Like Tree22Likes
Old 08-20-2013, 07:20 AM
  #13186
McD44's Avatar
Trader Rating: 16 (100%+)
Originally Posted by mulepic
I just noticed the v3 doesn't use pivot balls. And I know the strength improvement on the dex210 hanger was the elimination of the pivot balls. Did your plastic hangers that broke use the pivot balls?
No I have the exact same car you have no pivot balls with the plastic hangers. The AL hangers use the pivot balls.
McD44 is offline
Old 08-20-2013, 07:24 AM
  #13187
symmetricon's Avatar
Trader Rating: 27 (100%+)
Viper vtx10r can run hot too. When I was running on dirt with a 6.5T motor, 170deg was nothing. Set the internal sensor to 240deg and no problems.
symmetricon is offline
Old 08-20-2013, 07:25 AM
  #13188
I love that the car has pivot balls, it makes the suspension smooth and bind free...
Old 08-20-2013, 07:31 AM
  #13189
McD44's Avatar
Agree. The pivot balls with the aluminum hangers work very well.
McD44 is offline
Old 08-20-2013, 08:00 AM
  #13190
Trader Rating: 21 (100%+)
How about the shock towers, do they hold up or do they need to be replaced w/ aluminum?
mulepic is offline
Old 08-20-2013, 08:23 AM
  #13191
The carbo shock towers are good, but.... i would love some machined aluminum on the front..... for peace of mind on large fast tracks......
Old 08-20-2013, 08:42 AM
  #13192
The R version towers are plastic. So I'm curious if they break as easily as the dex210's did? And I'm actually looking at making the towers out of carbon fiber.
mulepic is offline
Old 08-20-2013, 08:50 AM
  #13193
Trader Rating: 50 (100%+)
I have been told that the 6mm composite towers are very durable. I am actually taking my carbons off in order to try the composite towers. You should see a little more traction due to flex as well with the composite.
ericzwick is offline
Old 08-20-2013, 11:53 AM
  #13194
1slash's Avatar
Originally Posted by TLRrunner
what motor is your 5.5? What is your gearing? What are the temps your seeing when you come off the track? I have a Reedy 5.5 and I've come off at 175+. I've checked the drive train for binding and found nothing, the only thing left to check is the motor itself.
I am running just a regular SP 5.5t motor (http://www.amainhobbies.com/product_...less-Motor-55R)
as far as the gearing goes im running a 21t pinion and 87t spur.
After an 8 minute main with some throttle happy driving the highest I have seen it is 150. most of the time it stays under 140 though. The motor also stays at a similar temp (around 138-146 after 8 minutes).
1slash is offline
Old 08-20-2013, 01:40 PM
  #13195
At this point I'm completely at a loss with why my motor is getting so freaking hot! Anyone else have any other thoughts as to why this might be happening?
TLRrunner is offline
Old 08-20-2013, 01:42 PM
  #13196
Trader Rating: 57 (100%+)
Default Tresrey Giveaway!
Against my better judgment, decided to share.
As I say on the stand, good luck everybody!!!
http://www.rctech.net/forum/tresrey-...-giveaway.html
shagino is offline
Old 08-20-2013, 01:43 PM
  #13197
Konich's Avatar
You are the lucky few that get a chance! GOOD LUCK!
Konich is offline
Old 08-20-2013, 01:45 PM
  #13198
Konich's Avatar
Get as many holes in your body for air flow as possible.
Konich is offline
Old 08-20-2013, 01:58 PM
  #13199
I've gotten up to 160 while I was testing the temp issue without the body. I'm going to retard the motor timing and see if that helps. Gearing hasn't helped, currently geared 87/19.
Old 08-20-2013, 03:08 PM
  #13200
the incubus's Avatar
Trader Rating: 17 (100%+)
Well, my Orion's timing isn't turned up and it still gets hot. I believe the issue is the heft of the car and nothing more. Compared to both of my buddies' 44.2's and the 2 K1's that run at my local track, the 410 is a heavy cow. It amazes me how gracefully it behaves on track. The car is superb but could stand to go on a serious diet. rather than adding all the weight to the rear of the car, perhaps the front end could stand to lose a little.
And before anyone suggests the weight is the greatest factor in how well the car drives, there are other cars that are far lighter that drive perfectly fine, though they are not as awesomely fantastic as the Durango.
Mind you, this is coming from long time Associated guy.
the incubus is offline
