Like Tree22Likes
Old 08-24-2010, 11:41 AM
  #1336
tonyv2382's Avatar
Trader Rating: 67 (100%+)
Originally Posted by dangerwr
Thanks for taking the time to post this info. I will definitely start with 10k in front and 5k in rear. Grapejuice runs at the indoor near Denver (MHOR) so will bug him more about shock setups . . .
Looks like the Black are 2.13lb front and 2.86lb rear which are two springs stiffer than light blue and two springs softer than the dark blue.
Speaking of which does anyone have a spring rate chart for durango?
tonyv2382 is offline
Old 08-24-2010, 11:44 AM
  #1337
dangerwr's Avatar
I will try to attach the file. Grapejuice posted the link last week I believe . . .
File Type: pdf
dangerwr is offline
Old 08-24-2010, 11:53 AM
  #1338
tonyv2382's Avatar
perfect thanks
Old 08-24-2010, 05:29 PM
  #1339
Trader Rating: 48 (100%+)
Hey guys, a little help here...I'm running a TekinRSPro with a 5.5 BL motor and using a 16T pinion on stock spur gear. My motor temps at 120+deg F but my ESC is at 155+degF. Could you guide me what's the best baseline set-up for the ESC? Many thanks.
ambo is offline
Old 08-24-2010, 05:32 PM
  #1340
R-E-A-P-E-R-'s Avatar
Danger I haven't had a chance to tell you this week yet but you suck bud.
HAHAHAHAHAH
You get that whip built yet?
R-E-A-P-E-R- is offline
Old 08-24-2010, 05:35 PM
  #1341
tonyv2382's Avatar
Holy Hell...lol take that 16t out and go from 23 and up. asap
Old 08-24-2010, 05:36 PM
  #1342
Matt Howard's Avatar
On the Tekin site there's a esc setup for a 6.5 in a durango, I would start with that.
Matt Howard is offline
Old 08-24-2010, 05:38 PM
  #1343
tony2382: Ok, thanks for the heads-up. I started with a 9.5 and wasn't happy because it didn't have the top-end I needed so I switched to a 5.5. I'll go start with a 21T pinion and check my temps.
Matt: Cool. I'll check it out. Thanks.
ambo is offline
Old 08-24-2010, 05:44 PM
  #1344
Randy's setup on the Tekin site calls for a 19T pinion with a 6.5 motor, he should be good using 17-18t pinion on a 5.5, a 23T pinion will overheat the motor pretty quick.
Old 08-24-2010, 05:45 PM
  #1345
tonyv2382: Just asking, what's your ESC set-up on your RSPro? It's taking me ages to scan at the Tekin Forum site..many thanks.
ambo is offline
Old 08-24-2010, 06:00 PM
  #1346
dangerwr's Avatar
HAHAHAHAHAH
Haha! No but I am starting tonite!! Take care and see you at the track. Be sure to text me if you are gonna race HTL.
dangerwr is offline
Old 08-24-2010, 08:15 PM
  #1347
Ok bud
Old 08-24-2010, 08:40 PM
  #1348
dangerwr's Avatar
Whoa-ho! Tiny parts!! This kit is amazing. Some of the tolerances are unreal. Truly a quality kit. I will be watching for their 8th scale when it comes out. Definitely use the Oople article and follow it closely when building . . .
dangerwr is offline
Old 08-25-2010, 01:46 AM
  #1349
MaTt 93's Avatar
I think 23t pinion might be a bit much for a 5.5T. Im running a speed passion v3 5.5t and a lrp sxx tc and i'v got a 18t pinion with the std spur and it comes of just about perfect. Im not sure if its different with the tekin speedy though
MaTt 93 is offline
Old 08-25-2010, 08:02 AM
  #1350
dangerwr's Avatar
I am wondering why Durango did not use gaskets in the diffs. Seems like a no brainer to me but maybe I am missing something . . .
dangerwr is offline
