Like Tree22Likes
Old 01-15-2013, 05:21 PM
  #11881
jmackani's Avatar
Trader Rating: 14 (100%+)
Originally Posted by MySlowZ
What body shells are most of you running? Do you notice a difference when running cab forward shells vs the stock shell that came with the v3? Like I said in my previous post I'm traction rolling quite a bit... Will these cab forward bodies make it worse for me on the turns? Also will trimming the front outer spikes of the tire help (schumacher mini pins) reduces rolling? Thanks
Judging by your tire selection, are you running on carpet? If you are, forget the swaybars and start looking at the european setups on petitrc.com.
jmackani is offline
Old 01-15-2013, 10:01 PM
  #11882
Mxpdx's Avatar
Originally Posted by sparkwraps
Just dropped an R10pro into the 410. And by dropped, I mean placed carefully and positioned 37 times till I could get everything to fit well. Or as well as I could. I like clean intalls to, so I am not 100% happy with this, but not too bad...
That looks good. What receiver are you running in there? I'm thinking or running a mico Futaba like this one.
http://www.amainhobbies.com/product_...Micro-Receiver
Mxpdx is offline
Old 01-15-2013, 10:55 PM
  #11883
dangerwr's Avatar
Forgive me. So what is the point of this conversation?
dangerwr is offline
Old 01-16-2013, 12:45 AM
  #11884
High grip carpet?
I would be looking at taking 1 row off the inner and outer to start and go from there. Trimming the outside makes the most difference. If you find you are trimming up to 4 rows or more off the fronts, consider running 2wd fronts (run them on standard 4wd front). I find the 2wd front takes a lot of front end away (the 410 doesnt lack steering !)
Chris-s is offline
Old 01-16-2013, 05:04 AM
  #11885
sparkwraps's Avatar
Trader Rating: 34 (100%+)
I am running an Airtronics AIR92744. It is standing on its side there.
sparkwraps is offline
Old 01-16-2013, 09:16 AM
  #11886
Trader Rating: 79 (99%+)
Who's going to Motorama, I am all signed up..
Raul Garcia is offline
Old 01-16-2013, 01:29 PM
  #11887
Woulvesbaine's Avatar
Do you think you're R10 will be OK without the fan? I run an R10 160A on my 210 without a fan, but with draw of an 8.5 on a 4WD, my instinct would be to run the fan.
Let me know. I'm currently running an RS Pro in my 410 and may one day want to switch it around to my R10.
Thanks.
Woulvesbaine is offline
Old 01-16-2013, 02:27 PM
  #11888
Trader Rating: 72 (100%+)
It should be ok, but you have to temp it. If it runs over 140f I would put a fan on it.
patrick is offline
Old 01-16-2013, 05:37 PM
  #11889
Kennynham's Avatar
Trader Rating: 46 (96%+)
Default dex410
has anybody used the graphite chassis on a dex410 in mod (6.5t) on clay tracks?
is there too much flex when using graphite chassis with mod racing?
Just wanted to know if its worth while?
i guess it would be great in stock?
cheers
kenny
Kennynham is offline
Old 01-16-2013, 05:43 PM
  #11890
dangerwr's Avatar
cheers
kenny
People like it with the with aluminum side plates.
dangerwr is offline
Old 01-16-2013, 07:52 PM
  #11891
Mxpdx's Avatar
Thanks.
Yeah I think it will be OK if your running 6mins or less. I see a lot of people cutting their body for more air flow. I hope to have it together in the next few weeks so we will see
Mxpdx is offline
Old 01-16-2013, 09:27 PM
  #11892
Boadazofa's Avatar
Trader Rating: 33 (100%+)
Hi guys i am running on a carpet track. It is carpet that has been laid over the top of the clay track so it still has the lumps and bumps of a clay track. I am trying to fine tune my shocks for better handling so i have 3 of questions that i hope someone can answer for me!
1. can you set rebound in an emulsion shock?
2. If you cant set rebound would a bladder shock be better for bumpy track?
3. Has anyone used the tsr bladders or any bladder in there shocks?
peter
Boadazofa is offline
Old 01-16-2013, 11:11 PM
  #11893
alexkenison's Avatar
I run bladders in every I run. I know I'm going to get lit up for what I'm about to say but the idea of air mixed with shock oil goes against everything I know in full scale tuning. I don't care how consistent you build shocks you will never get them the same with air. Sure you can get it to rebound the same but who says your seal packs aren't sticking the same.
I use bladders and my shocks feel the same when I set the car down as when pick it back up after an 8 min main
alexkenison is offline
Old 01-17-2013, 02:21 AM
  #11894
Boadazofa's Avatar
I am running emulsion at the moment because i dont have bladders but i will be getting some! I want to run 50% rebound front and 25% rear is this possible with emulsion shocks because i just cant seem to get them to rebound, yet i see setup sheets with different rebound rates?
Old 01-17-2013, 08:23 AM
  #11895
Trader Rating: 25 (100%+)
How do I get more bite in the rear? It seems when I try to power out of corners I just spin out. I also want to lock in the rear a bit more. It has a ton of steering I am running my dual rate at 120.
chevmaro is offline
