Like Tree22Likes
Old 01-14-2013, 11:40 AM
  #11866
Originally Posted by Vincent_Diesel
Hey all. Adding a third Durango to my stable. DESC210R, DESC410 V2 and a new DEX410 V3.
What are your thoughts on this setup before I place an order, mainly need help on what Savox servo, Tekin Gen 2 motor to get?
I run a small-medium sized indoor clay track. 60ft straight mainly technical layout. Grip is medium. Overall smooth but lots of jumps.
DEX410 V3
Tekin RS Pro
Tekin Gen 2 Motor 7.5 or 6.5?
Savox Servo 1256TG High Torque
Thanks for the replies as this is my first BUGGY ever : ) I really want to do it right from the start.
I have the savox 1258TG and it's plenty fast and torquey.
The 1256 has more torque than needed in a buggy, and it's a bit slow for my preference.
I would go 6.5 for the motor.
jha07 is offline
Old 01-14-2013, 11:52 AM
  #11867
DEX410 V3
Tekin RS Pro
+1 on the SC-1251 servo. Its also 10g lighter than the 1256 and 57 servos.
I`ve tried Novak 5.5 and 6.5, but I like the Turnigy Trackstar 7.5 with boost best of all. Gearing 25/87 and both esc and motor max 65 dg celsius after 10 min. Hobbywing 2.1 esc..
ridgeracer is offline
Old 01-14-2013, 12:28 PM
  #11868
I just bought a 410v3 but still haven't had the chance to try it but, do most of you run the brass weights? Is it something that I should get or just don't bother about?
magnushedqvist is offline
Old 01-14-2013, 12:38 PM
  #11869
Originally Posted by jmackani
I would honestly go with a 6.5. I am running the 7.5 and have found that I have to boost it. You would not believe how much of a difference it can make on the straight aways. Not so much on the infield sections. You can always tame it down with the current limiter if needed.
I am running an SC-1251MG low profile from my touring cars. It has plenty of torque and speed for the steering.
Thank you. My gut is to go 6.5. Thanks
Besides tires what else would I need to be competitive? I'm thinking of giving Panther Tires a go since I've heard many great things.
Out of the box it seems the V3 has all that I will need?
Vincent_Diesel is offline
Old 01-14-2013, 02:02 PM
  #11870
Woulvesbaine's Avatar
I just started running mine and found the rear end a tad squirly. Accordingly, I purchased the TD rear brass balance (weight) set. You don't have to have this out of the box, but depending on your track conditions, it's an option to consider.
Woulvesbaine is offline
Old 01-14-2013, 03:55 PM
  #11871
Mxpdx's Avatar
Hello,
I just bought a V3 used from a memeber here on RCtech. I'm planning on running a R10 and an orion 6.5. I also have a Savox 1258tg that I hope will fit. My question is with the small amount of space will I be able to fit a futaba R2104gf?
Mxpdx is offline
Old 01-14-2013, 04:41 PM
  #11872
Originally Posted by Mxpdx
Hello,
It won't be easy since both your receiver and ESC isn't very small. I've found though if you get creative, you can manage to put a lot in there. Getting rid of the electronics tray gets you a bit more room, and laying the receiver on the side helps.
I put a Mamba Max Pro in there and it's larger than your R10. I do have a small receiver though.
Attached Thumbnails Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-img096.jpg
jha07 is offline
Old 01-14-2013, 08:11 PM
  #11873
sparkwraps's Avatar
Trader Rating: 34 (100%+)
Hello,
Just dropped an R10pro into the 410. And by dropped, I mean placed carefully and positioned 37 times till I could get everything to fit well. Or as well as I could. I like clean intalls to, so I am not 100% happy with this, but not too bad...
sparkwraps is offline
Old 01-14-2013, 08:41 PM
  #11874
What body shells are most of you running? Do you notice a difference when running cab forward shells vs the stock shell that came with the v3? Like I said in my previous post I'm traction rolling quite a bit... Will these cab forward bodies make it worse for me on the turns? Also will trimming the front outer spikes of the tire help (schumacher mini pins) reduces rolling? Thanks
MySlowZ is offline
Old 01-15-2013, 10:18 AM
  #11875
SEF
SEF's Avatar
Trader Rating: 39 (100%+)
Are you traction rolling on corner entry or mid to exit?
Sometimes you just have the wrong tires that tend to catch edges.
Assuming you have the correct tires and you're not catching edges, the first setting I adjust to stop traction rolling is droop. Limit some of your front and rear droop (start with just the front). I use 3mm of internal limiting.
Next thing would be camber, roll center settings, and sway bars.
But the body type will do very little in the way of stopping traction rolling. By the time you are traction rolling, you probably slowed down enough to not be affected by the body aerodynamics. I feel the difference in body type primarily when I am accelerating or right at corner entry.
SEF is offline
Old 01-15-2013, 10:22 AM
  #11876
jmackani's Avatar
Trader Rating: 14 (100%+)
Trimming the spikes will help. Then follow with camber settings.
jmackani is offline
Old 01-15-2013, 10:45 AM
  #11877
Ya I'm pretty much rolling upon corner entry. I'm gonna trim the front tires and try adding a bit more droop. Should I trim the inner or outside or both? Kinda hard finding a setup that works when I'm the only one that I see running a 410 and has minimal off-road experience... I guess that's part of the fun. Thanks to those that have been answering my questions, I'm sure there will be more to come.
MySlowZ is offline
Old 01-15-2013, 11:28 AM
  #11878
I think you want less droop, not more.
As for tires, do the outside.
jha07 is offline
Old 01-15-2013, 12:49 PM
  #11879
SEF
SEF's Avatar
Definitely LESS droop up front, especially if you are running full droop. Limit droop by using internal shock spacers on the shock shaft underneath the shock piston
SEF is offline
Old 01-15-2013, 03:50 PM
  #11880
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Swaybars and more negative camber, if your not already....
Bman's 3XNT is offline
