Like Tree22Likes
Old 07-25-2013, 04:13 AM
  #13036
smittyusmc's Avatar
Originally Posted by 1slash
An easy way to keep track of this is to make a large dot on the side you want up with a paint marker. I have had too many times when I'm assembling my car after maintenance and the diffs are upside down
Thats good idea I will be doing that for sure.
smittyusmc is offline
Old 07-25-2013, 04:20 AM
  #13037
smittyusmc's Avatar
Originally Posted by yogii
I just remember that the cap screw heads always at the bottom. It doesn't matter if front or rear.
That is why I put them in backwards in the first place I did look at the manual and just figured the it would go in screw up. Well now I know thanks guys for the help.
Old 07-25-2013, 09:20 AM
  #13038
DangerCow's Avatar
Originally Posted by smittyusmc
You guys were right I had them in the wrong way thanks for the help.
A few months ago I changed the oil in my rear diff and reinstalled it upside-down. I went to the track, put it on the ground, and pinned it; the buggy was spinning all it's wheels but sitting in the same spot. I was pretty bewildered before someone else figured it out!
DangerCow is offline
Old 07-25-2013, 06:34 PM
  #13039
The Czechexican's Avatar
That's great.
The Czechexican is offline
Old 07-26-2013, 10:32 AM
  #13040
smittyusmc's Avatar
I ran my buggy for the first time last night and I really wasnt happy with how it drives. Its very twitchy. I put the stock setup on it. Whats a good setup for this car I was thinking going down in diff fluid would help. Thanks for the help
Old 07-26-2013, 10:34 AM
  #13041
Lengthen the wheel base, run 5/3K diff oils
zzztech is offline
Old 07-26-2013, 10:38 AM
  #13042
The first time its always twitchy. You have to "run in " the diffs. Also for me it helped to go down from 10/5 to 7/3 on a low/medium grip clay track
ridgeracer is offline
Old 07-26-2013, 12:06 PM
  #13043
smittyusmc's Avatar
I have the wheel base as far as it can go but I will try the 5/3 oil that is F/R right? Thanks for the help guys. What camber and ride height are you guys running? Just so you know I run on a smooth/small indoor clay.
Old 07-26-2013, 12:34 PM
  #13044
the incubus's Avatar
Trader Rating: 17 (100%+)
You'll also want to check your Slipper to ensure it allows some slip. If you don't have any, the power is instant and will make the car difficult to drive. You don't need much, but it has to have some.
the incubus is offline
Old 07-26-2013, 02:16 PM
  #13045
McD44's Avatar
Trader Rating: 16 (100%+)
21° caster blocks!!!! Made all the difference for me. Once you get used to driving this laser beam it becomes a potent weapon.
McD44 is offline
Old 07-26-2013, 02:25 PM
  #13046
My car isa pretty well dialed in and I have the 21° blocks but have not gotten around to installing them. Will be doing so this weekend. If they really make a big difference, I expect to place top 3 easily every time out. Going to revisit my ESC and receiver mounting position as my RS Pro is far too close to the spur and seems like it has been brushed lightly on the edge by the spur. Goes to show that these little cars are subjected to unimaginable forces while running at speed. My ESC is a full mm away from the spur and still does this. Going to be replacing the 3M servo tape with the super high-end stuff that will not allow it to move a single bit.
Old 07-26-2013, 02:47 PM
  #13047
McD44's Avatar
I think you'll like the 21° blocks.
That is pretty close to the spur. I have my TrakPower ESC 5mm away and haven't had any problems with it moving or rubbing. Using 3M VHB.
McD44 is offline
Old 07-27-2013, 05:56 AM
  #13048
Try to remove the rear roll bar. Move shocks out on arm and drop 5wt in oil at the same time. Long wheelbase and just leave the rest as it is. Worked great for me. Put me 2nd behind xray ace teamdriver Magnus Vässmar last race. The car was very consistant and fast. I didn't like it either with the start setup.
magnushedqvist is offline
Old 07-27-2013, 06:51 AM
  #13049
smittyusmc's Avatar
Thanks guys for all the help I will get that stuff a try. Thanks again
Old 07-29-2013, 09:03 AM
  #13050
-DOZER-'s Avatar
Default Newb DEX410v3
Just ordered my DEX410v3. Should be here on Wednesday. Here's what I have for the build:
Novak Havoc Pro SC
Hobbywing 4WD SCT 3400kv 540 4pole
Savox 1258tg servo
Tresrey servo saver steering crank
Tresrey rear diff inserts
Any advise on known issues would be great. Hope it survives the new triples at WCRC, lol. Thanks!
-DOZER- is offline
