Like Tree22Likes
Old 06-21-2013, 03:45 PM
  #12901
boudin4evr's Avatar
Trader Rating: 18 (100%+)
Default ball cups angled
Originally Posted by Gump
Looking for a solution to a problem...
IU'm running a setup with an insane amount of rear droop. So much that the rims are grinding on the rear outboard ball cups at full droop.
I have switched the car over to a complete RPM ball cup and TC5 ball stud setup, so I can't use the factory 'hooked' ball end (picture below) to solve the problem.
Does anyone make a hooked ball end that will work with the tc5 ball studs AND one that won't pop off easily as the factory durango ball ends do?
Thanks for any help.
JCONCEPTS makes them
boudin4evr is offline
Old 06-21-2013, 04:27 PM
  #12902
the incubus's Avatar
Trader Rating: 17 (100%+)
Hey guys, a friend told me the Associated Spur Gears fit the 410 but I busted out a brand new 81 last night only to find out the center hole is too small. Checked all my Associated spurs and it was the same issue.
Is there a specific Associated spur that I'm missing or are the Durango 410 Spurs unique?
the incubus is offline
Old 06-21-2013, 05:23 PM
  #12903
ekt
ekt's Avatar
The hole does need to be enlarged slightly. RW Racing, RDRP and TD spurs are the only direct fit, that I know of.
ekt is offline
Old 06-21-2013, 06:04 PM
  #12904
Great, thanks. Going away from Associated is proving to be a PITA! LOL
Old 06-22-2013, 07:29 AM
  #12905
boudin4evr's Avatar
get your body reamer out and it doesn't take much! I run the JCONCEPTS silent speed spur gears
Old 06-22-2013, 07:30 AM
  #12906
boudin4evr's Avatar
Default AE to Durango
at least you will not break any front arms or shock shafts going down the straits!
Old 06-22-2013, 08:14 PM
  #12907
Just ordered one of these, been wanting a 1/10 4WD buggy for a long time. It was either this or the new B44.2. Liked the alum chassis and gear diffs.
sgtlt is offline
Old 06-23-2013, 03:30 PM
  #12908
Tired of bending Team Durango front and rear inboard hinge pins? Ya, me too. I actually ran out at an indoor race last winter season and was faced with a dilema... straighten the pin and put it back and hope for the best? .... or.... hmmmm..... here I have this Integy 2.0mm allen driver tool with a busted tip.... and its hardened... and its ti-nitride coated. Let me just cut one up and jam it in and maybe that will work?
I just did a full teardown last Friday night. I had three bent durango inboard hinge pins, and one nice straight golden ti-nitride coated Integy pin made from my busted driver. Its been to three carpet races and two outdoor dirt races. I know whats going back in the car. Good thing I saved all those broken tips!!!
Gump is offline
Old 06-23-2013, 05:45 PM
  #12909
1slash's Avatar
Never broken/bent a single hinge pin myself still running my 2+ year old ones.
but great idea! I will have to keep that in mind when I want to replace mine. I bet some good quality drill bit blanks would work decent too.
1slash is offline
Old 06-23-2013, 06:37 PM
  #12910
so I am going to run my castle 4600 motor and esc. will that be enough power to get this buggy running till I can get a good sensored combo ?
sgtlt is offline
Old 06-23-2013, 08:37 PM
  #12911
DangerCow's Avatar
Yup, ditto, never one problem in about a year, and I crash all-the-time!
DangerCow is offline
Old 06-24-2013, 06:35 AM
  #12912
Aluminum Chassis is not me preference but I really love the design and layout of this 4WD as compared to others. It's very compact and neat but surprisingly heavy. I aim to get a CF Chassis for it as soon as the aluminum is scuffed up enough that it bothers me, possibly even sooner.
Old 06-24-2013, 08:16 AM
  #12913
hobdog's Avatar
Trader Rating: 19 (100%+)
I'm looking for some setup help. The problem I'm looking to get rid of is mid corner to exit, on power my car has a tendency to want to over steer instead of squaring up and powering out. I find myself counter steering because It just continues to rotate. I have played with diff oils a lot and have found I prefer lighter oils because when ever I go 10k or higher it makes the car to twitchy for me. My set up right now is 5k front 3k rear
Front
Long link 2 mm washer on knuckle
Middle on tower stock caster blocks
Inside lower hole on tower for shock position
Out side hole on arm
Rear
Middle on 1* hubs
Inside lower on tower
Inside arms with 2 mm in front and 1 mm in rear
Hubs forward
3 right side up on toe insert
2nd hole from top on shock tower for the shock
Inside hole on arm
hobdog is offline
Old 06-24-2013, 08:45 AM
  #12914
McD44's Avatar
Trader Rating: 16 (100%+)
Front
Rear
Middle on 1* hubs
Hubs forward
Inside hole on arm
21* caster blocks helped me quite a bit.
McD44 is offline
Old 06-24-2013, 09:30 AM
  #12915
Heavy B's Avatar
Default DEX410v3 For Sale
If interested in a very clean DEX410v3 go here:
http://www.rctech.net/forum/r-c-item...-dex410v3.html
Heavy B is offline
