Like Tree22Likes
Old 01-01-2013, 02:58 PM
  #11731
Originally Posted by racingdan
td210036 are a two way slipper clutch
Attachment 1011172
Main benefit?
mikeyscott is offline
Old 01-01-2013, 03:10 PM
  #11732
spunkysandoval's Avatar
Trader Rating: 125 (100%+)
Originally Posted by mikeyscott
Main benefit?
I think that might be like the decoupled slipper in the sc104x4. It allows the front and rear to have some slip independently of each other.
spunkysandoval is offline
Old 01-01-2013, 03:37 PM
  #11733
R/C Tech Elite Member
Jamison R's Avatar
Trader Rating: 66 (100%+)
http://www.team-durango.com/part-inf...artNo=TD220003
anybody using one of these?
Jamison R is offline
Old 01-01-2013, 06:53 PM
  #11734
Trader Rating: 54 (100%+)
Looking for some setup tips on how to plant the rear of the car better. The back end wants to slide out very easy on power.
jsmax is offline
Old 01-01-2013, 06:59 PM
  #11735
Trader Rating: 520 (100%+)
Thumbs up
If everything else is good (tires-shocks-etc) try taking out 1-1.5mm droop with the rear droop screws...
flame56mx is offline
Old 01-01-2013, 07:31 PM
  #11736
8ight-e's Avatar
Trader Rating: 58 (100%+)
I've been working on that too.. swapping shock setup has helped some, but also being .5mm higher in the rear seems to help a touch too. Tires tires tires though.. maybe getting too much front grip? try a different tire up front for less :P
I just went from 10k front and rear on the diff fluids to 10front 7rear, but I have not tested yet. Friday.
8ight-e is offline
Old 01-01-2013, 07:35 PM
  #11737
jmackani's Avatar
Trader Rating: 14 (100%+)
Are you running the weights under the skid and at the battery?
jmackani is offline
Old 01-01-2013, 07:49 PM
  #11738
Running both side and rear skid weights plus an extra 1/4oz. I did limit the front shocks 2mm but have not limited the rear droop, but will try that. Tires should be good for the track I run on, but also mounting some others to try. I have tried 2 different front tread patterns. Car seems to be lacking forward traction, side traction is good. I am running the same tires on on B44.1 and it is strapped.....
jsmax is offline
Old 01-01-2013, 08:01 PM
  #11739
I also have 2mm limiters in the front, 7frt/5rr for diff oils, the rear feels pretty planted..Its predictable, and its the best its felt on our clay track so far, as its been packing in..We're currently on green barcodes atm.. I have a set-up available, for wet clay, med/hi traction..pm me an email if you'd like to compare..
Old 01-01-2013, 08:15 PM
  #11740
PM sent, thanks. I am running 7k/5k as well. Maybe need to adjust shocks? Pretty much at any speed when I pull the throttle (to clear a jump for example) the rear end will want to kick out.
jsmax is offline
Old 01-01-2013, 09:05 PM
  #11741
CRFXXXT's Avatar
Trader Rating: 89 (99%+)
Just listed a great DEX410V3 package with a TON of parts and extras in the for sale section if anyone is interested:
http://www.rctech.net/forum/r-c-item...ons-parts.html
CRFXXXT is offline
Old 01-01-2013, 10:40 PM
  #11742
Originally Posted by ridgeracer
Nice work !
But your plastic servo arm wont last long when you start driving the car
Oh, i didn't know that, i just thought, that the servo saver breakes easy!?
Thanks for this info.
micholix is offline
Old 01-01-2013, 10:46 PM
  #11743
Originally Posted by Bman's 3XNT
When I had my LRP Esc. in I moved it further out, and ran the resistor under the driveshaft. May give you a little more room. Good Luck!
Did you that just for more room, or for some heat issues?
micholix is offline
Old 01-02-2013, 05:58 AM
  #11744
jmackani's Avatar
Where is your rear camber link on the tower?
jmackani is offline
Old 01-02-2013, 06:36 AM
  #11745
Rear camber link: middle on the hub and I have tried the inner middle and lower holes.
jsmax is offline
