Like Tree22Likes
Old 12-28-2012, 07:11 AM
  #11701
onekiwi's Avatar
Think that all the boots are optional and not a must
Diff house I have never seen a broken one
Get the alu diff house holders F+R if you can those plastic ones are pretty weak
Servo saver is a must
There are alu caster blocks that you could get with a 2nd hand cheapy from fleabay or here.
onekiwi is offline
Old 12-28-2012, 07:38 AM
  #11702
symmetricon's Avatar
Trader Rating: 27 (100%+)
I have read about the rear diff hoop breaking, but is this also a concern with the front end?
symmetricon is offline
Old 12-28-2012, 09:20 AM
  #11703
onekiwi's Avatar
fronts Im not sure about, did mine for piece of mind, the tresrey ones are nice as well, little cheaper as well
onekiwi is offline
Old 12-28-2012, 12:16 PM
  #11704
8ight-e's Avatar
Trader Rating: 58 (100%+)
I know people who have been running the desc410 forever with out replacing those diff hoops.. I think if you are careful when you pull the diff in/out to not wear or damage them they will hold up just fine. If you find you are breaking them, then replace um.
8ight-e is offline
Old 12-28-2012, 02:17 PM
  #11705
ekt
ekt's Avatar
I would recommend http://www.amainhobbies.com/product_...Rear-Hub-Set-2 rather than the caster block set, the v3 has those in aluminium.
ekt is offline
Old 12-28-2012, 02:36 PM
  #11706
slow_jun's Avatar
Trader Rating: 14 (94%+)
So glad that I didn't go with the Xray.
Anything else that I need?
-f/r arms
-allu servo saver arm
-cvd repair kit
-all boots f/r
-skids and balast weights
-tuning springs
-tuning shock oils
-extra 2mm pins
-Mcmaster pins (stock hinge pins bends easily)
-rear bulkheads (wing stay breaks on occasionally) on crashes.
-allu servo horn
-allu hexes f/r
-allu rear diff hoops
slow_jun is offline
Old 12-28-2012, 03:05 PM
  #11707
mdl060374's Avatar
Just finished my bugleboy body and undertray.
Gotta say it keeps it real clean and quiet. Well put together tray and body.
I have a handling question..
I am running on a tight indoor hard clay track with alot of turns.. An issue I am trying to figuyre out is that my onpower steering seems too little, and I have to cut way back on the throttle (almost all the way) to make tighter turns.. when I accelerate out of them ,I sometimes fishtail.. I am sure some of this is my trigger finger not being as sensitve as it should be, but any advice on how to balance this out?
I am running 10K front, 5K rear, BK bars, and 1' camber both front and back... This a suspension issue or a gear oil issue (or both?)
The car runs great, very pleased.. but I am just trying to fine tune it, etc..
(I am guessing I will probably need to drop down the oil to 7K front, 3K rear?)
Attached Thumbnails Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-s4010002.jpg   Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-s4010003.jpg
mdl060374 is offline
Old 12-28-2012, 04:41 PM
  #11708
Trader Rating: 52 (100%+)
Get rid of the plastic caster block set as the kit comes with alum.
tonyd is offline
Old 12-28-2012, 09:51 PM
  #11709
spunkysandoval's Avatar
Trader Rating: 125 (100%+)
Does anyone here know of a good hard plastic wing that I can run? I have a kyosho dbx wing, but I dont like the way it looks one bit.
I found a wing on ebay for a red cat that looks like it might work. It's 6.1" wide
06021 wing from redcat
any thoughts?
spunkysandoval is offline
Old 12-29-2012, 01:45 AM
  #11710
any thoughts?
3Racing have a hard wing that fits, but instead of the wing giving in when you roll/crash you are going to bust your wing mount when using a hard wing
ridgeracer is offline
Old 12-29-2012, 02:28 AM
  #11711
onekiwi's Avatar
LMR does great hard wings
onekiwi is offline
Old 12-29-2012, 02:33 AM
  #11712
Trader Rating: 106 (100%+)
What he said..
dan-o is offline
Old 12-29-2012, 03:37 AM
  #11713
Yea, I was kind of thinking that would be a problem
Old 12-29-2012, 06:16 AM
  #11714
8ight-e's Avatar
I run losi 10k front and rear, and I have the panther bobcats on the front.. TOO much on power steering I've dialed back my radio and tweaked a few other items from my base to get it in a good place. but mine has been the opp. I'm 1.5 camber f/r and about 1' toe out on the front.
I still get some of that fish tail, but I added about 1mm to the rear ride hight (~19.5mm) and it seemed to settle a touch.. I'm running the rear chassis weight but not the side weights.. considering the side weights as well in the future.
8ight-e is offline
Old 12-31-2012, 04:55 AM
  #11715
I see the mighty Ellis Stafford has been confirmed.
http://www.team-durango.com/blog/201...llis-stafford/
mikeyscott is offline
