Like Tree22Likes
Old 03-07-2013, 01:11 AM
  #12451
luko's Avatar
Can anyone inform me of the right ball cups to use on this little beautie?do i have to change balls studs to make it rock solid?
luko is offline
Old 03-07-2013, 01:45 AM
  #12452
hotdognobun's Avatar
Trader Rating: 32 (100%+)
i went with lunsford titanium set. been 14 packs and have no need to replace or any other issues.
if you are using stock studs use this
http://www.amainhobbies.com/product_...-End-Set-Black
hotdognobun is offline
Old 03-07-2013, 03:17 AM
  #12453
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Originally Posted by hotdognobun
has anyone tried the Tresrey universial frt/rear shafts? i have yet to snap the stock CV so wonder if the Tresrey are stronger?
I have been running then for a year or so. They do seem to be better quality. I know the cvd pins are a tad longer like Gump was mentioning.
Bman's 3XNT is offline
Old 03-08-2013, 02:32 AM
  #12454
luko's Avatar
Talking
Thanks for that. Hey nice rack your running there.
luko is offline
Old 03-08-2013, 07:55 AM
  #12455
Blown up's Avatar
I've been running the Tresrey's w/no breaks. Plus they look really cool
I was looking to get up there Sat but this snow may keep me busy. Bummer
Blown up is offline
Old 03-08-2013, 08:01 AM
  #12456
symmetricon's Avatar
Trader Rating: 27 (100%+)
So I have been reading that a lot of you guys have been bringing the rear diff oils closer in thickness to the front. I am familiar with what it will do in a 3 diff setup, but not exactly sure if this is the setup change I am looking for. I have one problem area with the buggy. There is a rhythm section a double double that goes into a 90degree turn. If I get on power while landing while steering, the rear washes out uncontrollably. Any suggestions?
symmetricon is offline
Old 03-08-2013, 08:08 AM
  #12457
Rob Phillips's Avatar
I'm running the stock "HD" cups and haven't had any issues with them popping off.
If you want to replace them, go with TLR balls and cup or AE (TC6) balls and cups. I prefer the TLR ones since they are 4.3mm spec'd.
The Lundsford kit is nice, but expensive. I've had issues with snapping Ti ball studs when used in aluminum towers, carriers and such.
Rob Phillips is offline
Old 03-08-2013, 03:11 PM
  #12458
Default Sway Bar ball joints
So how does anyone tighten the sway bar ball joints (the ones on the A Arm). On one end is a hex screw and on the other end is a hex pivot ball. How do you tighten these together? It seems there is no room on the other end to get a Allen Key or hex driver driver in there.
I'm puzzled.
Vincent_Diesel is offline
Old 03-08-2013, 03:26 PM
  #12459
I'm puzzled.
I use a small flat screwdriver and jam it in the hex pivot ball to keep it from spinning as I tighten the screw. It's still a pain in the ass, but works.
jha07 is offline
Old 03-09-2013, 02:52 AM
  #12460
onekiwi's Avatar
I use a ball hex in the arm, can be a bit hard to get in but works really well, OR use small/thin needle nose pliers on the rim of the piviot
onekiwi is offline
Old 03-10-2013, 05:38 AM
  #12461
jelly's Avatar
Originally Posted by 8ight-e
Do not bother until your stock parts wear out.. 'bling bling', these will reduce lap times by 0.0 seconds.... invest in the weight set, the rear alum diff braces or sway bars way before the djoints.
what does the rear aluminium diff brace help with?
jelly is offline
Old 03-10-2013, 06:17 AM
  #12462
desk_jockey's Avatar
I am also having nearly this exact same issue. Last week was my first race with it. Through the night I added the three TD weights, plastic chassis brace, and 1 degree hubs and it got better but its still not as planted as my xx4 is. Sorry, not trying to hijack . . .
desk_jockey is offline
Old 03-10-2013, 06:39 AM
  #12463
I played around with my setup this weekend, and found that rear was much more planted with 3k diff oil. The front however still had too much on power steering. I tried lower the front to 5k but had too much turn in, but it felt more stable. I think I'm gonna go back up to 10k and get rid of some anti-squat....
On a side note, Damn this thing is durable! The way I was driving would have left my b44.1 in pieces...
Old 03-10-2013, 09:45 AM
  #12464
Blown up's Avatar
This sway bar ball joint in the a-arm setup is a little funky. I was thinking about using balls w/o threads and tapping into the arm w/a longer screw like the DESC.
Blown up is offline
Old 03-10-2013, 11:36 AM
  #12465
onekiwi's Avatar
Ill try and get some pics of a mod I did.
I added 5gms of weight on the outer rear hubs, helped out a lot with the rear washing out, but im on carpet using slicks indoors
Wheel balancing weight with a hole drilled then screwed into the unused hole in the rear hub
onekiwi is offline
