Like Tree22Likes
Old 04-16-2013, 12:07 PM
  #12631
majorsmx521's Avatar
Trader Rating: 44 (100%+)
Default forsale thread
posted a very nice dex410v3 with tons of extras
in forsale thread for anybody wanting a bind and drive with enough parts for a couple seasons
majorsmx521 is offline
Old 04-16-2013, 10:35 PM
  #12632
Default Offset hex
Where can I find + offset 14mm hex ?
zzztech is offline
Old 04-17-2013, 05:50 AM
  #12633
I don't know if any one makes them. I used the losi 22 1.5 mm hex and the losi shim from the non-extend losi hex (the plastic one). It fits fine you need the parts below. I only had the 1.5 mm hex. The 1.5 mm fit fine but you might want to try the .75 mm. When I get home I will post pics if I remember.
http://www.amainhobbies.com/product_...m-Width-TLR-22
http://www.amainhobbies.com/product_...cer-Set-TLR-22
Now if you are like me and own a ton of 12 mm hex this works great. But its kinda useless if you own all 14 mm.
Ivegotklas is offline
Old 04-17-2013, 06:30 AM
  #12634
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
I know Exotek used to make them. I bought a set. Not sure of anymore though.
Bman's 3XNT is offline
Old 04-17-2013, 02:30 PM
  #12635
Andy63's Avatar
Hello!
I have much problem assemble my Dex410v3. One of it is my Bevel Gear does not fit into the gear input driveshaft. I cant even tigthen my screws so it does not fit at all. Anyone know if this is something common or should i contact my hobbyshop for new ones??
//Kind regards
Andy63 is offline
Old 04-17-2013, 04:38 PM
  #12636
Trader Rating: 72 (100%+)
They can be a very tight fit, we usually file down the hex on the outdrive a little so the gear slides on and off easily.
patrick is offline
Old 04-17-2013, 04:42 PM
  #12637
Andy63's Avatar
Well, the biggest problem is i cant get the gear all the way in. I cant adjust so i dont get a sloppy gearbox :S
Andy63 is offline
Old 04-17-2013, 06:55 PM
  #12638
P6
exotech doesnt have the 6.25 hexs anymore i cant find them anywhere but they do have the 4.75 hex i have looked around and found for my dex210
P6 is offline
Old 04-17-2013, 07:13 PM
  #12639
tobamiester's Avatar
Trader Rating: 360 (100%+)
Originally Posted by Andy63
Hello!
//Kind regards
Yup, Get a file and file down the edge of the hex on the outdrive until it slips on and off easily. Had to do this on 410's I've owned.
Also, pay attention the diff build guide
tobamiester is offline
Old 04-18-2013, 11:23 AM
  #12640
1slash's Avatar
Does anyone know the part # to the 1 degree rear hubs? I have looked around and cannot seem to find them...
Also does anyone else have issues with the rear outer hinge pins backing out of the hub? I have tried brand new hubs with the set screw in very tight and still after a 6 minute heat my pin is backed out around 10mm's. (no issues with the front hinge pins)
if it makes any difference im using the older style hub with the set screw on the outside along with the smaller outer bearing.
Thanks.
1slash is offline
Old 04-18-2013, 02:15 PM
  #12641
mdl060374's Avatar
Originally Posted by 1slash
D
Thanks.
Are you locktighing the grub screw in place? I similar problems so I just went with the Tresrey rear hubs. Then I went too tight which caused them to snap frequently (evens lunsfords)..
The key is to use locktight, and then tighten so it makes slght contact with the groove, but you gotta find the sweetspot..
mdl060374 is offline
Old 04-18-2013, 02:36 PM
  #12642
Cameron Kellogg's Avatar
Trader Rating: 45 (100%+)
I have had the same issue on the outer rear hinge pins. It's not the place to crank down the set screw. You will bend and snap them often if you overtighten them. Loctite and just barely snug up the set screw. No problems after I started doing that.
Cameron Kellogg is offline
Old 04-18-2013, 02:45 PM
  #12643
Andy63's Avatar
Thank you!
Andy63 is offline
Old 04-18-2013, 04:36 PM
  #12644
1slash's Avatar
Hmm even locktite on the plastic hubs?
1slash is offline
Old 04-18-2013, 05:42 PM
  #12645
Trader Rating: 19 (100%+)
No loctite on plastic hubs, if you need to get through a raceday and dont have parts you can use a dab of CA. But the best is to replace them. Here are the plastic one degree hubs: http://www3.towerhobbies.com/cgi-bin...?&I=LXCCTJ&P=7. The pic shows the old style with the small outer bearing, but I'm thinking there was a running change with the same part number. Searches of Tower and TD's website showed the same pic and part number.
But as said above, the Tresrey hubs are the hot ticket. We have a set on Cush's buggy with over two seasons of racing and they are still nice and tight. And about as bulletproof as you can get
Jonny5 is offline
