Like Tree22Likes
Old 08-29-2013, 06:02 AM
  #13351
Originally Posted by symmetricon
yes, rsd speedway is only carpet. we do have an excellent 1/8 clay track that is covered.....
Sweet! I'm heading down to San Antonio next weekend for round 3 of the EOS. I haven't gotten an 1/8th scale yet. I might have to bring my DEX410 with me when if I come in October. Only driven my F1 on carpet, it'll be interesting.
TLRrunner is offline
Old 08-29-2013, 06:08 AM
  #13352
symmetricon's Avatar
Trader Rating: 27 (100%+)
with the right setup the dex is amazing on carpet. put jorn's carpet setup and you'll be ready!
symmetricon is offline
Old 08-29-2013, 06:14 AM
  #13353
Trader Rating: 57 (100%+)
Still against my better judgment but with all the new DEX410 owners jumping on, why not share?
http://www.rctech.net/forum/tresrey-...-giveaway.html
shagino is offline
Old 08-29-2013, 12:18 PM
  #13354
MD
MD's Avatar
Trader Rating: 136 (100%+)
I am thinking about buying a 4wd Durango 1/10 buggy. Someone told me it's kind of a hassle to change the batteries. I saw one video where the driver removed the spur gear to change the batteries. Was that correct? How much of a hassle is it to change the batteries? Thanks for your help.
MD is offline
Old 08-29-2013, 12:25 PM
  #13355
BillyT.'s Avatar
Turf in dallas soon! We are all getting DEX 410s too... Gonna be a blast!
BillyT. is offline
Old 08-29-2013, 12:26 PM
  #13356
SUPERLOOPER's Avatar
You do need to remove the center diff to change the battery. If you have the pin fitment correct it is very easy to change. Like less than 30 seconds tops.
SUPERLOOPER is offline
Old 08-29-2013, 12:50 PM
  #13357
the incubus's Avatar
Trader Rating: 17 (100%+)
^^^ This!
People today are so darned lazy it's ridiculous. It might take you 3 times, if that to get the hang of it. You pull the Slipper retaining pin, remove the cover and slipper assembly, then remove the battery brace pin and slide out the batteries, slide fresh set in, Pin, drop in slipper and cover lining up driveshafts, slide pin and you're done.
Takes a bit more than double the time it took you to read this.
the incubus is offline
Old 08-29-2013, 01:20 PM
  #13358
MD
MD's Avatar
Originally Posted by the incubus
^^^ This!
I am lazy, no doubt it. But, I haven't owned a Durango before and I just wanted to check. I have B44 and putting lipo packs in it is a pain. I saw the video about changing the packs in a Durango. There are a few steps, but I don't think it's any more time consuming than the B44.
MD is offline
Old 08-29-2013, 02:11 PM
  #13359
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
Assuming all ROAR saddles fit right?
Also, seen pics of guys using Shorties, where is this an advantage over the saddles?
Cain is offline
Old 08-29-2013, 02:28 PM
  #13360
Reduces and centers the weight is my guess, and to be honest, as beastly fantastic as this car is, it can stand to shed a bit of weight.
Old 08-29-2013, 02:37 PM
  #13361
Trader Rating: 37 (100%+)
For me the main advantage is that I don't have to buy saddle packs. I already had a handful of shorties since that's what I run in my 2wheeler.
rnpnick is offline
Old 08-29-2013, 03:28 PM
  #13362
The Czechexican's Avatar
Originally Posted by tobamiester
8.5 is fine, 10.5 is also a good starting point for this buggy. Drives pretty cool but decently fast on a small track.
Watch the temps on the RS. An RS-Pro is more ideal for 4WD Buggy.
Yeah for sure I want a RS pro and I have a 6.5 in the box right now. Just hoping I could get away with set up for now And use the 6.5 for outdoor
The Czechexican is offline
Old 08-29-2013, 03:45 PM
  #13363
MD
MD's Avatar
This is a question for Durango drivers that have owned B44's. Is the Durango less durable than the Associated buggy? Thanks.
MD is offline
Old 08-29-2013, 03:47 PM
  #13364
Reflexia's Avatar
You can also do what I did and modify they battery strap. I have split it where the drive shaft goes (so cut the middle section away at the front and back ). This still holds the battery down fine, and I can now swap out the batteries without removing any of the drive line (they slide one at a time out the front near the spur). This was on a V3.
Saddles themselves are still a pain in terms of number of wires, but that's universal.
I've found my shorties are ok life time wise ( 3800/4200mah ) but I find the saddles give just that little extra push
Reflexia is offline
Old 08-29-2013, 03:48 PM
  #13365
vito's Avatar
iam thinking to tray one but don't know love my 44.2
vito is offline
