Like Tree22Likes
Old 02-05-2013, 07:07 AM
  #12166
crlock's Avatar
Hi guys, i finnally bought this buggy, and i'm really excited. this is the first kit i will build, any tips for a noob here? pinions for example
This'll be my setup
Castle sidewinder esc - 1410 3800kv 4 pole motor
Proline caliber M3
Protek 100T servo
Turnigy nano tech 2s 5100mah saddlepack
spektrum receiver
wich suspension setup would you recommend for a very loose dirt track?
cheers
crlock is offline
Old 02-05-2013, 07:24 AM
  #12167
I bought this kit on sunday. Last night I was assembling the CVDs and noticed that one of the driveshaft bushings was not threaded. Has anybody run into this? Its weird that 1 of the 4 in the kit wouldn't be threaded. The part must have slipped through QA.
Ivegotklas is offline
Old 02-05-2013, 07:29 AM
  #12168
Is it ok for DEX410RV3 ?
MOULDED SHOCK TOWER SET - Part No: TD330407
This moulded shock tower set is manufactured from strong and reliable composite material for DESC410 truck.
Attached Thumbnails Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-330407m.jpg
mos-leung is offline
Old 02-05-2013, 07:31 AM
  #12169
Trader Rating: 101 (100%+)
Andy you should've bought a b44.2. Lol
Revo Dan is offline
Old 02-05-2013, 07:34 AM
  #12170
hotdognobun's Avatar
Trader Rating: 32 (100%+)
Originally Posted by zzztech
Yeah I green slimed the O ring. The leak doesnt come from there
have you had any hard crashes? my diff case opened up a little causing leak
hotdognobun is offline
Old 02-05-2013, 07:56 AM
  #12171
Other then this defective part I really like the DEX410 so far. I don't think I would have like the B44.2 nearly as much.
Old 02-05-2013, 01:56 PM
  #12172
racingdan's Avatar
no,those towers are for the DESC410V2
racingdan is offline
Old 02-05-2013, 03:04 PM
  #12173
ABBOTT's Avatar
Curently run 20/7 in my diffs, what should I expect if I try the 10/10 that is so popular with Joern and lutz? Smooth track with pretty high traction (smac trac). I am looking for alittle more low speed steering without getting the rear end loose. I do not like a car that steers from the back.
ABBOTT is offline
Old 02-05-2013, 03:08 PM
  #12174
R/C Tech Elite Member
Trader Rating: 520 (100%+)
You will definitely get more steering. The first time I drove mine I felt the same way, I couldn't get used to the way it rotated..I went to 12/5 and it felt good until I pushed it, and it pushed back, badly. I am at 7/7 right now, and it feels good, good steering, and doesn't over rotate..
flame56mx is offline
Old 02-05-2013, 05:15 PM
  #12175
Originally Posted by dangerwr
What piston blanks are people using to make 2 x 1.7mm etc. for the BB shock? I ordered a set of blanks from Tresrey but are not designed to fit the stock shaft. They use 2 e-clips--wish I would have looked closer!!
i use the Tresrey ones…i just used some spare diff screws because they're counter sunk and they center the piston up on the shaft…the shaft has enough threads for the length of it if you didn't want to cut them down some and i use the stock bottom washer and no issues...
bLamey470 is offline
Old 02-05-2013, 05:33 PM
  #12176
dangerwr's Avatar
You is the man! Cheers
dangerwr is offline
Old 02-05-2013, 06:07 PM
  #12177
8ight-e's Avatar
Trader Rating: 58 (100%+)
10/10 is the ticket on med to high bite tracks.. I run on a clay pretty high bite indoor track and it's on rails.
8ight-e is offline
Old 02-05-2013, 07:51 PM
  #12178
Guillermito's Avatar
Hi, I have a Tekin Redline G2 7.5T with Tekin RS Pro, and would like to know how many teeth should have pinion that I have to use.
Thanks! Best Regards.
Guillermito is offline
Old 02-05-2013, 09:18 PM
  #12179
DBL15's Avatar
22 or 23 pinon and 87 spur mate but make sure you check temps every few minutes when your testing just to be safe
run in duel mode as well will drop heat issues a bit
DBL15 is offline
Old 02-05-2013, 09:20 PM
  #12180
DBL15's Avatar
This'll be my setup
Proline caliber M3
Protek 100T servo
spektrum receiver
cheers
i honestly think you will struggle with that motor and esc combo mate a 4 pole is way to much for these buggys
most run between a 6.5 to 8.5 and have power to burn i think your combo will far out way your set up issues if you have any
DBL15 is offline
