Like Tree22Likes
Old 12-20-2012, 09:40 PM
  #11641
Dnf Don's Avatar
Ok guys ty for replys so theres no real #1body i need to buy basically what ever i like and i guess ill rebuild the stock shocks and save myself 120 bucks for now and see how they work. Track i race on is smooth clay with awsome grip atm Hope it stays that way. Everyone is running bald tires theres so much grip
ty again
dnf don
Dnf Don is offline
Old 12-21-2012, 09:41 PM
  #11642
Woulvesbaine's Avatar
Anyone have a good setup for OCRC (med/large clay)? Neuman's or Lutz's clay setups on petit.rc may be good, but thought I'd ask to see if anyone has setup specifically for OCRC.
Also, I'm about to put my bulldog body on and wondered if and where people are drilling air flow holes in it.
Woulvesbaine is offline
Old 12-21-2012, 09:46 PM
  #11643
Here is a pic of the new body. Needs a few more stickers.
Attached Thumbnails Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-durango.jpg
Old 12-22-2012, 05:00 AM
  #11644
Trader Rating: 106 (100%+)
What body is that?
dan-o is offline
Old 12-22-2012, 05:58 AM
  #11645
tobamiester's Avatar
Trader Rating: 360 (100%+)
Originally Posted by dan-o
What body is that?
Proline Bulldog
tobamiester is offline
Old 12-22-2012, 11:23 AM
  #11646
8ight-e's Avatar
Trader Rating: 58 (100%+)
Anyone have too much steering too much power.. LOL I put a base setup on last night and did a few laps and wow it steers on a dime, in fact way too much steering iMO. The rear end likes to break loose because it can't keep up w/ the front w/the tight turns. Using the chassis weight but not the side weights. Going to tweak a few things.. tossed on the big bore shocks (found a parted car on ebay so got a great price) and a aluminum servo horn (plastic one stripped in minutes).
Any thoughts or recommends? I'm running on a fairly tight indoor clay track w/ a med bite surface.
8ight-e is offline
Old 12-22-2012, 12:01 PM
  #11647
onekiwi's Avatar
Yeah too little steerings not a problem with this car. Use the side weights if you can, I also added 5 gms to each of the rear hubs. Drilled a hole and screwed them in place.
I also widened the rear hexes. Form the little I got to test it seemed to help a fair bit, but I then broke a rear alu diff loop. Ill test it with plastic one more tomorrow
What setup did you use?
onekiwi is offline
Old 12-22-2012, 12:24 PM
  #11648
8ight-e's Avatar
Gearing down to a 22t (keep the 24t for large tracks) on my blinky 8.5, slapped the big bores on and plan on testing with my Rx and see if I can't slow it up enough there w/o too many setup edits. If I don’t feel it getting close I'll grab those side weights and see how I like. I've seen a few setups out there and none of them used the side weights so I'm a little hesitant to bother.
8ight-e is offline
Old 12-22-2012, 01:12 PM
  #11649
R/C Tech Elite Member
Trader Rating: 520 (100%+)
Take 1-1.5mm out the rear droop using the droop screws, helps keep the rear end where it belongs. I also have my front end internally limited 2mm.
flame56mx is offline
Old 12-22-2012, 02:00 PM
  #11650
Will be interesting to see how Ellis Stafford gets on. I have a feeling he'll be v quick
mikeyscott is offline
Old 12-22-2012, 05:53 PM
  #11651
So excited..., this will be my first 4wd buggy. Going to be using the car for carpet. I'm assembling the car as per instructions. What shock weight oil should I be using? Any other changes I should change to the setup for carpet? Basically just looking for a good starting point for carpet.
MySlowZ is offline
Old 12-22-2012, 06:37 PM
  #11652
tedstryker's Avatar
Trader Rating: 88 (100%+)
new ink thought I'd share....
tedstryker is offline
Old 12-22-2012, 06:42 PM
  #11653
tedstryker's Avatar
never said i was a photographer..
Old 12-22-2012, 08:36 PM
  #11654
Nice looking PCR Ride Ted
Old 12-22-2012, 11:06 PM
  #11655
Very nice! I'm kind of craving Reeses Peanut Butter cups now too for some reason.
