Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread
Small dilemma, due to an unfortunate experience I ended up with an $89 credit from Tower.
I've had my eye on the Hitech 4X AC/DC charger for some time and this credit may be the best way for me to pick one up. But that means I'd still have to shell out a little over $100.
The other option is replacing my Tekin Gen2 6.5T with a Reedy Sonic 2 6.0T. Im considering this because Im running a good amount of ESC timing on the Tekin and still not impressed with its power (although the power is sufficient). I've read good things about the Sonic's and could order it with out of pocket cost of >$15.
If I like the Reedy better I could always sell the Tekin but I don't expect to get more than $65-75 for it.
Sounds silly, I know, but any thoughts?
Anyone running the Team Orion Vortex R10 Pro (2-3S). If so how's the fit and performance?
i read some old posts about leaky diffs and some fixes. you guys having trouble with your diff's? does anyone have a good fix for them...or the best fix? links maybe?
I'm running one, the fit is fine because it has such a small footprint. I'm running a 7.5 Reedy motor. I was using a 5.5 mach 2 but it was too much for the track I run at. The 7.5 is perfect and if I go to a bigger track I can ramp everything up and still run cool temps. One of my previous posts has a picture of my car with everything in it.
kicking myself for not buying one before they went out of stock! I guess now I realize I want one more than I thought. Anybody hear any rumors about if/when they might be back in stock? or if LHS's can get ahold of them? the r still looks like a nice option for $150, but I'd prefer to get all the upgrades.
I'd recommend wait for more v3 back in stock at that price. Or just wait for the new version.
the R is worth the price tag, it's fine if you stick with only minimum necessary upgrades, you'll spend the discounted V3 money, ended up even without big bore shocks.
Or, if you "accidentally" got into the upgrade hole, you may end up with a V4 money for a V3.
Anyways does anyone knows when the stocks are coming in?
http://www.petitrc.com/setup/durango...ngoDEX410.html
For all the new Durango Owners there are a few important websites to add to your favorites.
team-Durango.com/in-the-pits.
Lots of great info here
Www.lutzinator.com
Lots of great Durango set-ups here
http://durangofansite.com/index.html
Everything else you need to know about parts and hop ups.
And of course the Petitrc link in the post above.
These sites will answer 85% of your question.
Www.lutzinator.com
There is some excellent build tips on here including diffs.
Www.lutzinator.com
And of course the oodles link in the post above.
Www.lutzinator.com
man that is some great info on the dex410 at petite. do you guys grease your CVD's often? do you take them apart to grease/rebuild or just squirt some grease in there? if so, how often do you do it?
also, did you guys guys add anything to keep the pins in? they said they added, "We have now added two CVD collars to TD310039 to ensure that even the most poorly-builtand poorly-maintained CVDs do not lose their pins!"
Www.lutzinator.com
Www.lutzinator.com
Just a note, I have been working on updating my website, you can find the newer version here http://durangofansite.com/index.php
