Like Tree22Likes
Old 08-20-2013, 06:40 PM
  #13201
Has anyone had an issue with the pin coming out of the rear center drive shaft? I locktite and have done everything possible to keep it in with no luck!
TLRrunner is offline
Old 08-20-2013, 06:49 PM
  #13202
symmetricon's Avatar
Trader Rating: 27 (100%+)
Clean the grub screw and everything else with break cleaner and the put a set screw on both sides and use red locktight ( not the kit locktight )...
symmetricon is offline
Old 08-20-2013, 07:07 PM
  #13203
weavz's Avatar
Use heat shrink, works a treat
weavz is offline
Old 08-20-2013, 07:22 PM
  #13204
mkiiina's Avatar
Trader Rating: 71 (100%+)
Originally Posted by ericzwick
I have been told that the 6mm composite towers are very durable. I am actually taking my carbons off in order to try the composite towers. You should see a little more traction due to flex as well with the composite.
I don't know about that as the front tower snapped on the 3rd pack. Another thing is the composite shock towers are thicker and the ball studs dont thread all the way through (too short). The strip out so get some longer ones and use nuts to hold them in.
Swapped to the metal ones in. If you are looking to get rid of the carbon ones drop me a PM.
mkiiina is offline
Old 08-21-2013, 05:12 AM
  #13205
Trader Rating: 21 (100%+)
I'm just about done putting the car together but my shorty lipo pack doesn't fit. It runs into the battery door pin nubs on the motor mount and pinion hoop. I even have the exact battery I see pictured for some of those using shorties. Do I need to modify something to get a shorty pack to fit?
mulepic is offline
Old 08-21-2013, 05:42 AM
  #13206
McD44's Avatar
Trader Rating: 16 (100%+)
Which pack?
McD44 is offline
Old 08-21-2013, 06:23 AM
  #13207
the nano tech 4200 shorty which is the same size as my smc shorties
mulepic is offline
Old 08-21-2013, 06:27 AM
  #13208
the incubus's Avatar
Trader Rating: 17 (100%+)
I run saddle packs but it never occurred to me that shorties fit in this thing.
Just googled it and low and behold, they do!
I'm sticking with saddles for now.
the incubus is offline
Old 08-21-2013, 06:32 AM
  #13209
McD44's Avatar
Crap, I just ordered the same packs for mine in hopes of running them. I had them before and they fit in my DESC410 though...
McD44 is offline
Old 08-21-2013, 06:37 AM
  #13210
McD44's Avatar
Exhibit A.
Attached Thumbnails Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-image.jpg
McD44 is offline
Old 08-21-2013, 06:39 AM
  #13211
search around, plenty are doing it. it's one of the reasons i got this car.
mulepic is offline
Old 08-21-2013, 06:53 AM
  #13212
Trader Rating: 166 (100%+)
I'm new to this car. What are the benefits to running a shorty?
Chris Gierse is offline
Old 08-21-2013, 06:56 AM
  #13213
As long as the batteries are no taller than 25mm they should fit. I personally like the saddles because they have a little more weight than the shorty which the car seems to like IMO.
Old 08-21-2013, 06:58 AM
  #13214
I heat shrunk the rear center drive shaft last night, it looks good but I hope it holds because the pin went thru the plastic pin retainer with now issues. This issue has cost me 1 saddle pack already.
Old 08-21-2013, 07:03 AM
  #13215
They will poke through heat shrink too if the CVD lost its grease (dry joint)
zzztech is offline
