Like Tree22Likes
Old 03-10-2013, 03:08 PM
  #12466
desk_jockey's Avatar
Originally Posted by symmetricon
I played around with my setup this weekend, and found that rear was much more planted with 3k diff oil. The front however still had too much on power steering. I tried lower the front to 5k but had too much turn in, but it felt more stable. I think I'm gonna go back up to 10k and get rid of some anti-squat....
On a side note, Damn this thing is durable! The way I was driving would have left my b44.1 in pieces...
I am currently runnin 7k front and 3k rear. I am thinking I am going to bring them closer in line, perhaps 7/5 or 7/7. Thanks for the idea.
desk_jockey is offline
Old 03-10-2013, 03:09 PM
  #12467
Originally Posted by onekiwi
Ill try and get some pics of a mod I did.
I added 5gms of weight on the outer rear hubs, helped out a lot with the rear washing out, but im on carpet using slicks indoors
Wheel balancing weight with a hole drilled then screwed into the unused hole in the rear hub
Do you run the chassis weights? I hate how much weight I need to add to this thing to get it to hook.
Old 03-10-2013, 10:37 PM
  #12468
ekt
ekt's Avatar
The DEX410 was initially designed for NiMH packs, with the change to lipos many people recommend the weight to make up the difference.
ekt is offline
Old 03-11-2013, 12:22 AM
  #12469
onekiwi's Avatar
Anyone know if Atsushi Hara has his reedy setup anywhere? Same with the other TD drivers?
onekiwi is offline
Old 03-11-2013, 12:38 AM
  #12470
hotdognobun's Avatar
Trader Rating: 32 (100%+)
been looking everywhere too! only got ryan lutz setup
http://www.petitrc.com/setup/durango...yRace20130126/
hotdognobun is offline
Old 03-11-2013, 03:25 AM
  #12471
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
I run 7/3 also. Unless it is super high traction then maybe 7/5 or 10/5. Running squared diffs just makes the car to aggressive IMO. If you can't keep the rear behind the car try a lighter rear diff oil. After the weight set and slipper adjustment of course.
Bman's 3XNT is offline
Old 03-11-2013, 04:10 AM
  #12472
8ight-e's Avatar
Trader Rating: 58 (100%+)
Agreed.. Our clay tracks traction has changed some and 10/10 use to be great, but now I'm down to a 10/5 setup for diff fluids. I also ended up adding just the rear sway into my setup, both changes yeilded good results and slightly faster lap times.
8ight-e is offline
Old 03-11-2013, 04:30 AM
  #12473
R/C Tech Elite Member
Trader Rating: 520 (100%+)
Haven't seen anything yet either.
flame56mx is offline
Old 03-11-2013, 05:32 AM
  #12474
onekiwi's Avatar
Theres only the under the hood stuff there from Hara
Anyone know if hes active on rctech?
*I sent him a message on FB see if I get anything back
onekiwi is offline
Old 03-11-2013, 05:39 AM
  #12475
Thats all I have seen also..
Old 03-11-2013, 05:47 AM
  #12476
8ight-e's Avatar
Mines on rails if you guys are looking for a starting point. I have not used on low bite, but med to high this setup is working great, I'd just edit tires as needed then tweak to your style.
link
8ight-e is offline
Old 03-11-2013, 08:38 AM
  #12477
Default Static / Constant front toe
So I've noticed with the kit default setup there is front toe change at full range of movement. At full droop the front wheels are slightly toe in. When front end is fully compressed the wheels have slightly toe out.
What settings / spacers are necessary to keep the front toe consistent throughout the entire compression range?
Thanks in advanced.
Vincent_Diesel is offline
Old 03-11-2013, 12:46 PM
  #12478
DEX410 1. on the podium in the Euro Offroad Series, round 3 !
ridgeracer is offline
Old 03-11-2013, 04:03 PM
  #12479
jmackani's Avatar
Trader Rating: 14 (100%+)
Thanks in advanced.
This is a result of camber gain and this is why you do all your settings at ride height. Your camber change will affect the toe also.
jmackani is offline
Old 03-11-2013, 06:57 PM
  #12480
Hi, I am building a Dex 410R and in my build I am stuck. On page 16, bag C, part # 310039. I am having a hard time installing this plastic ring on the rear and front diff dog bone. I tried installing to the back diff dog bone and broke the plastic ring. My question, do you really need this piece covering the pin? I did follow the instructions and used the small set screw with lock tight. Will it really loosen up and fall out? Can I use something else? Anyone out there in forum world please help me and give me a good tip to move forward on this build.........thanks
davidcisco is offline
