Like Tree22Likes
Old 10-10-2013, 08:43 AM
  #13966
Trader Rating: 40 (98%+)
Thanks guys, I tired a thick shim on bottom and thin on top and I still had slop.
Ruger357 is offline
Old 10-10-2013, 08:50 AM
  #13967
the incubus's Avatar
Trader Rating: 17 (100%+)
You have to use the proper sized ones. I believe it's 1mm up top and 2mm down below but this is with the 21░ blocks. The Plastic Caster Blocks require a little more shimming.
the incubus is offline
Old 10-10-2013, 09:37 AM
  #13968
Oh, really great, I really wish I had their own cars cars~!!
ipcamera is offline
Old 10-10-2013, 09:42 AM
  #13969
is the hitec 985MG a good servo for the DEX410? if not what's a good budget Hitec for it?
cripplethreat is offline
Old 10-10-2013, 10:28 AM
  #13970
rifleman223's Avatar
Are you hell bent on Hitec? If not, the ProTek 130SS is very good. Also the Savox SC-1257TG. Word of caution on these because they draw more power you might need a BEC if the speed control does not give enough power.
rifleman223 is offline
Old 10-10-2013, 10:29 AM
  #13971
If you mean Tresrey, I'd reckon they'd make a good carů but all the parts would be RED. LOL
I'm going to wait and see how all the new cars perform over a few months to see what's the next kit I buy. If the Durango is still one of the top cars I'll likely buy the V4 and if Tresrey makes components for it I'll likely buy them and have them custom anodized to the color I like.
I just wish companies offered a variety of color choices on aluminum parts so you can make your car unique.
Old 10-10-2013, 11:00 AM
  #13972
tobamiester's Avatar
Trader Rating: 360 (100%+)
985MG is a good budget servo, plenty of torque and decent speed.
7965 is also a good one, about the same price and digital. 139oz/.10secs.
tobamiester is offline
Old 10-10-2013, 03:25 PM
  #13973
Originally Posted by the incubus
Carbon fiber is inherently way stronger than Plastic so long as it is cured properly to exacting tolerances in an autoclave. This is why it is the premier material used to construct monocoques for F1, LMP, and many other types of race cars. It's tensile strength to weight is virtually unparalleled by anything else known to man and its rigidity and strength can be controlled depending on the type of weave chosen as well as how it's laid down before mating with resin.
While what you say is true, one aspect that isn't considered is impact resistance. This is one area where carbon composites come up short, no matter what manufacturing method is chosen.
compengr is offline
Old 10-10-2013, 03:32 PM
  #13974
ekt
ekt's Avatar
TD are starting to do that Several parts in their 10th range are available in Red, Olive, Black and Gold.
Originally Posted by Ruger357
So, working on installing the 21* caster blocks, do they require different plastic shims between the hub and the block? The plastic block required 1 thin shim. It looks like I will need a think shim on both sides. Is there a preferred method of shimming these?
8x3x1mm and 8x3x2mm spacers are what you are looking for, here's a list of available spacers http://durangofansite.com/main.php?v...#bling-spacers
ekt is offline
Old 10-10-2013, 04:45 PM
  #13975
Whats a good budget esc thats small enough to fit with an airtronics 92524 micro receiver? I just got this buggy and cant seem to get my old lrp sphere and receiver in there
JoshC90 is offline
  #13976
13Maschine's Avatar
Default 12mm Hubs
Originally Posted by MikeFriery
i run JC mono 22 wheels with TLR hexes in the rear and XXX-4 front wheels. Fischer did too when he was still running Durango. Perfect fit.
Thanks for posting this. If you don't mind posting some pics? are you using spacers?
Also just for clarification are you using these TLR 22 12mm clamping hexes?
http://www.amainhobbies.com/product_...d-Width-TLR-22
Same on front and rear? I noticed they have a couple of different offsets as well.
I picked up the AVID B4.1/B44.1:
http://www.amainhobbies.com/product_...-Wheel-Hex-Set
hexes and they seem to fit the rear and give me two width options, however they don't seem to work in the front. I've attached a few pics of the AVID hexes...
Any help is much appreciated. Thanks!!
Attached Thumbnails Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-img_1997.jpg   Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-img_1998.jpg   Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-img_1993.jpg   Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-img_1995.jpg   Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-img_1996.jpg
13Maschine is offline
Old 10-10-2013, 04:51 PM
  #13977
13Maschine's Avatar
Originally Posted by symmetricon
A standard 3mm socket head cap screw. I have never had any issue with the motor moving....:-)
Thank you!!, this seems to work although I'm still trying to figure out which 12mm clamping hubs will work with my JConcepts Inverse rims. I'm running these on my DEX210 so I want to try and keep the rim standard for the rear.
I've tried the avid 12mm clamping set for the B4.1/B44.1 and I used some spacers to make it work. The set of four gives you two width options but I'm still looking for a proper solution in the front. Any ideas you have are welcome? Please post links...and pictures if possible.
Thanks!
Old 10-10-2013, 05:47 PM
  #13978
losi hex has 5mm internal diameter. durango shaft is about 4.7mm thick, there's some play there and it's not idea.
I'm using JConcept B4.2 front hex for the rear, added 2.3mm spacer between the hex and the bearing. (actually 2.25mm is the best, but hard to make).
curious if anyone has tried to use sc10 front hex. it looks a bit thicker than B4 hex.
nicholasxuu is offline
Old 10-10-2013, 05:54 PM
  #13979
8ight-e's Avatar
Trader Rating: 58 (100%+)
hitec 985mg are awesome servo's; by choice I run them over most of the newer digitals...
That said bar none the spectrum 6040 is easily the best 1/10 servo out there.. PERIOD
8ight-e is offline
Old 10-10-2013, 06:42 PM
  #13980
Anyone got a good suggestion for a small esc besides tekin rs or lrp flow? Looking for something on the cheaper side. Dont think any of hobbywings are small enough with good amperage
JoshC90 is offline
