Like Tree22Likes
Old 03-25-2013, 10:17 PM
  #12571
mdl060374's Avatar
Originally Posted by Jaz406
Just got a used but good condition dex 410. How can I tell what version it is?
did it come with big bore shocks? (blacks springs with red caps that screw in the bottom half..)
mdl060374 is offline
Old 03-26-2013, 03:08 AM
  #12572
hbxlosidriver's Avatar
hey guys, i was wanting to get a team durango dex410r v3 kit and wonder what it needs to be completed. what oils are need and weights they are? and other things needed to complete it. your help is well appreciated.
hbxlosidriver is offline
Old 03-26-2013, 01:54 PM
  #12573
Its hard to say, I know that a true DEX410V3 (Ive done enough research lol) will have carbon fine tune f/r shock towers, alum. f/r with the new "insert" style r/r hanger, sway bar kit, nitrate (gold) colored shock shafts, gold alum. index spacers and conical ball stud spacers, bigbore 12mm shock package, Alum. knucles (front) this is the main parts just to name a few. sometime people "BRAND" a car too sell it and offer flashy upgrades. but the real way to tell what version you have, is buy new (if your pocket allows.) . unless your deal is fantastic and the "grey" areas are not that important.
I am a durango enthusiest/racer . JMHO. I hope this helps.
jonsee is offline
Old 03-27-2013, 12:24 PM
  #12574
1slash's Avatar
I thought it would be finnaly time to update my old Dex410 diff seals so they don't leak anymore.
As far as the fix goes is this thread still up to date on what you need? http://www.rctech.net/forum/electric...-shim-fix.html
Or is there a better seal to get now?
Thanks.
1slash is offline
Old 03-27-2013, 01:18 PM
  #12575
Trader Rating: 38 (100%+)
I use the DEX408 series shock seals as the replacement diff seals in my 1/10 410 and 210 cars/trucks...haven't had a leak yet. Follow the build guide at the link below. I've had nothing but success with the kit manual shimming.
http://www.team-durango.com/in-the-p...rticle_id=3193
jzwolen is offline
Old 03-27-2013, 06:14 PM
  #12576
fifi's Avatar
what about using #TD310251 gear diff main seal from dex210?
Don t have them to try but they should size okay.
Why 4wd gear diff doesn t have seals and 2wd has?
fifi is offline
Old 03-28-2013, 02:47 PM
  #12577
Hey,
diff seals problem was fixes in DEC410v3 ?
farm is offline
Old 03-28-2013, 03:45 PM
  #12578
Reflexia's Avatar
The 4wd does have seals.. Mine have never leaked. ( dex410v3 ). They are different in the dex410v3, same on the desc410v2. Or are you talking about it not having a gasket against the ring gear (Which could make sense)?
I find the only trick is making sure the outdrive/cup hex is sanded a little so that the gear slips on and off easily making the whole diff housing fit nicer. Those I've seen who have leaking housings have not done this. If you have to force the diff gear on the hex, its going to be a problem ( and getting it off is a real hassle ).
Reflexia is offline
Old 03-28-2013, 04:21 PM
  #12579
fifi's Avatar
I am talking about this
To they fit the 4WD diff.
fifi is offline
Old 03-28-2013, 04:39 PM
  #12580
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
I still have the original cases from my 09 spec! They never leaked. I lightly sand the plastic case in a figure eight motion every time I change the fluid. It takes the high spot off around the threaded holes and seal up tight. Just my .02
Bman's 3XNT is offline
Old 03-28-2013, 05:20 PM
  #12581
Reflexia's Avatar
Those are gaskets. Can't tell if they fit the 4wd. Not sure you need them, as the 4wd diff meets the ring gear, there is a lip. As long as the top of the diff housing is flat and the housing is able to be closed completely, this should not leak. That's the crucial part tho (as Bman says, every time you take it apart, make sure that the thread has no material popping out), should be golden. Could always put a little green slime around the lip on the gear I guess if that's still a problem.
Reflexia is offline
Old 03-31-2013, 11:02 PM
  #12582
Default 410 in action
I thought I would share a pic of mine in action from last weekend.
Cheers,
Ro
Attached Thumbnails Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-untitled4.jpg
nitro-rob is offline
  #12583
double post
Old 04-02-2013, 09:57 AM
  #12584
hobdog's Avatar
Trader Rating: 19 (100%+)
What other options are around for slipper pads, and is there any one that makes wraps for the stock body? I looked around on upgrade rc and I didn't find anything
hobdog is offline
Old 04-02-2013, 02:05 PM
  #12585
crlock's Avatar
Hi guys, just my half of a cent.
I would recommend to put a little bit of threadlock on the pins in the front and rear drive Shafts, I had one of them back out a little and ate trough the front tower
Cheers
crlock is offline
