Like Tree22Likes
Old 08-25-2010, 03:08 PM
  #1366
dangerwr's Avatar
Apparently, the 87T spur is the only option right now? I plan to run a 6.5 motor so, according to the gearing chart, I need to run a 21T pinion. Says ideal FDR is 10:1.
dangerwr is offline
Old 08-25-2010, 03:09 PM
  #1367
Is it possible to run ae or losi pistons in the rango???
Shirk is offline
Old 08-25-2010, 03:12 PM
  #1368
dangerwr's Avatar
I plan to suit up some Losi #55 pistons and see how they work--used them in both my B4 & T4 and are buttery smooth. I need to measure the diameters so I do not know the answer just yet . . .
dangerwr is offline
Old 08-25-2010, 03:16 PM
  #1369
Let us know, because I'm looking to get a rango and this would help with my decision..
Shirk is offline
Old 08-25-2010, 03:19 PM
  #1370
dangerwr's Avatar
Will do! Grapejuice might actually know. I will likely get it figured out tonight . . .
dangerwr is offline
Old 08-25-2010, 03:21 PM
  #1371
Team Tekin
Randy_Pike's Avatar
Guys you can always make your own 55's. Ca glue the old holes shut and drill new ones.
I'm running a 6.5 in my 410 and fell a 19 tooth for most indoor tracks is ideal. Tekin Redline 6.5 with a 12.5 Hi torq rotor.
Randy_Pike is offline
Old 08-25-2010, 03:22 PM
  #1372
tonyv2382's Avatar
Trader Rating: 67 (100%+)
Ya the comeseethis site is pretty good...but I also think gearing is relative tot he track. "Ideal" may not be ideal for every track size. but according to the site 21-22 should hit the spot...as for me the 20 was running crazy hot. Ill try 22 first
tonyv2382 is offline
Old 08-25-2010, 03:25 PM
  #1373
dangerwr's Avatar
Thanks for the heads up! I was originally thinking 19 or 20T pinion on the 6.5 motor. What company makes bland pistions you can drill? I know Losi has them for 8th scale stuff . . .
dangerwr is offline
  #1374
Why do that when you could just throw in a piston, its less work than ca'ing and drilling...
Shirk is offline
Old 08-25-2010, 03:29 PM
  #1375
dangerwr's Avatar
I am with you! I will stop by the track tonight and get some Losi pistons to see if they fit correctly. They make another size for 10mm shocks too . . .
http://www.amainhobbies.com/advanced...osi+55+pistons
dangerwr is offline
Old 08-25-2010, 03:32 PM
  #1376
Are the 10mm's for smaller shocks or bigger???
Shirk is offline
Old 08-25-2010, 03:37 PM
  #1377
dangerwr's Avatar
I have no earthly idea! Looks like on-road? I will try and find out tonight . . .
dangerwr is offline
Old 08-25-2010, 04:28 PM
  #1378
tonyv2382's Avatar
Its gonna run way too hot with those pinions. Trust me Ive tried the 20 and it wasnt right.
Old 08-25-2010, 04:30 PM
  #1379
dangerwr's Avatar
So bigger? 23t or something??
dangerwr is offline
Old 08-25-2010, 06:13 PM
  #1380
Team Tekin
Randy_Pike's Avatar
Smaller...
