Like Tree22Likes
Old 01-26-2013, 10:46 AM
  #12016
Blown up's Avatar
I've been running the DESC410 and love it so I have a new to me DEX410 coming in a few days. It's got all the Tresrey goodies including the carbon chassis. Does anyone have feedback on using the C/F w/alum rails vs Alum w/plastic?
Blown up is offline
Old 01-26-2013, 10:56 AM
  #12017
8ight-e's Avatar
Trader Rating: 58 (100%+)
Originally Posted by SEF
Link doesn't appear to work.
Also, is everyone just drilling out the pistons with a 1.3mm drill bit? What did you find was the difference when you went from 6x1.2 to 6x1.3? And how did you change the oil when going from 1.2 to 1.3? Thanks.
I moved the file to a public folder and updated the link... i'll email to try to get it on petitrc as well.
6x 1.3 is an included piston, at least it was in my kit.. comes with 1.2's 1.3's and blanks. I know some people drill their own from the blanks if they want less holes.. but I like the 6hole pistons.. just need to find the right wt oil for your track. To each his own though.. Some even plug up holes in the 6 holes to reach desired feel.
8ight-e is offline
Old 01-26-2013, 02:08 PM
  #12018
dangerwr's Avatar
Originally Posted by dgdcustoms
Yes it has all the upgrades and I have been building to the tech tips on the site. I will get the them other parts you speak of. Sorry it isn't a "R" just V3.
Thank You
Alright, yeah, TD sells an "R" version of the V3 which is $100 cheaper kit than the standard V3 with most of the upgrades people run. You should be good to go its kind of a pain to fit the electronics!
dangerwr is offline
Old 01-27-2013, 08:38 PM
  #12019
dgdcustoms's Avatar
Trader Rating: 85 (99%+)
Well the 410 is altogether now after another trip back to the LHS for all the hop-ups they had and hopefully set-up right for my local. I still need to get the rear aluminum gear box inserts and the other side of the motor mount. I really like the car so far and I'm sure once it hits the track I will like it just as much as my 210's I have.
dgdcustoms is offline
Old 01-28-2013, 01:27 AM
  #12020
DRCRacer299's Avatar
I was asked while at the Reedy Race to post my set-ups from the event so just sharing that I have done so!
http://lutzinator.com/?page_id=78
:-D
DRCRacer299 is offline
Old 01-28-2013, 02:19 AM
  #12021
Suspended
Trader Rating: 440 (99%+)
:-D
I'm sure a lot of guys will be interested in your setup Ryan. Thanks for posting that.....
MattP is offline
Old 01-28-2013, 07:14 AM
  #12022
majorsmx521's Avatar
Trader Rating: 44 (100%+)
Default thank you
:-D
thanks Ryan!!
majorsmx521 is offline
Old 01-28-2013, 08:49 AM
  #12023
Anyone know or has used other brand of springs that fit the TD big bore shocks and are they better than the TD? Thanks
MySlowZ is offline
Old 01-28-2013, 09:11 AM
  #12024
ABBOTT's Avatar
Several different springs fit the Durango shocks Losi, Avid, Kyosho, etc. I have witnessed others using them at the track but have not tried them myself so, I will not comment on quality.
ABBOTT is offline
Old 01-28-2013, 02:59 PM
  #12025
Briguy's Avatar
Trader Rating: 125 (100%+)
Anyone running an undertray ? Used to use the Azarashi tray but looks like you can`t get them anymore .
Briguy is offline
Old 01-28-2013, 03:13 PM
  #12026
For now I'm just using electrical tape and cutting it to size. Works fine for me. The bottom of my chassis still looks new. Another option could be AE's universal undertray.
MySlowZ is offline
Old 01-28-2013, 03:15 PM
  #12027
Briguy's Avatar
Thanks , I`ll check into the AE one and maybe work on making a vinyl protector .
Briguy is offline
Old 01-28-2013, 03:49 PM
  #12028
Actually I think it was jconcepts not AE that made the protective sheet. But I swear I saw somewhere that AE also made a universal protective sheet.
MySlowZ is offline
Old 01-28-2013, 04:00 PM
  #12029
Briguy's Avatar
Looking more for a lexan under tray . I can make a vinyl one . Thanks though !
Briguy is offline
Old 01-28-2013, 08:12 PM
  #12030
dangerwr's Avatar
Default Grub screw issues . . .
Guys,
The grub screw on my rear hubs back out causing my outer hinge pins to slide out towards the rear of the car. I have to dremel the hubs to work with my rear arms for some reason--otherwise they hit on the arms and do not have full range of motion. Make sense? This effectively removes material where the grub screw "bites." I can post pictures . . .
This happens on all the V3 plastic hubs I have used/replaced. What gives? Should I be dremeling the arms instead? Why in the heck do they not fit correctly or am I missing the bus here??
dangerwr is offline
