Like Tree22Likes
Old 09-12-2013, 12:48 PM
  #13561
Originally Posted by huzzler
I don't see how battery jumper wire will make motor run hotter. Maybe esc but not motor.
your guess is as good as mine. I'm gonna see what the temps look like when I run a few more pack thru it.
TLRrunner is offline
Old 09-12-2013, 01:30 PM
  #13562
the incubus's Avatar
Trader Rating: 17 (100%+)
The difference between 12-14 gauge is at best, nominal. I ran all 12 on my 410 and temps were high and since I swapped out all electronics and didn't have anymore of the nice 12 gauge, I went with the 14 and I feel no difference. The fan is new for me and I will be testing it for the first time on Saturday so I will report back on how much of a difference it makes. I felt that at $9 it was a no risk investment for my motor.
I am however heavily considering selling the Orion and going with an LRP since they are designed to handle higher temps better than most other motors. The one on my T4 survived a bad short and it never skipped a beat. I hear Reedy motors can handle higher temps about as well, though the only one I have experience with is my son's 17.5 which doesn't heat up much, if any.
the incubus is offline
Old 09-12-2013, 01:38 PM
  #13563
BillyT.'s Avatar
Originally Posted by TLRrunner
I bet it got louder! Lol! I think those things are about 1mm to 1.5mm, it could be an rc missle! The track at mike's isn't a fast layout after the recent change. The fastest I've heard and see are mid 19s.
Bring it out! The layout is the last one before the move.
It's faster than the turf track at monkey for sure... Even with the 10t at 70 percent, I am pinned for a split second on our banked turn, and that's it.
I prolly won't be able to get out there till after next weekend(after the Sweep race). We start on the build for the new track Saturday morning, and I'll be running till it's done...
BillyT. is offline
Old 09-12-2013, 01:57 PM
  #13564
The motor I've got in it now is a 1st gen Reedy Mach 7.5. I've heard the same thing about the Reedy motors being able to handle higher temps than most other motors.
Will Monkey be open this weekend? I might sneak by there today while on babysitting duty.
Old 09-12-2013, 02:31 PM
  #13565
BillyT.'s Avatar
yeah. Indoor will be open the whole time we are working outside.
BillyT. is offline
Old 09-12-2013, 06:56 PM
  #13566
RC*PHREAK's Avatar
Trader Rating: 145 (100%+)
Little help here...
can't figure out why I have this probably 1.5-2.0mm gap between the servo horn and the rod end. there are no washers between the servo ears and the block they screw into. i can make it reach, but then it's at an angle and isn't square. this is an orion 1409 servo. am i just screwed with this servo?
RC*PHREAK is offline
Old 09-12-2013, 07:13 PM
  #13567
Originally Posted by RC*PHREAK
Little help here...
you can always put a longer screw and some washer there to make it a square angle.
nicholasxuu is offline
Old 09-12-2013, 07:15 PM
  #13568
RC*PHREAK's Avatar
yeah, i thought of that and will do it if there isn't some other explanation. i was just looking for a reason why it's like this.
Old 09-12-2013, 07:26 PM
  #13569
guess you can always add some spacers to make it square. you'll need special servo horn vice versa.
Picture from 2013 reedy race, Jorn also added a lot of spacers for his.
Old 09-12-2013, 07:31 PM
  #13570
huzzler's Avatar
Little help here...
I run same servo in my dex. Just use longer screw with spacers and it works just fine. Never have any problems.
huzzler is offline
Old 09-12-2013, 07:37 PM
  #13571
morris's Avatar
Trader Rating: 44 (100%+)
Any of you guys do hexes on the back?
If so which ones?
Figured I would get a quick answer here vs trying to find the info otherwise.
Thx in Advance..
morris is offline
Old 09-12-2013, 07:38 PM
  #13572
Cameron Kellogg's Avatar
Trader Rating: 45 (100%+)
I use a 3mm nut as a spacer. Seems to work fine on the buggy and sc.
Attached Thumbnails Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-image.jpg
Cameron Kellogg is offline
Old 09-12-2013, 07:44 PM
  #13573
huzzler's Avatar
If so which ones?
Thx in Advance..
Are you talking about aluminum hexes? Cause you pretty much have to run hexes. I run the gold Durango 14mm hexes. I would like to get a set of the Hot Bodie 12mm hexes though so I can run my B4 wheels.
huzzler is offline
Old 09-12-2013, 08:02 PM
  #13574
If so which ones?
Thx in Advance..
I've tried Jconcept's AE B4 front hex, besides the original 6x5x1.5mm spacer, it needs an extra 5x10x0.8mm Shim. still the rear width is a bit narrow.
I guess jconecpt's AE SC10 front hex can get rid of the shim.
also going to try tlr 22's hex.
Old 09-12-2013, 08:08 PM
  #13575
RC*PHREAK's Avatar
Thanks guys. Guess I'll go that route. Seems like a design flaw.
