Like Tree22Likes
Old 09-30-2013, 08:37 PM
  #13816
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by rcjunky1
The link says its an R, but it has alloy pivot blocks, c hubs, carbon towers and BB shocks, so I think its a full fat kit with all the exotek bits for $100 more, not a bad deal.
Originally Posted by jmackani
Take note that is an r version.
Sorry for the confusion- copy pasted from Tower. It is in fact the DEX410v3, NOT the R.
MikeR is offline
Old 10-01-2013, 08:32 AM
  #13817
rcgod's Avatar
Trader Rating: 33 (100%+)
What does that car have that the non r version has except the front uprights? Just ordered a 410v3 from amain for $199 and new to this car. Not sure if I should pick that car up or wait for my new kit. Thanks.
rcgod is offline
Old 10-01-2013, 11:17 AM
  #13818
rcjunky1's Avatar
everything yellow/orange is an optional part, if you like upgrades it will save you a lot of cash
rcjunky1 is offline
Old 10-01-2013, 01:22 PM
  #13819
rcgod's Avatar
Cool thanks for the info.
rcgod is offline
Old 10-01-2013, 03:10 PM
  #13820
13Maschine's Avatar
Default Clamping 12mm hubs
Originally Posted by woodsy144
is it the "JConcepts Rear Hex Adaptor 12mm B4.1/B44.1 Blue" that fit, cause there are a few of varients
Has anyone tried these for all four wheels?
http://www.amainhobbies.com/product_...-Wheel-Hex-Set
13Maschine is offline
Old 10-01-2013, 04:16 PM
  #13821
tksnobords's Avatar
Trader Rating: 36 (100%+)
why would you want smaller hexes? isn't the dex410 15mm?
sorry i'm brand new to this truck
tksnobords is offline
Old 10-01-2013, 04:33 PM
  #13822
13Maschine's Avatar
I like to use the 12mm hubs so I can use more common wheels like the Jconcepts inverse or regular TLR or B4 rims. The J Concepts inverse is the best rim out on the market in my opinion. It's a two piece rim thus has no exposed ribs to catch mud which means your tires are balanced at the end of the race same as when you put the car down.
PS, perhaps your in the wrong forum if you are looking for truck info. This is the 4WD buggy forum. No worries, just wanted you to know.
Cheers!
Dave
Old 10-01-2013, 04:34 PM
  #13823
13Maschine's Avatar
Justin case you are REALLY curious:
http://www.amainhobbies.com/product_...l-White-4-B441
Old 10-01-2013, 04:42 PM
  #13824
Trader Rating: 19 (100%+)
Cheers!
Dave
It would be nice to have a 12mm option, but I am not as keen on the inverse wheel compared to one-piece wheels. They are heavier and not as "true" as one-piece. If you race in wet or muddy conditions then you have a very good point!
travymoto11 is offline
Old 10-01-2013, 05:11 PM
  #13825
13Maschine's Avatar
Originally Posted by carrotcake
As many mentioned, there are deals going on for the DEX410 V3. Even though I've got 6 Kits sitting on the shelve still to be built (i.e. T4.2, Axial Exo Terra, DEX210, SC10 4X4 FT, 3Racing F113, Tamiya F104WGP)...I still bite the bullet and bought it, just couldn't resist the price. Don't really care about the V4 I am sure it would be expensive and V3 looks decent enough (at least in terms of the quality parts you get).
Any suggestions on Upgrades? This kit doesn't seem to need a whole lot of upgrades, I just bought alum. wheel hex all around, Gold shock pre loads (looks like the aftermarket shock upgrades for DEX210 also fits DEX410v3). Bought SP Reventon Pro with 5.5R MMM motor. Running 3PM radio and Savox 1256TG High Torque servo.
Thanks.
Rob
Hey Rob, what kind of hexes did you pick up? I was thinking that these might work for 12mm setups:
Thanks!
Old 10-01-2013, 07:16 PM
  #13826
carrotcake's Avatar
Thanks!
IMO I don't think these Avid 12mm Hexes will fit (I never tried though). But if someone already tried and works I guess I'm wrong.
I bought these (14mm):
Front - http://www.amainhobbies.com/product_...heel-Hex-Set-2
Rear - http://www.amainhobbies.com/product_...heel-Hex-Set-2
carrotcake is offline
Old 10-01-2013, 07:42 PM
  #13827
any suggestions for more on power steering with the 410?
TLRrunner is offline
Old 10-01-2013, 07:46 PM
  #13828
Pittster's Avatar
Question on the 410V3 in regards to pistons.
I have a track that has largish jumps outdoor dirt blown off can be grippy and has sugar in the corners.
I ran my DEX210 with the stock 6 hole 1.2-1.3 piston with 30wt F 25wt R and it was slapping the chassis everywhere didn't land nicely off the jumps either, I now run a 4x 1.3mm piston front and rear with the same wieghts and it feels excellent, alot of the TLR22 guys run the same pistons.
Now with the 410 I got it second hand and it had 6x 1.3mm F and 6x 1.2mm Rear.
I have put 35wt F and 30wt R, now being new to 4wd I am going to have to learn how to set these up a bit differently.
the shocks have very little pack with these pistons and even dropping from 6 inch's it chassis slaps the ground.
Now others guys that run in the 4wd class chassis slap nearly every jump is this a norma thing with 4wd buggy?
Question is what are common piston and weights uses in 4wd ?? Going off all the setup sheets on PetitRC its either 6 hole 1.2-1.3 or 2 hole 1.5-1.7.
Last bit of info this is for Stock 17.5 motor class
Pittster is offline
Old 10-01-2013, 07:47 PM
  #13829
R/C Tech Elite Member
Trader Rating: 520 (100%+)
Hmm, I have never had this issue before. Usually have to dial out steering with my cars. What are running for tires?
flame56mx is offline
Old 10-01-2013, 08:22 PM
  #13830
EvanAZ's Avatar
Trader Rating: 99 (100%+)
I put 4 hole 1.3 all around in mine and run 35F/30R oils and the front feels good, but the rear has too much pack. Gonna try 6x1.3 - 30wt for the rear tomorrow to see how it feels. I do slap if I over shoot the jumps but if I downside it no problems.
EvanAZ is offline
