Like Tree22Likes
Old 08-22-2013, 04:58 AM
  #13231
Originally Posted by ridgeracer
Im geared 87/23 and Im using tons of boost and turbo with a 6.5
I had problems with heat before, but after I put a fan on the motor the temp is around 40 degrees celsius/10 min running.
Hey Ridgeracer, how did you mount the fan? Can you post a picture?
TLRrunner is offline
Old 08-22-2013, 06:14 AM
  #13232
8ight-e's Avatar
Trader Rating: 58 (100%+)
Just get the hobbywing Xerun 4-pole sensored 4000kv motor, you'll never have to worry about temps or anything more than basic cleaning and swap the bearings as needed depending on the conditions in which you run. Typically I swap bearings 1x per year to be safe
8ight-e is offline
Old 08-22-2013, 06:22 AM
  #13233
I usually run all Hobbywing gear, but I couldn't pass up the deal on the motor that I'm using now. Which Hobbywing motor are you referring to the XERUN V10 or the XERUN Sensored Brushless 3656 Motor used for SCT? I think that I might be way under geared, today I'm going to try gearing up and see what effects that has.
Old 08-22-2013, 07:52 AM
  #13234
Trader Rating: 21 (100%+)
I'm still figuring out which motor/esc I'm going to use. I like the idea of using the XERUN Sensored Brushless 3656 4 pole motor w/ say the hw 120a esc. I bet the would run cool.
mulepic is offline
Old 08-22-2013, 08:00 AM
  #13235
You'll definitely have more than enough power with the 4pole but you gotta think about space. Space is tight in the Dex410v3. Which of the 120a esc are you considering? Not to mention that motor has a 5mm rotor might have a hard time finding a pinion that fits.
Old 08-22-2013, 08:13 AM
  #13236
Good point, I don't have a 5mm 48p pinion. But I do have a cc1406 4000kv 4 pole motor but it is not sensored. I'll just give that a try once I get this battery figured out. Write now the only esc I have to use is a 60a HW. I smoked my 120a but I'll probably get another.
mulepic is offline
Old 08-22-2013, 08:57 AM
  #13237
I ran a 1406 in my SCTE for a long time before I got the Hobbywing in it. It was a good motor but it was a different world when I put the right kind of motor in the truck which would be the same situation for the 410.
Old 08-22-2013, 09:12 AM
  #13238
I would agree that a 1406 would be anemic for the scte but for the dex410, it should push it w/ no problem. You're not confusing the 1406 (540 sizes) w/ the 1410 or 1415?
mulepic is offline
Old 08-22-2013, 11:01 AM
  #13239
Yea, I remember wanting a 1410 but could never get one cheap enough and the motor coming off a little warmer than most other guys racing with me.
Old 08-22-2013, 11:06 AM
  #13240
8ight-e's Avatar
I thought this was the desc410 thread... you don't need 4-pole beasts in the dex410,,, my bad. But yes that new v10 should be pretty awesome... just make sure if it's another brand you run their torque rotors to help keep cool. just an opinion I'm not saying that 4pole wont work though, and it would be very cool as well but will put a lot more stress on the drive train.
8ight-e is offline
Old 08-22-2013, 11:54 AM
  #13241
The Reedy 5.5 I have in my buggy feels like its a 4pole monster just because there is nothing I can do! just a little bit ago I almost cooked all the electronics 200+. Dialing back motor timing and gearing should give me less wheelspin, more top end and less torque right?
Old 08-22-2013, 01:21 PM
  #13242
Woulvesbaine's Avatar
Any intel on the v4 and whether the v3 can be converted to the new chassis (or whether it's not worth it).
Woulvesbaine is offline
Old 08-22-2013, 02:03 PM
  #13243
Jochim_18's Avatar
You guys need to free up the driveline to keeps the temp down... I'm running 6.5 geared at 87/21 at first temp is always an issue. I noticed the driveline is not free and that will cause heat on the motor. What causing the driveline to bind is the diff case. If you add a middle bearing on the driveline axle and this will free up the driveline with no slap and your driveline will spin more free.
Jochim_18 is offline
Old 08-22-2013, 02:04 PM
  #13244
Jochim_18's Avatar
Is their a version 4 coming out?
Old 08-22-2013, 04:05 PM
  #13245
ifmar world coming && v3 on sale,
according to a post in oople, it'll probably be out around November.
nicholasxuu is offline
