Like Tree22Likes
Old 01-30-2013, 09:15 PM
  #12061
dangerwr's Avatar
Originally Posted by BigKid J
Cool Danger ill try it and let u know how it goes. while on oil thing whats good for big bore shocks front & rear ??
That is a much harder question because you have a whole system in play. Depends on piston and springs. I cannot offer any good advice on this front as I like to run stiffer than most my racing buddies. I like a stiffer suspension as I can drive the car harder once I figure out the car & track. Check the TD website for some ideas . ..
dangerwr is offline
Old 01-30-2013, 10:19 PM
  #12062
Suspended
Trader Rating: 440 (99%+)
Are the v3 cars pretty tough? I'm looking at buying a v3 and was curious if it was fragile or not.
MattP is offline
Old 01-30-2013, 10:22 PM
  #12063
Trader Rating: 25 (100%+)
They are pretty tough. Not as durable as your 22B but not as fragile as a B4. They still break but not often.
chevmaro is offline
Old 01-30-2013, 10:32 PM
  #12064
dangerwr's Avatar
MattP,
I have ran this car for 3 seasons now and have been impressed. The car is solid and have not found a problematic weak spot. There are a few concerns, which I understand the V3 has addressed, and entails; most importantly, the aluminum hinge pin braces. I certainly recommend an aluminum servo saver and servo horn. Some have problems with the plastic rear diff hoop so that might be worth your while to invest in aluminum. Cheers!
dangerwr is offline
Old 01-30-2013, 10:53 PM
  #12065
Suspended
Ok thanks guys. My last 1/10th 4wd buggy was a b44.1 and I saw a few durangos on the track and they looked fast. Plus I have recently bought a bunch of 1/8 durangos so I'm thinking of picking up their sct and their 4wd buggy.
MattP is offline
Old 01-30-2013, 11:06 PM
  #12066
8ight-e's Avatar
Trader Rating: 58 (100%+)
Make sure to get the v3, for the 99 over the r version it is money well spent.
8ight-e is offline
Old 01-31-2013, 05:53 AM
  #12067
Blown up's Avatar
It looks like dark blue fronts and light green rears and the front seems really soft? handles great, very nimble but the front of the chassis seems to drag alot. Any suggestions? The bottoms are in on the arm so I'll move them out and maybe tops out one hole too. I guess heavier oil. IDK, do they all run real low and soft like that? I may not even touch it.
Blown up is offline
Old 01-31-2013, 05:56 AM
  #12068
Briguy's Avatar
Trader Rating: 125 (100%+)
I have never liked dark blue springs up front , I found myself always going to black .
Briguy is offline
Old 01-31-2013, 06:23 AM
  #12069
Suspended
Ok I will thanks for the heads up....
MattP is offline
Old 01-31-2013, 06:39 AM
  #12070
dangerwr's Avatar
Oh and be sure to channel the gods of I do not know what because the electronics are a PITA to install into this machine.
dangerwr is offline
Old 01-31-2013, 07:18 AM
  #12071
8ight-e's Avatar
Maybe you just need to thicken up the oils... I run 1.2 x 6hole 45wt and it feels great with those springs.
8ight-e is offline
Old 01-31-2013, 07:19 AM
  #12072
Briguy's Avatar
Nope , not for me on the tracks I race at .
Briguy is offline
Old 01-31-2013, 07:37 AM
  #12073
Suspended
Tell me about it lol. I used to have a v1 and it was a major PITA to fit everything in there using a low profile servo and a micro spektrum receiver!
MattP is offline
Old 01-31-2013, 07:45 AM
  #12074
hotdognobun's Avatar
Trader Rating: 32 (100%+)
is it me or is installing the motor the worst? having to use a the allen key is not cool. Any news of an updated version like assoociated b44.1 where the screws are on the outside?.....still waiting on that two way slipper too!
hotdognobun is offline
Old 01-31-2013, 07:47 AM
  #12075
dgdcustoms's Avatar
Trader Rating: 85 (99%+)
How do you post the set up sheets? lol I will post the set-up I got if I figure out how...
dgdcustoms is offline
