Like Tree22Likes
Old 01-09-2013, 12:23 PM
  #11791
Originally Posted by chevmaro
Mounting electronics in this car is a joke. Can somebody post a pic of their electronics install with a Tekin RS PRO?
Tekin is the easiest install !
http://www.oople.com/forums/showthread.php?t=31939
Chris-s is offline
Old 01-09-2013, 12:25 PM
  #11792
jackcarter3's Avatar
Go to page 693 I posted pics of my wiring with the sp v3 and futaba rx. Bulkier than the tekin and I got it in clean. I switched to tekin but have no pics. It's basically the same just cleaner.
jackcarter3 is offline
Old 01-09-2013, 12:55 PM
  #11793
Trader Rating: 25 (100%+)
Thanks, that's how I did mine I just didn't like the rx being hard to plug/unplug. I looked at mine again just now and I think I can get the RS PRO and rx to sit side by side. I am using the MX Sport RX and it is square but the M11X RX I have is rectangle and I think it will fit next to the esc. I am also going to open up the ESC and Servo and shorten the wires to make it look a little cleaner.
chevmaro is offline
Old 01-09-2013, 01:04 PM
  #11794
They will sit side by side with the tekin. I put my transponder under the slipper. That speed passion was a lot of stuff to fit in there.
Old 01-09-2013, 01:23 PM
  #11795
tibbs's Avatar
Trader Rating: 12 (93%+)
Are these all on back order I am looking to get one......
tibbs is offline
Old 01-09-2013, 01:25 PM
  #11796
There was a NIB Dex in the for sale section. Go Search it was a great deal too. I couldn't find one either so I purchased a clean used roller off ebay with a bunch of spares and it looks brand new .
chevmaro is offline
Old 01-09-2013, 01:58 PM
  #11797
Pm me if you wanna go the used roller route. Have 2 atomic carbon chassis, one is brand new and enough spares to build another car and it has a new tekin rs pro and 6.5 gen 2 in it plus all the tresrey stuffs, acer ceramics and d joints. It's just sitting on a shelf.
Old 01-09-2013, 02:25 PM
  #11798
Trader Rating: 38 (100%+)
are the aluminum side pods required to run the carbon fiber chassis?
jzwolen is offline
Old 01-09-2013, 02:27 PM
  #11799
The atomic carbon conversion is a molded tub. So it has more room and you don't use the stock side pods at all.
Old 01-09-2013, 02:32 PM
  #11800
SEF
SEF's Avatar
Trader Rating: 39 (100%+)
Here's how I did mine with an RS Pro and a Futaba receiver. Futaba receivers are a little big
Also, I am running a Gens Ace shorty pack.
SEF is offline
Old 01-09-2013, 02:33 PM
  #11801
SEF
SEF's Avatar
Originally Posted by SEF
I just got my hands on a v3 since I wanted to try some 1/10 4wd, coming from a primarily 1/8 scale racing background. Decided on a Durango because it looks like an 1/8 scale and will hopefully drive like a scaled down version. Also, from what I've read is more durable than the b44.2 or the xb4, and I like gear diffs. It's like the best of the b44.2 and xb4 but with durability
Anyway, I have 2 questions
  1. Can you set the slipper like a 2wd 1/10 scale? Hold the wheels down hit the throttle and make sure the front wheels only raise 2-3 inches? Or should I just run the 8.5 mm distance as recommended in the manual?
  2. I run primarily at WCRC. I am starting with Jorn's 2012 Reedy race setup as a baseline. I will get to drive it tomorrow. Anyone try this exact setup yet? Is it good for normal human drivers? Only reason I ask is because the 2 hole/45wt front and the 3 hole/30 wt rear makes the damping seem really heavy (at least on the bench). I guess I will find out tomorrow.
Anyone?
SEF is offline
Old 01-09-2013, 02:37 PM
  #11802
I think those may be the longest battery wires I have ever seen.
Old 01-09-2013, 03:48 PM
  #11803
symmetricon's Avatar
Trader Rating: 27 (100%+)
If I can for a losi exploderon and a standard futaba receiver I think you will manage.....
symmetricon is offline
Old 01-09-2013, 04:10 PM
  #11804
R/C Tech Elite Member
Trader Rating: 520 (100%+)
Tell that to the guy who has an RX8 in his..lol
flame56mx is offline
Old 01-09-2013, 05:42 PM
  #11805
tobamiester's Avatar
Trader Rating: 360 (100%+)
Anyone?
SEF,
I run the slipper stock in general.
Be aware that Jorn runs the small/standard bore shocks on his V3.
tobamiester is offline
