my soldering iron to melt the holes closed to make what I want. With the buggy 1.4 x4 is nice front and rear then just dial in your thickness to fit track features. Great pack, just a nice feel. I did try the other setups and didn't like them as much. With the desc410 the 1.2x4 all around is awesome, honestly with the desc210 I love my 1.2x6 all the way around and just run my oils a little thick at 45/40.
8ight-e is offline
Old 10-15-2013, 07:50 PM
  #14039
Originally Posted by 8ight-e
1/8 bits are what 1.5 if you drill your own? At any rate from the kits and things I've bought in my box I have 1.2, 1.3, 1.4 6hole and from there I use some small zip ties and my soldering iron to melt the holes closed to make what I want. With the buggy 1.4 x4 is nice front and rear then just dial in your thickness to fit track features. Great pack, just a nice feel. I did try the other setups and didn't like them as much. With the desc410 the 1.2x4 all around is awesome, honestly with the desc210 I love my 1.2x6 all the way around and just run my oils a little thick at 45/40.
Actually 1/16 is 1.59mm on the chart I have..
Old 10-15-2013, 08:05 PM
  #14040
Idk what you're doing but I have never had TLR cups develop slop. The shitty sliderack, now that POS develops slop in no time and requires constant replacement.
