Like Tree22Likes
Old 01-03-2013, 10:12 AM
  #11761
Found a set of new proline calibers m3 cheap. Would these be okay for use on asphalt (tread wear)?
MySlowZ is offline
Old 01-03-2013, 10:21 AM
  #11762
Trader Rating: 25 (100%+)
Whats the deal with shorty packs? How do they make the car handle vs saddle packs? I just picked up a used 410 roller and I have both batt's. Does setup change much from one to the other? I will have to play around but I was just curious.
chevmaro is offline
Old 01-03-2013, 12:49 PM
  #11763
killermmn's Avatar
dumb question,what type of servo people use with they dex410?
killermmn is offline
Old 01-03-2013, 03:07 PM
  #11764
8ight-e's Avatar
Trader Rating: 58 (100%+)
I think mostly people trying to save a couple bucks.. the weight balance is far better w/ the saddle packs. Nanotech are super cheap, no reason to not get them. Most people add weight to the rear anyway, the shorty will just make it so you need to add even more weight. Just my opinion of course.
Hitec 985mg is a awesome servo... great price fast and plenty of power. They are great last the life of your vehicle.
8ight-e is offline
Old 01-03-2013, 11:34 PM
  #11765
racene1's Avatar
Trader Rating: 34 (100%+)
Sure, price is really the key esp. if your only messing around.
JT
racene1 is offline
Old 01-04-2013, 06:15 AM
  #11766
jmackani's Avatar
Trader Rating: 14 (100%+)
I believe it is just the opposite. The shorty conversion adds more weight from the batteries and most guys are removing the additional rear weights in this configuration.
The original reasoning was to get packs with more run time. Added weight was a side benefit.
jmackani is offline
Old 01-04-2013, 06:42 AM
  #11767
Maybe you are mixing the DESC410 and the DEX410 thread ?
A single shorty pack weights around 210g and a saddle pack from 265g ish.
ridgeracer is offline
Old 01-04-2013, 06:52 AM
  #11768
8ight-e's Avatar
Most shorty packs are less mah and less weight than the saddles.. and you have to get a nice left right balance as it doesn't fit in the given guides (ie foam spacers needed)
Typical shorty's I see around 4200, typical size for saddles are 5600 these days.
8ight-e is offline
Old 01-04-2013, 08:41 AM
  #11769
jmackani's Avatar
But when you run the shorties in parallel, you can get 8400 out of them. My mistake, I was thinking of my sct and not my buggy.
jmackani is offline
Old 01-04-2013, 08:42 AM
  #11770
jmackani's Avatar
You are right, my mistake.
jmackani is offline
Old 01-04-2013, 09:11 AM
  #11771
8ight-e's Avatar
yes in the SCT it would... no way to fit that in the buggy though.
PS a thin lead plate under your saddles from what I have seen works better than the weight from batteries (lower cog) but if you needed run time.. then it's a great trade off, get the longer run time and added weight. I run the SCTE, don't have either of those issues :P A standard 2s Intellect 6800mah fits just nice
8ight-e is offline
Old 01-04-2013, 10:47 AM
  #11772
jmackani's Avatar
Yep, I have an SCTE sitting on bench for this summer's outdoor season with 7200 SMC packs. Still keeping the Durango for indoors where it seems to excel on 1/10th style tracks.
jmackani is offline
Old 01-04-2013, 11:38 AM
  #11773
Trader Rating: 106 (100%+)
I see a lot of people running the plastic rear brace of the carbon fiber chassis brace... I would assume that the plastic what's the rear end flex more better traction?
dan-o is offline
Old 01-04-2013, 12:22 PM
  #11774
dangerwr's Avatar
That would be my opinion as well--I like the plastic better. Not a huge difference but it worked better on our track.
dangerwr is offline
Old 01-05-2013, 10:21 AM
  #11775
AboveU's Avatar
Just thought I'd share… Had a LHS with a used LRP V2 SSX comp ESC (ASCLRP80905). A friend runs this ESC in his DESC410 with a Pro4 4000kv motor and absolutely loves it.
Side story (I run Tekin in everything and familiar with the software/hotwire and love Tekin. With 3 RX8's, 1 RS, and 4-5 Pro4 motors and two 7.5 Redline motors, I've never had an issue except when my SCTE would eat and destroy motors via a never ending battle to fight over-heating.)
So I recently yanked my RS(non-pro) with my Tekin 7.5 out of my DEX410 and set it aside. I installed this LRP and a Pro4 3300kv. Still a work in progress as I learn how to tune the LRP via "feel" and "boost" modes. I've been creeping up on it as it started out extremely lazy and slow. Now it's getting faster but I'm at nearly full timing. I'm geared 87/23 at the moment and going to try a 25t and 27t pinion and pull some timing out, (boost).
My initial impressions are this motor combo are all good in the DEX410. Comes off the track after 12min of practice at 96° and about 2700mah used from my 5500mah batteries. I'll be playing with the gearing some more today and might even toss a 4000kv Pro4 motor in for fun. I'm not running any current limit and my EPA is at 100%.
I wish I had the newer rotors as this is a 5mm shaft motor so I had to pick up a few new pinions although I already had several as I run the 48p gears exclusively in my DESC410. Pro4 4000kv 102/23, so smooth and fast TQ'd and won with it last night's club race.
Anyhow many might wonder what's the point? Just playing around and having fun.
AboveU is offline
