Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread
I just built this kit. Overall I love the way the car is designed except the battery configuration. I suppose its not that bad as longs a you get used to it. I do however HATE the pathetic pictures in the manual that shows no dimension because everything looks black. Really bad pictures. Some small issues like the shock piston washer had to be persuaded into the shaft. The battery retainer hole had to be slightly modified so I can place the pin in. The kit also disnot have diff oil? Not a beginner build.
http://www.petitrc.com/setup/durango...oDEX410v3.html
I am having issues assembling the front steering knuckles. The holes are not reamed large enough for the screws provided. Anyone else have this issue?
Anyone no who has these kits instock , at a decent price ?
It did look OK but as soon as you start placing the electrics, real estate quickly vanishes.
any of you guys have your electronics mounted directly on the chassis? i'm debating on whether to put mine on the chassis or the little mounting plate. but my wires have to clean and shrink wrapped. i can't have all loose everywhere lol
Honestly I don't know how you can use the mounting plate. There is barely any room in this thing for the esc. Everyone I know just mounts it straight to chassis including myself.
Double up on the servo tape to give it a little extra give for hard landings.
good idea. i just got move my motor wires a little bit and i need a few more pieces to shorten the esc-to-rx wires, and my transponder wires to clean it up. i will be sure to post some pictures after i get the electronics mounted.
though for my 410 short course, I've removed the mounting plate for larger electronics.
