Like Tree22Likes
Old 08-25-2010, 09:12 AM
  #1351
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
Has anybody had an issue with leaks between the ring gear and case? I thought the leaks were more commonly associated with the x-ring/outdrive areas.
t0p_sh0tta is offline
Old 08-25-2010, 09:35 AM
  #1352
bigBoyBigToy's Avatar
Trader Rating: 23 (100%+)
Originally Posted by dangerwr
I am wondering why Durango did not use gaskets in the diffs. Seems like a no brainer to me but maybe I am missing something . . .
good question!! so far no leaks here tho!!
bigBoyBigToy is offline
Old 08-25-2010, 10:09 AM
  #1353
rfleck's Avatar
Trader Rating: 58 (100%+)
Have had leaks with the xring, but not the area between the ring gear and case. I saw waaaayyy back in the thread a guy said he stopped his leaks by using kyosho orings so going to give them a try.
rfleck is offline
Old 08-25-2010, 12:04 PM
  #1354
Andy p's Avatar
[QUOTE=ambo;7850489]Hey guys, a little help here...I'm running a TekinRSPro with a 5.5 BL motor and using a 16T pinion on stock spur gear. My motor temps at 120+deg F but my ESC is at 155+degF. Could you guide me what's the best baseline set-up for the ESC? Many thanks. [/QUOTE
i ran randys 6.5 (208 software) set up with my 5.5, std timing with 21 pinion outdoors on a medium grass/astro track with no problem not sure on temps but it was showing 3 lights on the esc for temp
Andy p is offline
Old 08-25-2010, 12:13 PM
  #1355
dangerwr's Avatar
Interesting! I will wait and see if I have any issues before changing anything. I have some of the Kyosho o-rings laying around since I used to run the Inferno spur on my Losi. The o-rings provided with my kit looked pretty serious! Like a split-groove design and fit VERY well. We shall see . . .
dangerwr is offline
Old 08-25-2010, 12:21 PM
  #1356
grapejuice's Avatar
Trader Rating: 151 (100%+)
My diffs have not leaked, just followed what TD has posted on their web site, just used plenty of green slime!!
grapejuice is offline
Old 08-25-2010, 12:30 PM
  #1357
dangerwr's Avatar
I forgot about that little "How-to" they had posted. Should have that page up as well as the Oople article when building. Well, looks like I will have one built per kit instructions and one using Green Slime!
dangerwr is offline
Old 08-25-2010, 01:56 PM
  #1358
tonyv2382's Avatar
Trader Rating: 67 (100%+)
Originally Posted by MaTt 93
I think 23t pinion might be a bit much for a 5.5T. Im running a speed passion v3 5.5t and a lrp sxx tc and i'v got a 18t pinion with the std spur and it comes of just about perfect. Im not sure if its different with the tekin speedy though
Yes for a 5.5 it would be a bit much...Im runnin randys 6,5 setup and its dope. But with a 20t pinion this thing was on fire! My Motor was at 140 and esc was real hot to the point that one of the battery wires unsoldered itself. I was told by a team driver at the track to go up a few teeth which is why I recommended 23 I didnt notice that he was runnin a 5,5. Im still not sure what to do my self but I will go up and see what that does first. I think the motor is struggling a bit too hard with that small pinion.
tonyv2382 is offline
Old 08-25-2010, 02:05 PM
  #1359
What is the stock spur for the rango???
Shirk is offline
Old 08-25-2010, 02:16 PM
  #1360
t0p_sh0tta's Avatar
87 teeth
Old 08-25-2010, 02:21 PM
  #1361
If you guys need help gearing the rango visit www.comeseethis.com its a good site to see what gearing you should be at...
Shirk is offline
Old 08-25-2010, 02:22 PM
  #1362
Dlewis4's Avatar
Trader Rating: 148 (100%+)
Can you add Tekin to the site too?
Dlewis4 is offline
Old 08-25-2010, 02:26 PM
  #1363
That would be nice... I think the site creator needs to add tekin because a lot of people run tekin motors and speedo's
Shirk is offline
Old 08-25-2010, 02:27 PM
  #1364
Dlewis4's Avatar
Oh, i thought it was yours.
Thats cool tho. Thanks for the website!
Dlewis4 is offline
Old 08-25-2010, 02:34 PM
  #1365
Yeah no problem, just trying to help some fellow racers out...
Shirk is offline
