Like Tree22Likes
Old 05-28-2013, 12:58 PM
  #12766
McD44's Avatar
Trader Rating: 16 (100%+)
Thanks ridgeracer! I'm sure I have some washers or shims laying around that will work.
How is that Avante of yours? I always wanted one of the originals when I was a kid.
McD44 is offline
Old 05-28-2013, 01:30 PM
  #12767
I bought one in -88 (still have it) and when the Avante came back in -11 I had to have one. My dream was to make it competitive at club level, but the DEX410 are so much better to drive
Also bought the DMX410 kit, but even with 5mm longer wheelbase it is much more nervous to drive than the DEX410.. Still alot of testing and adjusting to so Im not going to give up on it.
ridgeracer is offline
Old 05-28-2013, 01:43 PM
  #12768
Heavy B's Avatar
Trader Rating: 18 (100%+)
Originally Posted by 1slash
I ran Big bores for the first time today on my DEX410. Feels okay, One thing im not sure about is the setup. I was running Hupos basic shock setup and the front felt very very soft.
I run on a loose track and was getting a very big amount of oversteer. The rear shocks felt fine but the fronts felt too soft. The springs feel decent for the track but the shock oil must be too low. The rebound on the front shocks where too fast for a normal setup in my opinion.
This is the shock setup I was running and as far as the setup sheets go it appears to be what hupo runs on almost all off-road tracks, with minor shock mounting adjustments.
Front:
Spring: Dark Blue
Oil: 35wt
Piston: 4x4.1
Rear:
Spring: Light Blue
Oil: 25wt
Piston: 5x1.3
Any suggestions on a good basic big bore setup for a loose off-road dirt track would be great.
Thanks!
Front:
40wt (Losi)
2 x 1.6mm pistons
Dark green spring
2mm inner limiters
Rear:
30wt (Losi)
2 x 1.6mm pistons
Dark green spring
I have the all 3 ballast weights added to the rear.
Heavy B is offline
Old 05-28-2013, 02:11 PM
  #12769
Front:
Spring: Dark Blue
Oil: 35wt
Piston: 4x4.1
Rear:
Spring: Light Blue
Oil: 25wt
Piston: 5x1.3
Thanks!
Front :
Spring ark blue
Oil: 35wt
Piston : 2x1.6
Rear :
Spring : Light blue
Oil : 25wt
Piston : 3x1.5
I read that Avid are releasing pistons for the Xray 4wd that are drilled with different holes on the same piston. Front : 2x1.1mm and 2x1.5mm. Rear :1x1.1mm and 2x 1.6mm.
Want to try thismyself with the Team Durango taper pistons
Old 05-28-2013, 04:29 PM
  #12770
www.darcdevelopments.com
D.A.R.C 1 is offline
Old 05-28-2013, 05:09 PM
  #12771
Is the link working?
Old 05-28-2013, 06:16 PM
  #12772
1slash's Avatar
Yep working fine for me.
Kit/chassis looks great!
1slash is offline
Old 05-28-2013, 11:52 PM
  #12773
Thank you
We also have a DARC Developments Facebook group and page
Old 05-29-2013, 12:04 AM
  #12774
http://www.oople.com/rc/photos/2013national-epr/
Old 05-29-2013, 01:03 AM
  #12775
SCT4TEN's Avatar
SCT4TEN is offline
Old 05-29-2013, 06:18 AM
  #12776
McD44's Avatar
Anyone using the two-way slipper? I'm assuming it acts like a slipper diff? Makes sense to use it to me.
McD44 is offline
Old 05-31-2013, 09:28 AM
  #12777
Trader Rating: 16 (94%+)
What is the magic diff set up on this buggy. Is it like the desc410 and need to run heavy diff fluid to get it to calm down or what's the key? I have a v3 I'm running on a hard pack dirt track with some ruts and pretty blown up in some of the corners?
SFutahrc is offline
Old 05-31-2013, 09:52 AM
  #12778
McD44's Avatar
I ran 15k/12k to start and found it difficult to drive. Went to 5k/3k and like it much better.
McD44 is offline
Old 05-31-2013, 10:12 AM
  #12779
Did the rear end seam to be loose with 3k in it?
SFutahrc is offline
Old 05-31-2013, 10:49 AM
  #12780
McD44's Avatar
No, it is now less prone to spinning out under power in turns.
McD44 is offline
