Like Tree22Likes
Old 04-08-2013, 06:30 AM
  #12616
Desert Runner's Avatar
Great !
would you please post a link of the that 4600kv CM36 that run on 4S ?
i searched and it's only showing that this motor only takes 3S max
Desert Runner is offline
Old 04-08-2013, 06:58 AM
  #12617
Reflexia's Avatar
Looks like CC finally dropped the non-quad motors ( CM36 v2 ). Might find one on ebay.
maybe this is more in your realm
http://www.hobbyking.com/hobbyking/s...Brushless.html
Says it can do 21v max and its a stubby 50mm long.
Still think you'll just blow it up tho, 4wd is a balancing act with normal motors on 2s!
Reflexia is offline
Old 04-08-2013, 07:31 AM
  #12618
Thanks buddy : )
that hobbywing motor is ultra cheap ! but it might takes so long to reach here because HK doesn't offers ups or fedex as shipping method , and the ems service is very bad here, few days ago they deleivered my parcel to another address and i ended up empty hands .. i filed a complain and i'm sure they will not get it back b/c the reciepiant simply took it a way
sorry for the side talk , i'll see if amainhobby got a similar to this motor.
Thanks again .
Old 04-08-2013, 03:45 PM
  #12619
8ight-e's Avatar
Trader Rating: 58 (100%+)
Best bet for cost savings and performance is the hobbywing v2.1 esc paired with a xerun 8.5t motor (combo deal), if you have a small enough track and can deal with a 10.5 motor you can save even a few more bucks and get the extreme stock combo instead. May find a good deal on the hobbywing v3.0 esc as well for a few bucks more. falconsekido
8ight-e is offline
Old 04-11-2013, 04:52 AM
  #12620
ColbyRichards's Avatar
What's needed to get 12mm hexes on the rear of this car? I grabbed JC hexes for an associated and was hoping they would work
ColbyRichards is offline
Old 04-11-2013, 07:32 AM
  #12621
Are the Tresrey high grade ball bearing set any good?
MySlowZ is offline
Old 04-11-2013, 07:45 AM
  #12622
hobdog's Avatar
Trader Rating: 19 (100%+)
Has anyone used any other shock O-rings then the stock ones. I don't have access to them and have a race coming up
hobdog is offline
Old 04-11-2013, 08:06 AM
  #12623
huzzler's Avatar
Check this out might help you.
http://www.petitrc.com/setup/durango...herWheels.html
huzzler is offline
Old 04-11-2013, 10:03 AM
  #12624
crlock's Avatar
Hi guys, quick question. Are the carbon fiber shock towers a really good upgrade over the aluminum ones?
crlock is offline
Old 04-11-2013, 12:49 PM
  #12625
I bent my aluminum ones, so I would say yes.
jha07 is offline
Old 04-13-2013, 12:08 PM
  #12626
OK, i'm building my shopping cart for the needed items including the dex410.
anyone pls advise -with links if possible- with good traction F/R tires and with good ( not high end ) servo ?
i recieved an email that mamba max pro with trinity 4 or 4.5t is a good high end combo to get.
Thanks for the help guys : )
Old 04-13-2013, 12:19 PM
  #12627
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
That's a crazy motor! I would go in the 6.5-8.5 range depending on your track. As for tires, again depends on your track. I know the biggest thing that helped with my car is the 21 degree front castor blocks. As long as you have all the aluminum hinge pin holders the other item would be the aluminum servo saver. Savox has a decent servo, 1258 I think? Good luck....
Bman's 3XNT is offline
Old 04-13-2013, 02:19 PM
  #12628
Originally Posted by huzzler
eh not really, i have the durango front hex that is the same size as ae wheels so i was just looking for info on the rear and thought you could just bolt on a b4.1 hex. I'll do a little more looking. thanks for the help though!
Old 04-13-2013, 08:07 PM
  #12629
Thanks Bman's . i'm a basher and always looking for extreme builds .
I'm looking for a good grip tires .
Old 04-13-2013, 08:36 PM
  #12630
yogii's Avatar
I finally was able to take out my DEX410v3. Wow that was fun. I had to make some adjustments. This has to be the funnest 1/10 scale buggy I have ever drove. I need to make other diff oil adjustment. I did manage to brake a part that i think everyone will say how. I was driving crazy! The rear carbon fiber shock tower. It broke at the camber ball joint. The next one I put on i'm going to super glue that area on both sides, and on the back side i will use a washer. Seems like when to much pressure is applied to it the nut side from the 6 points puts extra force on the holes. Remember guys there is know a total of 9 places to have your ball joint for the camber on this bulkhead. I would like to know if anyone knows what other ball joints will work here? That have a longer studs on them, this way on the ball side i can put a 2mm spacer that will line it up a little better with the bearing block. Then I will use a nice washer on the other end to support the back side.
yogii is offline
