Like Tree22Likes
Old 05-31-2013, 10:58 AM
  #12781
Trader Rating: 16 (94%+)
Ok sweet the lowest I have tried is 10k in front and 5k in rear and it seamed a little loose but I could have been my set up thanks for any advice!!
SFutahrc is offline
Old 05-31-2013, 11:07 AM
  #12782
McD44's Avatar
Trader Rating: 16 (100%+)
I'm pretty new to the car and I'm still experimenting so YMMV
McD44 is offline
Old 05-31-2013, 11:39 AM
  #12783
Ya I'm fairly new to it also I have all the other durangos but this one is certainly different than the others
SFutahrc is offline
Old 06-01-2013, 04:58 AM
  #12784
Trader Rating: 57 (100%+)
What aluminum servo horn are you folks using? I tried a TLR 22 but it hits the antenna.
shagino is offline
Old 06-01-2013, 09:06 AM
  #12785
Tdiddy's Avatar
I'm using the TLR 22 servo horn also and I shaved the end down to not contact anything.
Tdiddy is offline
Old 06-01-2013, 01:37 PM
  #12786
Does Durango make a new 1 degree rear hub that uses a larger outer bearing? The only one I can find is the old style that uses small bearings.
jha07 is offline
Old 06-01-2013, 02:37 PM
  #12787
1slash's Avatar
These are the new 1 degree hubs with the larger outer bearings:
http://www.team-durango.com/part-inf...artNo=TD330007
It's the same item number as the old ones so be carful if you order from an online store as they might still be sending out the older ones.
Another option is the Tresrey ones, only $35 for a set so its a pretty good deal.
http://www.tresrey-usa.com/copy-of-a...ex410-2pcs-v2/
1slash is offline
Old 06-01-2013, 03:00 PM
  #12788
McD44's Avatar
I'm using this racers edge horn. Fits perfectly with no modification.
http://www.racers-edge.com/product_p/rce10380b.htm
McD44 is offline
Old 06-01-2013, 04:41 PM
  #12789
Originally Posted by 1slash
I ran Big bores for the first time today on my DEX410. Feels okay, One thing im not sure about is the setup. I was running Hupos basic shock setup and the front felt very very soft.
I run on a loose track and was getting a very big amount of oversteer. The rear shocks felt fine but the fronts felt too soft. The springs feel decent for the track but the shock oil must be too low. The rebound on the front shocks where too fast for a normal setup in my opinion.
This is the shock setup I was running and as far as the setup sheets go it appears to be what hupo runs on almost all off-road tracks, with minor shock mounting adjustments.
Front:
Spring: Dark Blue
Oil: 35wt
Piston: 4x4.1
Rear:
Spring: Light Blue
Oil: 25wt
Piston: 5x1.3
Any suggestions on a good basic big bore setup for a loose off-road dirt track would be great.
Thanks!
I run
front -
1.6x3
35wt
Dark Blue
Rear
1.6x4
30wt
Light Green
This is in the UK on a track with no jumps and it is awesome!!!!!!! but u mite need to go to 42.5 front 35 rear and increase the rear spring to light blue, i dont no y people run really heavy rear springs like dark green it aint gonna work as well as the setup i posted!!!
av4625 is offline
Old 06-01-2013, 06:09 PM
  #12790
Thanks.
jha07 is offline
Old 06-03-2013, 09:41 AM
  #12791
Heavy B's Avatar
Trader Rating: 18 (100%+)
Little things, or sometimes big ones, called jumps. Also, if you run the ballast weights the lighter springs don't work as well, for me anyway.
Heavy B is offline
Old 06-03-2013, 10:23 AM
  #12792
Trader Rating: 72 (100%+)
Regarding the two-way slipper, when I first put it in, I didn't notice any real handling difference in the car and was turning the same lap times. I check the adjustment by hand every race, but after about two weeks of use I was leading the main and it decided to back itself completely off and the car stopped moving. Needless to say I have a two-way slipper for sale if anyone wants to try one, I wont ever run it again.
patrick is offline
Old 06-03-2013, 12:56 PM
  #12793
I'm interested in trying it. What do you want for it?
jha07 is offline
Old 06-04-2013, 12:04 AM
  #12794
onekiwi's Avatar
When mounting the Reventon Pro would it not be better to mount it 90 to what ive seen here and run a fan beside it to blow air through the esc?
I know space is limited in the 410 but thought it might run cooler
onekiwi is offline
Old 06-04-2013, 09:54 AM
  #12795
Hi there, i just wanna check... when you guys mention diff oils, eg 10k, 5k like above, you guys mean CST right?
Thank you guys in advance.
greatfatshark is offline
