Like Tree22Likes
Old 08-18-2010, 01:53 PM
  #1231
savageboy69's Avatar
Trader Rating: 93 (100%+)
i went from a b44 to a durango and for me it was a night and day difference, i went from have a few fast laps every now and then in my b44 to consistent fast laps over and over, never hit a 11 lap run at my home track with the b44 and first time out did it with the durango, i guess it just comes down to driving style, to me the durango drives like a 1\8 scale. only problem i had is the diffs leak, but the shocks are solid
savageboy69 is offline
Old 08-18-2010, 06:36 PM
  #1232
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Has anyone tried the R plastic side plates on their regular DEX? I just ordered some as they were only $12. I want to see if it gives it some more flex.
Bman's 3XNT is offline
Old 08-18-2010, 07:38 PM
  #1233
dangerwr's Avatar
Well, I just picked up the DEX410R today and the guy at the local indoor track has ran the DEX410 since last year. Likes the plastic side plates because they offer more flex. That is all I will pretend to know at this point . . .
dangerwr is offline
Old 08-18-2010, 09:16 PM
  #1234
R-E-A-P-E-R-'s Avatar
Danger you suck bro. I will have one soon though.
R-E-A-P-E-R- is offline
Old 08-18-2010, 09:31 PM
  #1235
mdowney's Avatar
Trader Rating: 21 (100%+)
Default Futaba Rx in the Rango
I'm switching to a 4PK because I need the 4th channel for my crawler (selling the DX3R and Rx's: http://www.rctech.net/forum/r-c-item...receivers.html).
Anyone know if the FASST 603/604 Rx's will fit in the Rango? I don't know how much bigger they are than the SR3100's.
mdowney is offline
Old 08-18-2010, 09:43 PM
  #1236
dangerwr's Avatar
I use a 4PK and have the 603FF receivers. What I have seen will require some creative ingenuity to get these receivers to fit. I think I am going after the Futaba Micro (6004FF) . . .
dangerwr is offline
Old 08-18-2010, 09:45 PM
  #1237
dangerwr's Avatar
Ha-ha! Ah man, you will get yours soon then time for some test & tune! B44 wheels fit these right? Not a big fan of the Durango wheels . . .
dangerwr is offline
Old 08-18-2010, 10:21 PM
  #1238
grapejuice's Avatar
Trader Rating: 152 (100%+)
That's me Hands down drives way better then my old one, not running a sway bar either, could be part of it to.
grapejuice is offline
Old 08-18-2010, 10:24 PM
  #1239
dangerwr's Avatar
There he is! I have always read that a rear sway is a must for any 4x4 10th scale. Maybe not this one?
dangerwr is offline
Old 08-18-2010, 10:32 PM
  #1240
ABBOTT's Avatar
The Futaba rx will fit with a sphere tc without issues. If you want it to be clean be willing to make your servo and esc leads custom lengths no matter what setup you use! We where looking into getting the Novak in there tonight and its going to take some work.
ABBOTT is offline
Old 08-18-2010, 10:43 PM
  #1241
mdowney's Avatar
What's a "sphere tc"?
mdowney is offline
Old 08-18-2010, 10:47 PM
  #1242
ABBOTT's Avatar
Was meaning the older LRP Sphere Comp esc.
ABBOTT is offline
Old 08-18-2010, 10:54 PM
  #1243
dangerwr's Avatar
Which Novak ESC? Let us know how it goes! I want to use the new Kinetic which has a slightly smaller footprint than the GTB but was not sure if it would fit with the Futaba Rx.
dangerwr is offline
Old 08-19-2010, 01:00 AM
  #1244
mdowney's Avatar
Originally Posted by Blackstring
I chose tall 8mm because they were the same as durangos so the camber gain will be the same and the stud isnt too long.
also I have been using the losi grey "HD" ball cups with much success. They seem to be way stronger than rpm's. plus they dont get sloppy as fast.
Which Losi ball cups are you using: the HD 30* or the "Extra Rigid" grey cups?
- HD: http://www.amainhobbies.com/product_...ic-Rod-Ends-12
- Extra rigid: http://www.amainhobbies.com/product_...l-Cups-16-Gray
Also, here's a link to the Associated TC5 long 3x8mm ball studs (x2) that work with these and the RPM cups:
http://www.amainhobbies.com/product_...Associated-TC5
mdowney is offline
Old 08-19-2010, 04:57 AM
  #1245
I don't run any, and mine handles great at my local track......
