Like Tree22Likes
Old 08-28-2013, 06:30 PM
  #13336
Originally Posted by the incubus
You could've just as easily changed the timing curve on your ESC and/or turned down the timing of your motor. Would've saved a little cash and retained the additional power should you feel the need for more once you've mastered the lower speed.
Either way 7.5 is still beastly fast and you can rely on gearing to make up some of that punch. I run a 7.5 on my 4.2 and I feel that's likely the limit and on my 410 the 6.5 is the limit but I'm still getting acclimated to this car. As well, I just got the new vortex wing which has a ton more surface area and I'm expecting for it to plant my rear end a bit better. Oh, and my 21 Blocks should be arriving so I'm expecting another slight improvement there. All in all I'm expecting to feel a noticeable increase in performance.
I've tried all of those things with no success, my temps were constantly climbing. I didn't spend any money on the motor, I just swapped the 7.5 from my Dex210 and I have a 17.5 ready to go in it as replacement. Now I've got a 5.5 available for sale.
TLRrunner is offline
Old 08-28-2013, 07:20 PM
  #13337
The Czechexican's Avatar
Could I run a 8.5 in this buugy? Running on a small carpet track and 6.5 5.5 seems over kill. Will it work over the Teakin RS and 8.5? To Small?
The Czechexican is offline
Old 08-28-2013, 07:31 PM
  #13338
yes on both questions.
Old 08-28-2013, 07:37 PM
  #13339
symmetricon's Avatar
Trader Rating: 27 (100%+)
im running a 13.5 on a small carpet track. it works very well.
symmetricon is offline
Old 08-28-2013, 07:51 PM
  #13340
vito's Avatar
was this kit like 400 one time lol
vito is offline
Old 08-28-2013, 08:39 PM
  #13341
Trader Rating: 17 (100%+)
$429 I believe.
AlderBoy is offline
Old 08-28-2013, 09:50 PM
  #13342
Jochim_18's Avatar
The 2010 spec is like $700 when they first came out..
Jochim_18 is offline
Old 08-28-2013, 10:36 PM
  #13343
Originally Posted by nicholasxuu
i'm wondering what will be on the new version? something that will cost more than 200 to upgrade to?
Even if it is I'd just run the kit as is... I'm nearly fast enough to have to worry about having the latest and greatest. For $200 I can drive it for a year and then worry about upgrading.
Barge is offline
Old 08-29-2013, 04:10 AM
  #13344
Vary cool. Thanks.
Old 08-29-2013, 04:57 AM
  #13345
symmetricon - What track in Houston do you run at? I assume you're running boost, turbo or some kind of timing with that 13.5 right?
Old 08-29-2013, 05:13 AM
  #13346
tobamiester's Avatar
Trader Rating: 360 (100%+)
8.5 is fine, 10.5 is also a good starting point for this buggy. Drives pretty cool but decently fast on a small track.
Watch the temps on the RS. An RS-Pro is more ideal for 4WD Buggy.
tobamiester is offline
Old 08-29-2013, 05:23 AM
  #13347
RSD Speedway, lap times range from 13-15sec based on layou. No turbo or boost. We have found having more power does not yield faster times due to the tight technical layout....
Old 08-29-2013, 05:28 AM
  #13348
with a 6.5t
+ YouTube Video
with a 13.5t
+ YouTube Video
Old 08-29-2013, 05:48 AM
  #13349
you guys just got new carpet right or recently reopened right? EOS round 4 is going to be there in October. I'm planning on running my F1 in that race. So you guys just run all carpet everything no dirt right?
Old 08-29-2013, 05:53 AM
  #13350
yes, rsd speedway is only carpet. we do have an excellent 1/8 clay track that is covered.....
