Like Tree22Likes
Old 08-27-2013, 07:06 PM
  #13306
ABBOTT's Avatar
The 102 spur from the DESC will fit in the buggy? never thought to try but it is interesting
ABBOTT is offline
Old 08-27-2013, 07:50 PM
  #13307
it does barely, it takes removing the spacer between the center mount and modifying the spur gear cover.
TLRrunner is offline
Old 08-27-2013, 08:07 PM
  #13308
-DOZER-'s Avatar
Originally Posted by mulepic
I was definitely going to go for the 4000kv if I did the 3656, but thanks for the info.
I stuffed the 3400kv 3656 in my DEX. Once in it was very apparent the end bell would smack the servo with chassis flex. Also I could not fit the appropriate ESC in there with it. If you want a 4pole the Pro4 is the same length as a normal 540. But the appropriate ESC is still an issue.
-DOZER- is offline
Old 08-27-2013, 08:16 PM
  #13309
Trader Rating: 21 (100%+)
I did see there was only about 1.5mm space between the endbell and servo but I didn't think about chassis flex. I'm guessing the hw 120a 3.1 will fit in the car.
So you never got to run it w/ either the 3656 or Pro4?
mulepic is offline
Old 08-27-2013, 08:19 PM
  #13310
you probably have to shim the motor mount up so the motor clears without rubbing the chassis.
Old 08-27-2013, 08:55 PM
  #13311
-DOZER-'s Avatar
^ Absolutely, I forgot about that. I had to raise the motor and spur mount using 3mm spacers. In the end it was all unnecessary work.
-DOZER- is offline
Old 08-27-2013, 09:24 PM
  #13312
the incubus's Avatar
Trader Rating: 17 (100%+)
As promised here are pics of my 410 showing the electronics and the newly installed fan:
Haven't run it on track yet so I haven't a clue as to how much of a difference it will make considering the placement. I'd I don't see much of one I will be buying the Spec-R mount and place it dead center. Still have to rewire anyway so it won't be a big deal.
the incubus is offline
Old 08-27-2013, 09:33 PM
  #13313
how were you geared again?
Old 08-28-2013, 06:30 AM
  #13314
87/21 I believe.
Old 08-28-2013, 06:49 AM
  #13315
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
seeing a deal on these, down to $199.99 shipped. Is there a new one on the way?
Cain is offline
Old 08-28-2013, 07:05 AM
  #13316
$199 is the 410Rv3 I believe. New 410v4 out in March.
AlderBoy is offline
Old 08-28-2013, 07:21 AM
  #13317
Really? Do you have anything to back that up?
mulepic is offline
  #13318
Tech Legend
Cain's Avatar
This one here:
http://www3.towerhobbies.com/cgi-bin...&I=LXCBXR&P=ML
I believe that is the full vehicle right? The "R" one is $150 right now.
Cain is offline
Old 08-28-2013, 07:28 AM
  #13319
Trader Rating: 57 (100%+)
There's a lot of chatter of new everything in Q1. Saw a few people posts a while back. Haven't seen anything official but I definitely believe it.
shagino is offline
Old 08-28-2013, 07:46 AM
  #13320
Originally Posted by Cain
This one here:
That is the latest one. Wow they just dropped the price another $100!
AlderBoy is offline
