Like Tree22Likes
Old 09-09-2013, 11:24 AM
  #13501
rifleman223's Avatar
Originally Posted by huzzler
Rc planet has them in stock for $189. You can probably find coupon code also.
http://www.rcplanet.com/ProductDetai...FchxQgodbScAQg
It says its $249
rifleman223 is offline
Old 09-09-2013, 11:34 AM
  #13502
tksnobords's Avatar
Trader Rating: 36 (100%+)
Originally Posted by nicholasxuu
I got tekin rs pro + spektrum sr3100, fits perfectly onto the mounting plate.
I'm running the same. But my motor wires are touching the drive shaft. So I'm going to angle them on the motor tabs so they won't touch anymore.
tksnobords is offline
Old 09-09-2013, 11:41 AM
  #13503
the incubus's Avatar
Trader Rating: 17 (100%+)
Just L@@K at how I wired mine up. All you have to make sure you do is maintain the correct angle coming off the motor and ESC leads and you will clear everything just fine. i was a bit concerned but once I soldered the first lead to the Motor & ESC it was easy to see how well it was going to work.
the incubus is offline
Old 09-09-2013, 12:13 PM
  #13504
Cameron Kellogg's Avatar
Trader Rating: 45 (100%+)
Originally Posted by tksnobords
good idea. i just got move my motor wires a little bit and i need a few more pieces to shorten the esc-to-rx wires, and my transponder wires to clean it up. i will be sure to post some pictures after i get the electronics mounted.
I will post some pictures of my set-up tonight using a RS Pro and a standard receiver. I have a lexan cover that goes over the part of the ESC and receiver that covers all the wires and just cleans up the overall look of things. Kind of a out of sight out of mind set-up. The motor wires go over the front drive shaft with enough of an arc to get the center gear out still.
Cameron Kellogg is offline
Old 09-09-2013, 12:53 PM
  #13505
huzzler's Avatar
Originally Posted by rifleman223
It says its $249
Your right it does. They were $189. Only thing they have in stock now is r version and it is $249. Didn't really pay much attention to link. Sorry bout that.
huzzler is offline
Old 09-09-2013, 01:55 PM
  #13506
RC*PHREAK's Avatar
Trader Rating: 144 (100%+)
which pivot balls do you need to run the one piece shock standoffs?
RC*PHREAK is offline
Old 09-09-2013, 02:52 PM
  #13507
R/C Tech Elite Member
Trader Rating: 520 (100%+)
Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-tdrc4612.jpg
http://www3.towerhobbies.com/cgi-bin...?&I=LXCCWD&P=7
flame56mx is offline
Old 09-09-2013, 02:54 PM
  #13508
RC*PHREAK's Avatar
thanks!
Old 09-09-2013, 02:59 PM
  #13509
thanks!
No prob, I am sure most everyone knows this, but the shock cap is a one way design, there is a larger side, and a smaller side. Be sure to push the pivot ball in the larger side, I believe its marked with a wide ring around it if I am not mistaken.
Old 09-09-2013, 07:02 PM
  #13510
And that larger side is supposed to face forward so the shock caps can't pop off and past the nuts.
Old 09-09-2013, 07:05 PM
  #13511
RC*PHREAK's Avatar
confused here.
so the smaller side goes toward the shock tower? if you're using the stock standoffs, that would mean that you're putting the pivot ball/cone/thingy into the smaller side. correct?
Old 09-09-2013, 07:19 PM
  #13512
ekt
ekt's Avatar
confused here.
From my experience it doesn't matter which way the cap is when running the quick change mounts. With the stock shock mounts the caps will only mount one way.
ekt is offline
Old 09-09-2013, 07:45 PM
  #13513
I agree, I have never had any issues, and my OCD causes me to run the bleeder screws towards the outside for some reason regardless of which way the pivot ball faces..
Old 09-09-2013, 07:49 PM
  #13514
The Czechexican's Avatar
Inside for me
The Czechexican is offline
Old 09-09-2013, 07:59 PM
  #13515
RC*PHREAK's Avatar
So which way should bleeder screws be facing with stock standoffs?
