Like Tree22Likes
Old 02-04-2013, 05:09 PM
  #12151
symmetricon's Avatar
Trader Rating: 27 (100%+)
Originally Posted by hotdognobun
looks like ball diffs just without the balls! lol.... putting it together now will update once i test it
Hope it works better than the decoupled slipper on the sc10 4x4....
symmetricon is offline
  #12152
Briguy's Avatar
Trader Rating: 125 (100%+)
Originally Posted by anythinggas
I have another issue need more rear traction, buggy wants to spin when i apply the throttle even if i'm rolling. any suggestions would be helpfull. running a tekin rs w/reedy 8.5 with a 87/20.
What setup are you running ? Track conditions ? Running any weight in the rear ? 1* rear hubs ?
Briguy is offline
Old 02-04-2013, 05:34 PM
  #12153
anythinggas's Avatar
Trader Rating: 21 (100%+)
track is packed clay, medium to low traction, running the rear weight kit, barcodes super soft front and rear, 7000 front 3000 rear, light blue rear spring dark blue front spring, 45 oil front/rear, 1* rear hubs.
anythinggas is offline
Old 02-04-2013, 05:41 PM
  #12154
How much anti-squat?
Old 02-04-2013, 06:10 PM
  #12155
not sure have the +2 on top and the 4 bracket on the bottom
Old 02-04-2013, 06:32 PM
  #12156
DBL15's Avatar
not for an 8.5 , 21-22 at the most . 24-26 is for a 10.5 .
nah mate look at all the tekin set ups mate there running 22 on 6.5 motors i personally run a 21 on a 6.5
would have to be 24 or more on a 8.5 IMO but check temps
have you tried running clay tyres on the clay indoor track mate ? not softs that might help grip ?
DBL15 is offline
Old 02-04-2013, 06:39 PM
  #12157
Briguy's Avatar
Change that +2 for a -2 . +2 is high roll center .
Briguy is offline
Old 02-04-2013, 06:49 PM
  #12158
dangerwr's Avatar
I run a 24t on my 8.5T and is all good.
dangerwr is offline
Old 02-04-2013, 06:54 PM
  #12159
Originally Posted by dangerwr
What piston blanks are people using to make 2 x 1.7mm etc. for the BB shock? I ordered a set of blanks from Tresrey but are not designed to fit the stock shaft. They use 2 e-clips--wish I would have looked closer!!
I've used the Tresrey blanks with success. Never even noticed if the center hole was bigger or not, they worked fine. I also ordered a bunch of tapered blanks from Nick on Oople, and they work awesome. But, it took me about 2 months to successfully get my order from him, with his being in the UK and me being in the US. The first batch never showed up, lost in customs or something. He sent a second batch, and they finally showed up. 1.5x2 hole front pistons and 1.6x2 rear pistons work great. 30-32.5 wt losi oil front and rear. Stock springs.
Stealth_RT is offline
Old 02-04-2013, 07:03 PM
  #12160
dangerwr's Avatar
Yeah the center hole on the Tresrey are a little large but imagine they are doable. I will try to work with stock piston configurations but good to know you did not have an issue. Cheers!
dangerwr is offline
Old 02-05-2013, 04:35 AM
  #12161
KH
I run 24/25 depending on track layout with an 8.5. A cpl pages back I said I made a mistake and have been running 24/87 with a Tekin 6.5t with great results.
KH is offline
Old 02-05-2013, 04:47 AM
  #12162
my diffs are leaky on the V3, how'd you guys solve it? It seems to be missing a gasket seal, that's where I think the leak sprang
zzztech is offline
Old 02-05-2013, 04:58 AM
  #12163
There is no gasket, but they should not leak there. Did you grease the o-rings?
Mine have not leaked at all.
Old 02-05-2013, 05:01 AM
  #12164
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Also try using some fine emery (sandpaper) and lightly in a figure eight motion lap the diff housing surface that bolts to the gear. You will see there are high spots around the threaded holes. I do this before every refill.
Bman's 3XNT is offline
Old 02-05-2013, 06:18 AM
  #12165
Yeah I green slimed the O ring. The leak doesnt come from there
zzztech is offline
