Like Tree22Likes
Old 09-29-2013, 06:48 AM
  #13771
symmetricon's Avatar
Trader Rating: 27 (100%+)
Originally Posted by rifleman223
Where do you get these pins from?
Google mcmaster-carr, the sell drill blacks and pin gauges that can be used in place of the stock thing pin........I have been using tool steel drill blanks since day one and have only bent 1 pin in 9 months.......
symmetricon is offline
Old 09-29-2013, 10:26 AM
  #13772
huzzler's Avatar
What size blank do you use?
huzzler is offline
Old 09-29-2013, 11:54 AM
  #13773
buy the longer than u need and cut them.......
Old 09-29-2013, 01:43 PM
  #13774
RC10Nick's Avatar
I'm having an issue assembling the v3 I just bought and I'd like some help. I'm currently on page 17, the center drive shafts. The bevel gear, 310005, does not go far enough into the driveshaft input, 310116. This prevents the setscrew from threading into the driveshaft input far enough to be able to spin inside the diff case. Has anyone else had this issue?
RC10Nick is offline
Old 09-29-2013, 02:05 PM
  #13775
is it not long enough or is it binding/catching?
Old 09-29-2013, 02:26 PM
  #13776
RC10Nick's Avatar
depends on which "it" you are talking about.
It seems like the shaft on the bevel gear is too long, or the input shaft is not deep enough. The problem is not the setscrew, the problem is the mating between the bevel gear shaft and the shaft input.
*Edit*
I tried hammering the bevel gear into the shaft. I got them to mate properly, but ended up bending the part of the input shaft that mates into the CVD. This really sucks. Time to email TD.
RC10Nick is offline
Old 09-29-2013, 03:01 PM
  #13777
huzzler's Avatar
Yeah I get that, I was talking about diameter.
huzzler is offline
Old 09-29-2013, 03:04 PM
  #13778
Woulvesbaine's Avatar
If you look around you can find a complete Lunsford 410 pin set for under $20.00.
Woulvesbaine is offline
Old 09-29-2013, 07:20 PM
  #13779
13Maschine's Avatar
Seems like the the motor mount could be a potential issue and I'm looking for better mounting screws. I usually use lunsford titanium screws but they don't fit in this case.
Has anyone tried these?
http://www.tsrproducts.com/index.php...s270003rd.html
Thanks! I'll post pics soon...
13Maschine is offline
Old 09-29-2013, 07:32 PM
  #13780
i doubt the slots for the motor mount screws are big enough for the red aluminum bits...
Old 09-29-2013, 07:35 PM
  #13781
the inner hing pins are 3mm and the inners are 2.5mm
Old 09-29-2013, 07:52 PM
  #13782
the incubus's Avatar
Trader Rating: 17 (100%+)
Originally Posted by lil_man72
i've got the jconcepts finnisher being painted right now, but i also think the pro-line bulldog body would be a good choice.
Having a jconcepts body currently, I'd suggest either the proline of Kuhler body. There's also the bugleboy body which is also nice but you have to google it. It's posted in here a Few pages back.
the incubus is offline
Old 09-30-2013, 05:02 AM
  #13783
The mains were great yesterday,it was great to see 3 410s in the A-main. Just a little disappointing to see Jorn fall apart like that after taking everyone to school during quals.
TLRrunner is offline
Old 09-30-2013, 05:14 AM
  #13784
Agreed. It shows the car is every bit as good as anything else out there. Jorn also showed the cars durability lol. The car is not nearly as fragile as some make it sound like....
Old 09-30-2013, 05:26 AM
  #13785
agreed symmetricon, I'd say the current is just as good as everything else out there but the prototype might be on another level. I can be a bit of a rough driver and I've personally beat the ever loving crap out of my car and to date only broke 2 parts.
