Like Tree22Likes
Old 05-25-2013, 06:35 PM
  #12751
McD44's Avatar
Trader Rating: 16 (100%+)
Okay, did some testing today.
I liked the car with a front 1.5mm bar only. I have slim bores, dark blue/2x1.3/35wt/front, light blue/3x1.3/27.5wt/rear, and 35g of weight added to the rear. Loosened the slipper a bit and went to 5000/F, 3000/R on the diffs. The car was definitely easier to drive with this setup but I'm still not 100% happy with it. Getting closer though...
I see that many are recommending to limit the droop in the rear to settle that car a bit yet I see many setup sheets indicating full droop plus unscrewing the shaft ends 2 turns. Wassup with that?
McD44 is offline
Old 05-25-2013, 08:00 PM
  #12752
R/C Tech Elite Member
Trader Rating: 520 (100%+)
A lot of these set-ups are on blue grooved, swept, high bite tracks..Most of us don't usually get to see that type of surface very often if ever. So, when using someone else's set-up, we have to take that into consideration when setting up our car, and make necessary changes..
flame56mx is offline
Old 05-26-2013, 08:48 PM
  #12753
Trader Rating: 57 (100%+)
How do you folks change the motor? Old school wrenches or take out the 4 screws from the bottom?
shagino is offline
Old 05-26-2013, 08:56 PM
  #12754
Jochim_18's Avatar
screws from the bottoms is a lot easier.
Jochim_18 is offline
Old 05-26-2013, 09:56 PM
  #12755
I use a short 2.0 hex driver, and with the pack out of the car you should be able to get a straight shot at the screws..works for me..
Old 05-26-2013, 09:58 PM
  #12756
fifi's Avatar
fifi is offline
Old 05-27-2013, 06:32 AM
  #12757
Thanks for the responses. I don't want to do this whenever I change a pinion or the motor
Flame56mx,
Which wrench? My dynamite doesn't cut it.
shagino is offline
Old 05-27-2013, 07:37 AM
  #12758
Flame56mx,
I think this may be a combo of 2 different ones, but it works..
Old 05-27-2013, 11:25 AM
  #12759
Thanks. Mines is about an inch tool long. I wonder if this or a ball end would work.
http://www.amainhobbies.com/product_...-Wrench-TLR-22
shagino is offline
Old 05-27-2013, 12:35 PM
  #12760
1slash's Avatar
If you have a wrench with a replaceable tip you could always take off the tip and grind it down a bit until it's just the right length.
I generally just use the old school wrenches when changing gear mesh or pinions as you just have to loosen the screws off. But if it's to clean out or replace the motor then it's faster and easier to remove the bottom 4 screws.
1slash is offline
Old 05-27-2013, 06:12 PM
  #12761
McD44's Avatar
Quick question on the Tresrey rear diff hoop. Is it the same exact dimensions as the TD part?
McD44 is offline
Old 05-27-2013, 11:05 PM
  #12762
Mopar's Avatar
Yes
Mopar is offline
Old 05-28-2013, 06:32 AM
  #12763
I have to shim mine to clear the lipo batt..
ridgeracer is offline
Old 05-28-2013, 07:34 AM
  #12764
McD44's Avatar
What are you using for shims? How much did you have to shim?
McD44 is offline
Old 05-28-2013, 12:36 PM
  #12765
Sorry for a late reply..
Im using the gold servo washers, are they 1mm or 0.5mm ?
